Question about Baby Care
Dr brown bottle warmer
It does not work correctly
What does code E1 on dr browns bottle warmer mean?
I don't know what it means, but I found that unplugging the warmer, waiting a few seconds, and then plugging it back in fixed the issue. I don't know if it'll do it every time, but it worked this time. :)
Aug 02, 2014 | Dr Browns Brown Deluxe Bottle Warmer...
Is it possible to use Aveda or other brands' bottles in this sterilizer?
The instruction manual recommends not using any other bottles, other than the ones included in the kit, with this product. This is because they can't guarentee that they will be sterilized.
Feb 16, 2014 | Handi-Craft Co Dr. Browns Natural Flow...
Bottle warmer
Hi
We recommend you contact Tomy for advice http://www.tomy.co.uk/
Jan 16, 2012 | First Years Quick Serve Bottle Warmer
Lost instructions Philips AVENT Digital Bottle Warmer
You can download the manual here:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SCF260/32&scy=tr&slg=en
Oct 04, 2010 | Avent Philips iQ Bottle Warmer without...
How do you clean the baby pro bottle warmer?
Ice container, measuring containers, and baskets: Dishwasher-safe (top rack only).
Measuring containers should be placed in a dishwasher basket. Or wash in warm water
using mild liquid soap. Rinse with clear water.
Bottle Warmer unit and removable cooler: Always turn OFF and unplug before cleaning.
Wipe surface of unit as well as inside of cooler and cooler lid, and inside of warming
chamber with a damp cloth or sponge using mild liquid soap. Wipe with clear water. Air dry.
Do not immerse in water. Do not use scouring pads, solvents, or abrasive cleaners, as
these could damage the unit.
Warming chamber (optional): Mineral deposits (usually white in color) may form on the
inner surfaces of the warming chamber and can cause damage to the unit. To remove them:
1. Unplug the unit.
2. Remove the basket, and wash separately as indicated above.
3. Pour 2 oz. vinegar into the warming chamber and let it stand for an hour or two (longer if
necessary).
4. Pour out the vinegar and rinse the chamber two or three times by pouring in, then
emptying out, 3 or 4 oz. of plain tap water. Do not immerse the Bottle Warmer in water.
Wipe dry or air dry.
Aug 21, 2010 | Avent Philips iQ Bottle Warmer without...
Welli just bought an avent bottle warmer online and instructions didnt come so i turned it on an put it on bottle and the amount of oz and it dint warn any so could u tell me how to use it or how it works?
turn on,select where bottle came from,room temp/fridge/freezer by pressing power button.
Press size button to amount of water/milk in bottle,when at right level hold button in,unit will bleep
May 21, 2010 | Toys
HOW TO DE SCALE THE Philips AVENT Digital Bottle
Mix one sachet of citric acid* (10g) with 200ml/7oz of water. Pour solution into the
empty warmer. DO NOT place a bottle, jar or cup into the warmer when de-scaling.
Close the lid of the warmer and programme the warmer to run with 310ml/11oz of
milk from frozen. After the warming cycle has ended, leave the solution to cool for
30 minutes before emptying the warmer and rinsing with tap water. Wipe the inside
and outside of the warmer with a damp cloth only.
OR:
Pour 100ml/3.5oz of vinegar mixed with 200ml/7oz of cold water into the warmer.
Allow liquid to stand in the unit until any limescale has dissolved. DO NOT place a
bottle, jar or cup into the warmer when de-scaling. DO NOT start the warming cycle.
Empty the unit and rinse thoroughly. Wipe the inside and outside of the warmer with
a damp cloth only.
Jan 30, 2010 | Avent Philips iQ Bottle Warmer without...
Baby Care Logo
111 people viewed this question
Top Baby Care Experts
masud
masud
Tom Chichester
Bill Boyd
Are you a Baby Care Expert? Answer questions, earn points and help others
