Question about Merits Health S131HD Pioneer-3 Heavy Duty Mid Electric Scooter
Flashing green light merits pioneer 3
My pioneer 3 ligh flashes 5 or six times when you turn it on
My dad has a merits 4 wheel pioneer that flashes 5 times what fault code is this
This flash error code for the dynamic controller indicates a park brake fault. Try moving the brake lever back and forth in each direction to clear the fault. You may have a faulty brake or brake microswitch. You can test the brake with a voltmeter. It should read 40 to 60 ohms and not shorted or open. You can test the microswitch by pushing it and checking for switch closure using a voltmeter. You need to turn the scooter on and off to clear the last fault. Hope this helps.
Mar 08, 2016 | Electric Mobility Merits Pioneer 3 Hd ...
Where is a wiring schematic for a Merits Pioneer 3 S 131 3 wheeled scooter?
You can call Tech support at Merits 800-963-7487. owners manual may have where the fuses would be. Lights could be burnt out. more likely the wires were disconnected.
Feb 10, 2016 | Electric Mobility Merits Pioneer 3 Hd ...
I have a merits s131
Put the unit in drive mode (engage the brake) and try again. If one way doesnt work, try the other way. If this doesnt work you may have a faulty brake switch or brake wiring. Replace both and try again.
Jul 30, 2014 | Electric Mobility Merits Pioneer 3 Hd ...
I have a pioneer pdp-r05XE, on the plasma, the light flashes green and red alternately whilst on the receiver it flashes green 6 times. I can't get the tv to turn on...
Unplug if you have not done so BOTH units from power for several minutes (any cable or satellite box also connected.
wait several minutes and restore power to all units which may allow them to reboot.
Cannot hurt and may help.
Dec 06, 2012 | Televison & Video
My tv wont turn on ,It seem it is going to turn on and close itself
Searching for tv turns off but will turn right back?
  • Service Manual of KV-32XBR400 shows error info regarding red light flash 2, 3, 4, 5, 6, & 7 times only. Each flash corresponds to different problem in TV. Please check red lighe flash count again.
Nov 26, 2012 | Sony FD Trinitron WEGA KV-29LS35 29" TV
When i on my sony wega tv green light flash then turn on red ligh and flash 3 times
Most Sony (not all) 3 blinks is lamp door not properly closed.
It means that but not really: On some models it means the door has become warped from heat--I can tell you a easy way to prove if this is your problem.
Front shield has to be on these removed (outer one the covers lamp door)
Let me know and I would be happy to explain further.
Mar 19, 2012 | Televison & Video
Merits DL 52 i electric wheel chair, all leds flash 3 times as a error code. Battery is fully charged, then turn on wheelchair. All led are on. then when the joy stick is pushed, all leds flash 3 times...
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Jul 15, 2010 | Health & Beauty
Monitor on switch goes onto green for 3 seconds and then turns to a flashing red, which flashes 5 times quickly,and repeats every few seconds. model is pioneer plasma display system noPDP503HDE
Thats a Factory shut down .... caused by a fault usually the power supply
Sorry it's a factory repair issue
make sure all the connections are tight
and try one more time .... sorry
LB
Sep 19, 2008 | Pioneer PureVision PDP-503HDE 50 in....
Tv turns off but will turn right back on
Aug 10, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Merits Health S131HD Pioneer-3 Heavy Duty Mid Electric Scooter Logo
44 people viewed this question
Top Merits Health & Beauty Experts
Ngoro
Ngoro
Robin Hill
Robin Hill
Are you a Merits Health and Beauty Expert? Answer questions, earn points and help others
