Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
F5 error code on kenmore gas range model number 911.7358810
fridgetech
  • 473 Answers
SOURCE: I have Error Code E1 F5
This code means the control has detected a problem with the door latch switch. Switch is defective and needs replaced. Part # is W10107820 and cost is $39.99. You can get it at http://www3.sears.com/.
Posted on Nov 09, 2007
  • 172 Answers
SOURCE: f5 code on a kenmore range
Hi mrscottd,
The f5 indicates a loss of the relay drive circuit. To correct you can turn the power off to the range at the breaker box and wait about 10 minutes, then turn back on. This will reset the board. If the error returns you will need to replace the electronic range control (ERC). The part number for the control is # 338692 price $338.49 at Sears or My price $299.99 delivered. Good luck to you and please dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Posted on Oct 30, 2008
57 varieties
  • 1653 Answers
SOURCE: I have kenmore elite gas range 790 series getting
The F93 shows that the Maximum oven door lock time has been exceeded.
Turn off the range and turn off the AC power and wait for up to 10 mins. The door should reopen. Turn on the AC power ans see if the error persists. If it does then check the following.
1. Check the wiring between EOC & Lock Motor Micro Switch.
2. Replace the Motor Door Latch assembly if necessary.
3. Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. Lock Motor continuosly runs - if Micro Switch is open, replace Lock Motor Assembly.
6. Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
Posted on Nov 12, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Kenmore elite range, model 970-698593, Error Code E015
Just asking if your model number is correct. I do not find 970 models but do find 790 models. If it is a 790 model there can be aproblem with the door lock on the oven door. You may want to check to see if all the shipping materials have been removed from the door lock / latching area. I would recommend that you review the installation instructions in the owners manual, paying particular attention to the removal of shipping materials.
Adittionally if the problem presists it says to replace the Electronic Range Control (ERC) This is not a cheap part! Good thing it will be at their expense including the repair service call..
Hopefully you have already called for warranty service? We both know a brand new oven should not be producing any error codes. If you have not called for warranty service you do so now. Make sure to tell them that you already have talked to customer support and that unplugging the unit for ANY period of time made no difference in the error code.
Thanks for choosing FixYa.
Kelly
Posted on Aug 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: We used the self cleaning option on our Kenmore
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
Error codes kenmore range
What is the model number?
Feb 22, 2013 | Kenmore Kitchen Ranges
My Kenmore Range Model #95014 is displaying an E1 F5 error and will NOT unlock!
This error code has to do with the oven door lock assembly.
What is the complete model number listed on the unit? Look in the door area or the storage area on the bottom if you have one.
Dec 08, 2012 | Kenmore 95012 / 95014 Electric Kitchen...
Kenmore model 790.96113403 F5 error code
it means that your oven is showing a restart code
Jun 13, 2012 | Kenmore 99123 Electric Kitchen Range
Kenmore model 911.95875790 code f5
The Kenmore 911 series ranges are built buy Whirlpool. An F5 error indicates an oven control error (clock or ERC). Sears Parts Direct lists this as part 16 here: http://parts.sears.com/partsdirect/part-model/Kenmore-Parts/Range-Parts/Model-91195875790/0582/0124111/10052061/00001 . The part is listed as in stock for $171.99. If you had a 4 character trouble code, additional diagnostics could be done to locate the problem.
I hope this helps.
Nov 18, 2011 | Kenmore Kitchen Ranges
My kitchen aid gas range display F5:E3 and contact touch board has no function
Hi
Error code F5-E3 indicates that there is an issue with the door latch switch assembly; if the switch tests open then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
My kenmore oven 911.30465 is giving error code F5. What does this mean?
Jul 22, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
We used the self cleaning option on our Kenmore Gas Range (model number 665.72004101 or 665.75004101) and now the oven door remains locked and the error message on the screen is e1 - f5. How do we unlock...
Dec 27, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
F5 code on a kenmore range
Hi mrscottd,
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 01, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore gas range 82772735
Check that door switch is completely closed. Check latch, solenoid, and actuation switch for electrical or mechanical malfunction. One of these is the reason for the E1, F5 code.
Dec 21, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Oven door will not unlock
morobie The error code "F5 E1" means "Door latch not operating". To help you better I need the complete model number for you range. You can find it on the frame behind the storage drawer. Gendos...post back
Jan 30, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
49 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
