Question about Taylor Ice Cream Makers
Relay keeps tripping - Taylor Ice Cream Makers
Taylor ice cream machine tripping on auto
sounds like you have a bad motor or compressor short
Feb 23, 2015 | Taylor Soft Serve C706-27 Machine
Why would our Model 702-27, be kicking the breaker. Tried changing plugs, but as soon as the breaker is reset and then the machine is turned on it kicks. The machine is full of product, and was runn
What breaker? The GFI on the wall plug?
If so,liquid may have entered the device and tripped the gfi breaker at the wall plug OR the main panel that provides power to that wall plug.
Nov 10, 2014 | Taylor 702-27 Tabletop Soft Ice Cream...
Put a new motor in the left side, but when you try to run it, it keeps tripping the reset button and turning off. The left side controls the hopper cooler, so I come in and the hopper is warm on both...
Did you check the wiring ? This motor is reversible and you may not have the wires under the connection plate. A model number would be very helpful as I am looking at model # 339 manual.http://www.taylorfreezersales.com/op_man/0336_338_339op0.pdf
Jun 29, 2011 | Taylor Ice Cream Makers
The Alarm is going off continues to beep is making Ice cream Model is c707-27
There is a self test by holding the Mix,Wash and Pump keys on the logic panel while simultaneously turning on the power switch.Hold down the keys until all eight lights illuminate.Each light on the panel will not extinguish until the test is complete for that particular relay.Could be one of the relays is bad.
Jan 12, 2011 | Taylor Ice Cream Makers
Taylor 754-27 runs good until ice cream is made then trips-not able to restart in auto or wash-able to turn beater with hand-not binding - after ice cream becomes liquid able to start again in auto or...
It is possible that your viscosity is set too cold. You should check the temperature of your product to see if it is too cold. Is the Ice Cream hard? It sounds like maybe the beater overload is tripping. Some of the overloads can reset on their own. If you have and know how to use an ammeter, it would be beneficial to check the amp draw of the beater motor to determine if you are exceeding the overload or not. Ice cream is generally good at a temp between 16 and 20 degrees F. Temps vary with product and product brands. I hope this information helps, it is hard to determine exact problem without being there.
Oct 04, 2010 | Taylor 632-33 Ice Cream Maker
Toaster when ipush the handle down to toast the two slice of bread does not hold down please an advise
This is due to no power going through the relay that holds down the slice bar, when the setting is reached, the relay is de-energised, and it Pops Up. It is NOT doing so, due to A: No Power to the Unit, or B: Power is getting to unit, but one or more "Elements" is burnt out. or it has developed a controller fault.
Apr 06, 2010 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Taylor 770 soft serve
754-27 Taylor soft serve machine Beater motor not running - compressor not engaging - Power to beater relay but not out of relay.
May 18, 2008 | Ice Cream Makers
Ice Cream Makers Logo
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
