Question about KitchenAid KUDC10IXSS Builtin Dishwasher
Kitchenaid dishwasher not turning on KUDC10XISS4
Hi, My Kitchenaid dishwasher is not turning on at all, all other power is ok...
the dr
  • 447 Answers
SOURCE: KUDIO1ILBS2 KitchenAid Dishwasher
These dishwasher have a thermal fuse near the contol panel protecting the heat sensitive computer. Do you use the Sanitize or Anti-bacteria cycles?? If so then these cycles get very hot and could have made the fuse blow. Kitchenaid also had some loose connection problems at the fuse making the fuse heat up due to the electicity and not actual temperature. The new fuse comes as a kit with connectors already attached to the fuse (dont mess with them) and a junction block to splice the wires.
Posted on Jan 18, 2008
localwonder
  • 6784 Answers
SOURCE: Kitchenaid dishwasher making funny noises while running
HI. this sounds like a busted impeller in the pump housing. there are two impellers. one for the wash and one for the drain. the drive shaft will strip the impeller center nut, causing this noise. I would inspect the pump housing for lose impeller action. replace the faulty impeller if found to be damaged.
Posted on Jun 11, 2009
SOURCE: Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Posted on Jun 12, 2009
praky16
  • 744 Answers
SOURCE: Kitchenaid custom 21 dishwasher will not turn on
Hi, this is a control fault that is localized in the logic sector of the control board. the logic chip which holds all wash programing is damaged. you will need to replace the control asap if possible...
thank u
rate me!!
Posted on Jul 27, 2009
erpaalai
  • 999 Answers
SOURCE: kitchenaid KUDS25SH
Hold the button down until it beeps and the light goes off. Eric
Posted on Sep 03, 2009
Stella@starridgestables.com i cannot get the child lock to turn off and i cannot get the dishwasher to star
please provide the full model number of our kitchenaid dishwasher.
have you tried turning the power to dishwasher off and back on again from the mains switch.
Childlock can be turned off by pressing the childlock button for 4-5 secs.
If childlock light is continuously flashing then there is a fault in dishwasher.
Nov 25, 2010 | KitchenAid Dishwashers
Blown fuses
Hi
You can get the manual for your kitchenaid dishwasher from this link---
Kitchenaid Kuds01dlss Dishwasher Manual
Please post back for any further assistance.
Daniel
Jul 22, 2010 | KitchenAid 24 in. KUDS01DLSS Built-in...
Kitchenaid dishwasher KUDK02CRBS the spring on the door broke? Is this a easy fix, where do you access the spring
Turn off the power to the dishwasher.
Remove the access cover on the bottom front of the dishwasher.
Lying on the floor,you can see the door hinges and replace the spring.
Feb 12, 2010 | KitchenAid 24 in. KUDK02CRBS Stainless...
Kitchenaid imperial 24. it will not turn on.
Have you checked the breaker or fuse at the power panel ?
Nov 08, 2009 | KitchenAid Dishwashers
KitchenAid W.Q. dishwasher turned itself off cannot restart
Looks like power is been lost, 1st ck power at junction under the unit, if ok ck the thermo fuse on the control panel, if it's out, replace it with the fuse kit recomended by Whirlpool on their Service Flash on this unit.
This should be done by a trained Tech.
Sep 17, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
No power on KitchenAid (KUDr01tj) dishwasher
You must have fuse 16 amps or 20 amps.16A is enough if is heater
OK.If heater is broken You must replace it.
Dec 16, 2008 | KitchenAid KUDR01TJ Dishwasher
KUDIO1ILBS2 KitchenAid Dishwasher, two years old, not heavy usage: control panel is dead, no other power problems in the apartment, the apartment's electical box shows all breakers ok.
Jan 18, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Clean Light Flashes
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Oct 07, 2006 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid KUDC10IXSS Builtin Dishwasher Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
