Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
Pump contiues running as soon as you switch on carrys on running with door open and after re set not filling timer working
  • 1 more comment
  • Alboy Feb 03, 2008
    Exactly the same problem, pump runs as soon as machine is switched on and will run even with the door open.
    Tilting the machine back on itself seems to have cured it. Thanks.
  • Anonymous May 04, 2008
    I had the same problem. Been looking for an answer online for past 3 hours. Read your post and did what you said by tipping back and it worked!!! Can't thank you enough.
  • ArthurShack Feb 09, 2009
    Tilting it back worked a treat! Do be prepared for more water on the floor when performing this manoeuvre though. Thank you for the decidedly top tip.
Yes tipping the unit on its back at 45 angle for a few minutes worked. However, when the dishwasher was pushed back under the surface the problem re occured. We solved this by altering the feet at the back so that it was just slightly lower at the back and it works fine again. Excellent advice on this page. Has definately saved us a call out fee.
Posted on Oct 19, 2008
Yes tipping the unit on its back at 45 angle for one minute and opened door pushed on switch and closed door and it came to life, unbelievable! thanks for saving us $200 +
Posted on May 21, 2008
  • 183 Answers
The anti flood switch has activated, remove lower panel and dry out, if possible locate leak and retry, this will resolve fault. Regards Advisor
Posted on Aug 31, 2007
    Problem Solver:
The 45 degree tilt idea was brilliant. Saved me having to wash up in the old fashioned way - Great idea
Posted on Mar 27, 2009
Brilliant - worked a treat and saved me a fortune. Thank you
Posted on Jan 16, 2011
    New Friend:
The 45 degree tilt worked for my machine also,working like a dream now.Many thanks for your advice now know how to reset the programmes should it happen again.
Posted on Apr 02, 2010
Pull dishwasher out, tip it back on itself raising the front about three inches to allow any water in the overflow to drain out. put dishwasher back in place and it'll work fine. Worked for me.
Posted on Dec 17, 2007
SOURCE:
When i put my car in park open the door, light does not illuminate andthe doors dont unlock.and when i turn off the car,and open the door, the stereo contiues to run.what is going on
- ensure the interior light control switch is set to turn on with door.
- the stereo may continue to run if the key is left in the ignition.
Feb 24, 2015 | Cars & Trucks
I have to open and close the door several times to reset the timer wheel for a new cycle. cycle light
The timer works like a clock if you like. The cycle starts at 12:00 finishes around 11:55. When you open the door, the timer advances to the 12:00 position resetting itself to the start of a new cycle. The door has to be open for about 12 seconds. Check on the left side door hinge bracket and see how it plays on the door switch. old doors on the SR24's had an issue of the hinge screw coming loose which triggered the switch too soon. You should be able to rest the door against the tank without the maching running. The switch should close as the door engages the latch.
Jan 27, 2014 | Hobart SR24-H Built-in Dishwasher
Hi I have a Dewalt d55141 emglo contiues to run
Open the shut off switch box and adjust the cut out pressure.
Nov 17, 2009 | Dewalt & 2HP Hand Carry Heavy Duty...
Stays in wash cycle
Solution found in a defective SPDT 'Heater ON' switch which had burnt out, thereby causing an 'open' to pump solenoid, fill valve, and heater. Temporarily bypassing the switch confirms the solution. Buy either the whole switch panel (3 switches) from parts dealer or find a source for CW Industries part GRS2012-13.
May 27, 2009 | GE Dishwashers
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
Soon as i set cycle and swich on door light flashes open
hi,
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Thanks for your question.
Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
Pump continuing to run -Asko D3100
Micro switch was actually faulty,moisture had entered the switch and caused internal tracking and shorting out the micro switch ,making the pump run continually as it thought it was still in flood mode.
Flood appears to have been caused by a pin hole in the water fill hose in the base of the dishwasher,causing water to spray on the micro switch and eventually biuld up in the base of the machine.
Aug 05, 2008 | Dishwashers
Have a Bosch shy56a05uc dishwasher that suddenly stopped working to a point. I believe it is related to the door latch switch, because I don't feel the door securely latch shut when I close it, and I also...
Does your dishwasher electronic control or mechanical timer? if mechanical timer, I encounter a similar problem n change the mechanical timer. that problem solved.
Prince P
Jul 23, 2008 | Dishwashers
Waterpump won't pump and spin cycle won't start.
one of 2 things are happpening iether hte timer is not sending down the power to operate the pump , or switch is not closing correctly to allow power to the pump
Mar 19, 2008 | Frigidaire FWS833A Top Load Washer
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
914 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
