Question about Dryers
Dryer when i turn the dryer on at first it works fine but after the heat goes off it wont come back on need help
  • 625 Answers
Check for a lint blockage in the blower discharge line. there is a quarter size overload in the metal blower line. evidently the heat is building up to the point that the overload is kicking out. once it's cool it operates fine.
Posted on Sep 06, 2007
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
Dec 30, 2015 | Roper REX3614KW Electric Dryer
Dryer wont heat
either the element is bad our the diode that controls the heat element is bad
Jul 04, 2012 | GE Dryers
My dryer runs fine, just wont heat, was working fine this morning, but on my second load of the day it stopped heating, cleaned all the lint from front-even pulled out and cleaned the lint from the back...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 30, 2011 | Bosch Nexxt 500 Dryer
Bought my dryer bout 3 years ago it spins fine , goes on spins, just wont heat at all.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 02, 2011 | Dryers
My dryer won't heat up, it will start and it runs fine but it wont get hot. i just hooked it up and it was new but the warrantees expired on it so i cant take it back to the store. how do i make it heat...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer starts and then heating shuts down in about 2 minutes does not start heating againtimer not moving
The pilot light lights? Then goe's back out? There is two stiff wires right in front of the flame. One of them is an ignightor, and the other one a thermocoupler. Or may just be one. That is the ignightor and thermocoupler. The thermocoupler is what detects that the pilot light lit. Its a saftey feature. It makes sure that there is fire before it turns on the main gas. So it wont blow up. It gets a film built up on it from the gas. Take some real fine sandpaper, or steel wool and clean it real good.
Then try again. It should work. If not then it needs to be replaced
May 21, 2010 | Dryers
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
Maytag MDG16CSBWW heating problem
I have a Miele Novotronic T560C. The tumble drier is working fine except the air circulating is cold - it does not heat up at all. What could the possible reason for this and/or solution?
Oct 05, 2008 | Maytag MDG16CS Gas Commercial Dryer
Dryer wont heat!
It could be a problem with the terminal block in the back of the dryer.  You'll need to unplug the dryer and check the block.  I learned this on home depot.com/ApplianceRepair.  Should cost you under 75 dollars to fix if you do it yourself.
Jul 28, 2008 | LG DLE3777 Electric Dryer
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Dryers Logo
1,090 people viewed this question
Top Dryers Experts
