Question about ASUS G73JHA2 Notebook
ASUS G73J line in option does not work
When I plug in an audio line in the microphone socket the option to switch to "line in" does not pop up as it does on my other laptop. The recording has a strong background hiss.
    New Friend:
In the recording audio settings when the new line in device is plugged in select that as default, then it should revert back to old setting when it is not in use but select the default when you plug it in, however there should be an option in the audio settings to adjust the hissing you hear, see if you do not have some boost in the settings turned on, i know making the line in boost will create hiss
Posted on Jul 29, 2013
I have a tower computer kind of older . when i plug in the microphone to the back i.e. microphone port, nothing happens to signal it reads the microphone and when i try to use the microphone for fruity...
Assuming you are running windows XP you need to
1. right click the speaker in the lower right corner and select adjust audio properties.
2. Select the audio tab
3. Pull the drop down menu under sound recording and make sure it is selected to your audio driver device. Most are either soundmax, creative(for soundblaster and audigy standalone cards), realtek, or ASUS.
4. Next repeat step one but select open volume control
5. Go to options and then properties
6. Select the circle for recording and make sure your mic input is checked.
7. Close that window and recording mixers will pop up. Select the input you need by checking the box in the lower left corner of the mixer channel. Adjust the level and then use your recording program or sound recorder under Program files>accesories>communication>sound recorder.
Mar 08, 2011 | Philips Phillips...
I just bought an audio technica at2020 cardioid condenser mic its the 20 series and i cant figure out how to get it to work on my toshiba laptop
Unlike 'Dynamic' microphones all condenser microphones require some sort of power supply to make them work. Sometimes this can be by way of an internal battery but many of them work on an external 'phantom' power supply.
I am not familiar with the exact model number you quote but AT make 2 types of AT2020 condenser microphone.
1) If your AT microphone is fitted with a USB plug then you can connect it directly to the USB socket on your computer, which will provide it with the power that it needs to make it work. The USB bus should automatically recognise the microphone and allocate an audio channel to it but you may still have to select this device as your input source in your recording program. How you do this will differ from one program to another.
2) However if the microphone is fitted with a standard jack-plug then it will not work by you just plugging it into your computer microphone input socket as this is not powered. You will need a separate 48volt DC power supply to power the microphone.
You will almost certainly also need some sort of microphone pre-amplifier to match the output voltage and impedance (electrical resistance) of the microphone to the levels required by your audio input socket on your computer.
Probably the best way to achieve both of these requirements at lowest cost would be to purchase a small audio mixer with a phantom power option such as the Phonic AM220 http://cpc.farnell.com/phonic/am220/mixing-console-am220/dp/DP29303
WARNING - most audio mixers only have one on/off switch for phantom, power - thus the power is either on or off for ALL channels. Some other devices - like radio microphones, keyboards and electric guitars may be damaged by having 48v dc current supplied to them
Here is a link to the technical specs sheet for the AT2020 http://www.audio-technica.com/cms/resource_library/literature/49f63e6efc082082/at2020_english.pdf
More information is available here http://www.dolphinmusic.co.uk/article/40-why-do-i-need-a-microphone-preamp-.html
Jan 28, 2011 | Audio Technica Audio-Technica AT2020 -...
I have installed Win 7 on a separate partition, dual booting with my previous XP. I find that, to get any audio output in Win 7, I have to connect my 'line out' jack to the pink 'microphone' socket instead...
if you have the full version audio driver then you can set the pins at your own choice. the full version driver have a utility that will help you to change the pins audio in one of the windows.
Jan 07, 2010 | ASUS K8S-MX Motherboard
I have got 2CH speakers idont know where to plug in to the CPU
There are usually 3 audio connectors on a sound card. For Line in, headphone/line out and microphone. The connectors maybe connected to the motherboard or there is a separate sound card.
These connectors are 2.5mm audio sockets - connect the speakers to the headphone/line out (usually green).
If you are not sure which connector to plug the speakers in, just start a audio CD and plug the speaker plug into each socket connector until you get music from the speakers. You will not damage anything if you plug the speakers in the wrong audio socket.
Oct 24, 2009 | Acer X193W LCD Monitor
I skpe using my Asus, and my microphone does not work.The other party can't me...how do I solve this please
Hi
Are you sure that this laptop has a build in microphone? or are you using a external microphone?
in either case the most likely problem is that the skype sound settings on the input are wrong.
open skype, tools, options, then the audio settings page.
On the microphone, try all the possible options offered and see if it detects your voice, you can also try calling the skype test number / echo123.
When you see the volume bar light up green like this as you speak or tap the microphone its working.
If you are using a external microphone, are you sure you have it on the right slot? Try the other plugs on the laptop and then go over the options again and see if you get sound.
You should also check from volume control that the microphone is not muted.
To check that open up start -> control panel -> sounds -> recording -> select the microphone and click properties -> check the levels tap and make sure its not muted and its turned up to full volume.
also some microphones have a on off switch on the wire, make sure its turned on.
By now you should be able to talk on skype.
Let me know if you need further assistance.
Thanks,
Ekse
Aug 13, 2009 | ASUS m6n Notebook
Desktop Microphone 600 works on roommate's HP but not on my Dell
Be sure your microphone is working fine, try to reconfigure your sound device. maybe you've miss something
Jul 27, 2009 | Logitech (980240-0403) Microphone
I an trying to make a call via skype i have made a test call I can hear them but they cannot hear methe message is microphone must be muted
make sure the "pink" plug goes to the pink socket in your computer
open skype Options -> Audio Settings and adjust
Dec 08, 2008 | ASUS M2N-E SLi Motherboard
I purchased a computer microphone model mc-1000. I did not recieve any instructions with this item and would like to know how to go about using it. I am not very literate when it comes to computers, but I...
at the bottom of the screen next 2 the time u shud see an arrow pointing 2 the left. click that and more options shud pop up. in those options there shud b a diagram of a speaker. right click on that and selcet adjust audio properties. a new window will appear and select audio from the tabs at the top. on the microphone option select the mic that u installed. click the volume tab. on the sliders make sure that the mic slider has been selcted with a tick and adjust the volume to suit. if it still isnt working the plug the mic in different sockets til it does.
Jun 24, 2008 | Computers & Internet
Microphone can be detected but doesnt work
Go to start then control pannel then sounds and audio devices. Then in in the volume tab select advanced in the device volume section. When the mixer comes up go to options then properties select the recording option a recording mixer will come up make sure to check the microphone box. Raise the level in the ixer and you should be golden. If you want to hear the mic select playback mixer and raise the mic level. Hope this helps. : ]
Dec 09, 2007 | ASUS P5RD1-VM Motherboard
ASUS G73JHA2 Notebook Logo
49 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
