Question about Fujitsu M1010 Sub-Notebook
Reset cmos jumper - Fujitsu M1010 Sub-Notebook
How do I reset my password
on board password with jumper clear cmos You have 3 pinns on motherboard near battery clr cmos jumper close 1and2 open jumper from 1and2 and close 2and3 after few sec put jumper back on pin 1and2 and your cmos is reseted and bios need set new settings for windows have utilities depends of software
Jul 18, 2014 | AccessData Password Recovery Tool Kit (ftk...
"Reset you're cmos/bios jumper to
HI,
No need to worry. There are many known ways to reset / remove / bypass the password:
  • By removing the CMOS battery
  • By using the motherboard jumper
  • By using MS DOS command
  • By using software
  • By using Backdoor BIOS password
Now I'll try to explain each method one by one:
A. By Removing the CMOS Battery:
Almost all motherboards use a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
If it fails, then try to remove the battery for at least one hour.
B. By Using the Motherboard Jumper:
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
C. By Using MS DOS Command:
This method works only if you have access to the system when its turned on because this method requires MS DOS. Open Command Prompt from Programs menu and provide following commands one bye one:
debug
o 70 2E
o 71 FF
quit
NOTE: The first character in the above commands is "O" and not the number 0.
After providing the above commands, restart your system and it should reset the CMOS Settings along with the BIOS password.
If you are curious to know how it works? then let me explain the above commands:
In this method we are using the Debug tool of MS DOS. The "O" character present at first in these commands, outputs the values to IO ports. The number 70 and 71 are port numbers which are used to access CMOS memory. By providing FF value we are telling CMOS that there is an invalid checksum and it resets the CMOS settings as well as BIOS password.
Jan 08, 2011 | Intel DG31PR Motherboard
Where are the bios reset pins on apire one aod150
Here is the BIOS reset pins and the CMOS battery of acer laptop. You can reset BIOS password also trough removing the CMOS battery. 04ebfdf.jpg
Apr 03, 2010 | Acer Aspire One AOD150-1920 Netbook
I need to reset password on my Acer 4230, and I can't find the cmos battery to remove
The CMOS battery looks like a small circular disc
http://www.tccycling.com/misc/5672inside.jpg
Just remove the connector hold for 30 seconds and plug it back in. Thats all.
Jan 27, 2010 | Acer TravelMate 2300 Notebook
I was forgot my assus motherboard bios password can any body help? without open the cabinet give me solution
There is no solution with out getting in the cabinet and removing the CMOS battery or moving the CMOS jumper on the CMOS pins. Desktop computers have a password reset built onto their motherboards. This reset area has three pins with a jumper on two of the pins, when you need to reset the cmos (and get rid of a password) this jumper has to be moved over to the pin next to it and the computer powered up to reset the cmos, then the computer gets powered down and the jumper placed back in the normal position.
Nov 11, 2009 | Computers & Internet
I need to reset the CMOS Password for my acer extisia 4230
for that you need to open back cover of laptop .
Then find motherbord there.
Pull CMOS cell from motherbord for 10 minutes then refix it .
Also you can clear cmos with jumper find jumper near cmos cell named "clear CMOS " it has 3 pin
Set jumper i 2-3 position then power up 1 time then again set jumper in 1-2 position then it not ask for password.
Let me know if you need more assistance.
Thanks.
Oct 21, 2009 | Acer Extensa 5620-4020 Notebook
How to get toshiba bios password remover toos
ok what you will need to do is reset the bios. just take out the bios battery for a couple ofseconds then putit back in this normaly resets the password Regards Slitwrists
Jun 08, 2009 | Toshiba Portege S100-S1133 Notebook
Reset Cmos Settings for Acer Computers
There might be a jumper on your motherboard that's labelled CMOS, or reset... you just have to move the jumper to the other pin combination, power up your PC, then turn it back off and replace the jumper.
If you can't find a CMOS jumper, try unplugging your computer and removing the battery on your motherboard for a few minutes. When you turn it back on, your CMOS should reset to factory defaults.
May 07, 2009 | Computers & Internet
Jumper settings
There is no jumper settings, it is just a small bridge aside the bios Chip. you bridge the two pins and power to reset cmos.
A much easier way is removing the Cmos coin shaped battery from motherboar for few seconds, and put it back, this will reset Cmos the same .
Oct 05, 2008 | Toshiba Satellite A135-S4527 Notebook
Hi - Benimur
Hi again,
If your motherboard is for a desktop, there would often be a 3 terminal jumper very near the Lithium battery marked CMOS Reset. A jumper is currently positioned shorting one end and the center, temporarily removing this jumper and moving it to the opposite end/pair would reset the CMOS/BIOS. Alternately, you can also remove the 3.0Volts coin size battery for about 30 minutes wold reset the CMOS/BIOS.
Cheers.
Aug 18, 2008 | Intel Motherboard
Fujitsu M1010 Sub-Notebook Logo
21 people viewed this question
Top Fujitsu Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Fujitsu Audio Player and Recorder Expert? Answer questions, earn points and help others
