Question about Lexmark Office Equipment & Supplies
I have a Lexmark 300-400 Series printer and when i print the page comes out blank. please help
SOURCE: Lexmark x1185 printing problems
my lexmark will not print in color
Posted on Jan 30, 2008
mediatecar
  • 60 Answers
SOURCE: My printing displays wrong ink levels and prints blank pages
If your cartridge is new (or full) and you know that not just from ink levels display, then you did not used the printer for a while (at least a month) and the nozzles of the cartridge are clogged. If u used the cartridghe 4 or 5 moths ago, then the whole cartridge is dryed out, so get out and get yourself a new cartridge.
If it's just a month, then you should put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the cartridge with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridge in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the cartridge on some sheets of tissue.
Install the cartridges it in the printer and run a few cleaning processes from the printers maintenance software.
If the cartridge is new and just installed in the printer, and you have the inklevels but it does not print, then get it out of the printer and back to the store, they should replace it for you. I hope you removed the protective plastic stripe that covers the nozzles before installing the cartridge?...
OK, let ne know please how things evolve.
Hope it helped you, rate the solution.
Almoust forgot: ink levels are displayed by Lexmark inkprinters by estimating the ink consumed trough you printing process, it has no sensors in the cartridge. It's just kind of a counter, you can evan set an empty cartridge to be seen as a full one.
Posted on Feb 15, 2008
PeteG0429
  • 34 Answers
SOURCE: prints extra blank page for every one page of printed material
Ok, I too have HP Photosmart 7280 and it was spit'g out a blank page after each print page.
I went into the Control Panel/Printers - Right click on the HP Photosmart 7200 series icon and choose delete. Don't worry...just delete it.
Right above (Vista) click on Add a Printer - it's going to ask you if you want to add a local printer which is connected via USB connection or if you are set up wireless then choose Network
It will find your printer click on the printer hit next - then this is the most important step
It will ask you to find the manufacturer it shows Hewlett-Packard and underneath it shows HP - Do not click on HP - you'll have the same problem with that driver - choose Hewlett-Packard and find this driver HP Photosmart C7200 series Version 61.71.244.0 [3/23/07]
Hopefully they are all digitally signed with this information.
Click on that driver and click next - then click on replace the current driver and click next.
Print a test page and problem should be solved. Hope it helped!
Posted on Apr 01, 2009
PeteG0429
  • 34 Answers
SOURCE: One extra blank page coming out for each page actually printed
There you go. Good luck!
Posted on Apr 14, 2009
PeteG0429
  • 34 Answers
Here you go...
Posted on May 18, 2009
Prints no ink
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 1300 Series folder.
  4. Select Lexmark Solution Center / All-In-One Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Feb 14, 2012 | Lexmark Z1300 InkJet Photo Printer
Why is paper blank
  2. Go to Programs.
  3. Go to Lexmark 3600 Series folder.
  4. Select Lexmark Solution Center.
Feb 12, 2012 | Lexmark X3650 Printer
Lexmark wireless printer 1400 series prints blank pages
  2. Go to Programs.
  3. Go to Lexmark Z1400 Series folder.
Jan 22, 2012 | Lexmark Z1420 Printer
Printer-printhead replaced but paper is coming out blank
Make sure that your printer's firmware is up-to-date. The firmware update for the Lexmark Interpret S405 printer addresses print quality issues. Please visit the Lexmark website to download and install Lexmark S400 Series Firmware Update. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
After updating your printer, please run the Deep Clean Printhead one time. From the printer operator panel, press the Setup button > Maintenance > Deep Clean Printhead. Your printer will then print a page forcing ink through the cartridge nozzles and clean them.
Then try to print your document again to verify that the problem is fixed.
Nov 30, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Lexmark pro 205 printing a blank page before a document
If you're using Windows, try to follow these steps to fix the problem.
  1. Start menu > Printers & Faxes > Lexmark Pro200 Series Properties window pops up > go to Advanced tab > Printing Defaults.
  2. The Lexmark Pro200 Series Printing Preferences window pops up > go to Advanced tab > More Options > under Suppress Blank Pages, enable "Enable blank page suppression"
  3. Save the setting.
  4. Try to print a document again to verify that the problem is fixed.
Nov 09, 2011 | Lexmark Prospect Pro205 Wireless...
Lexmark interpret s400 prints a blank page
A firmware update addresses a number of known issues for your model including print quality issues. Please visit the Lexmark website to download and install the Lexmark S400 Series Firmware Update.
Should the problem continue, please contact Lexmark Technical Support for additional assistance.
Oct 19, 2011 | Lexmark X1240 All-In-One InkJet Printer
I have two computers on my network, an iMac and a PC running Windoew 7. I recently purchased the Lexmark Pro901 and installed it on the network. It(the Lexmark Pro901) seems to connect fine to the network...
It could be a software issue. Try to uninstall the existing Lexmark Pro901 driver from your desktop pc by going to Start menu -> Programs -> Lexmark -> Pro900 Series -> Uninstall Lexmark Pro900 Series. Reboot pc when prompted.
Now, check your Windows 7 if it's running on 32-bit or 64-bit by going to the Start menu -> right-click on Computer -> Properties. Take note of the System Type.
To reinstall, download the Lexmark Pro900 Series driver using the links below: - Lexmark Pro901 driver for Windows 7 32-bit - Lexmark Pro901 driver for Windows 7 64-bit
Download, execute the file and follow the instructions on the software.
I hope this information has been helpful. Thanks.
Jan 04, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Help
Did you make sure the cartridge nozzles were clean? They will dry out over a period of time without use. Make sure the driver your using is the latest version from Lexmark. Hope this helps,, Mechanic
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_652569481_0_en,00.html
Dec 31, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
149 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
