Question about Casio Classpad 330 Graphic Calculator Classpad330
Complex Calculation Not Working
I've updated the os from 3.03 to 3.06 and since then,it does not perform complex calculations. After entering any Equation,it just shows the same Equation as the answer. Any idea?!!
    Top Expert:
  • Casio Master
  • 42,740 Answers
You may need a new driver for the updated version. try an on line updated driver
Posted on Jul 29, 2013
  • 1 more comment
  • Farokh Kaardan Aug 01, 2013
    tnx for the respond.
    Add a CommentI
    I updated the os. to ver. 3.0.6.2000 and the problem is fixed.Do you any sites where I could download some Lang. packs,add-ins or e-activity or other stuff such as games?
5 Suggested Answers
  • 7993 Answers
SOURCE: In complex number mode, how to get out?
"Is there anything that I can do about this to stop my answers being complex numbers when solving cubic equations?"
You are making an assumption that is unwarranted.Namely that a cubic equation must necessarily have 3 real roots. This is not the case.
Let your equation be
If coefficients are complex you should expect some complex roots. Right?
If the coefficients are REAL then depending on the discriminant
you can have three cases
DELTA positive : three distinct real roots
DELTA=0 , the equation has a multiple root and all roots are REAL
DELTA negative: the equation has ONE real root and 2 complex roots that are complex conjugate of each other.
It suffices to look at the Tartaglia/Cardano expressions of the roots to know that more often than not there is going to be complex roots.
Posted on Jul 25, 2010
  • 7993 Answers
SOURCE: Edit Casio FX - 9860G SD have complex equations??
Thhe Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Apparently it will take coefficients that are real, and will give a Ma Error if any coefficient is complex.
Addendum.
The calculator CANNOT solve equations with complex coefficient. YOU can however convert the system of linear equations with ccomplex coefficients ( of the type you show) as a system of 4 linear equations in 4 unknowns; Split x into a real and an imaginary part, split y into a real and an imaginary part. Substitute Real(x)+iIm(x) for variable x in the equations; substitute Real(y)+iIm(y) for y in the two equations; do the algebra. In each of the original equations split the Real and imaginary parts. You should be able to derive 4 linear equations in unknowns Real(x), Im(x), Real(y), and Im(y).
Use the linear equation solver to obtain the solutions. Recompose x=Real(x)+iIm(x), and y=Real(y)+iIm(y)
Alternatively, after you create the system of 4 linear equations you can use the matrix utility to find Real(x), Im(x), Real(y) and Im(y) and recompose the x and y.
Posted on Mar 18, 2012
  • 7993 Answers
SOURCE: Casio FX - 9860G SD have complex equations?? edit
The Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Addendum.
ali_rezaali7
SOURCE: use of scientific calculator fx-82ES solving complex equation directly.How?
upgrade it into fx-570es http://www.youtube.com/watch?v=52YSOGcBMFI
Posted on Jun 11, 2012
How to add function for complex number calculation on my casio fx 82 ms...anyone help
The calculator cannot perform any calculation on complex numbers. Sorry.
Aug 22, 2016 | Casio FX82MS Scientific Calculator
How to perform operations on complex number in bistec BS-991MS calculator?
Put the calculator in complex Mode. Enter a complex number and press the key for the operation you want to perform, + for addition etc.
Oct 14, 2015 | Office Equipment & Supplies
Complex number
Try entering on the same command line your calculation followed by the ToFrac command. That should work. Here is a screen capture from a TI83Plus in complex mode (a+ib).
Aug 26, 2013 | Texas Instruments TI-84 Plus Calculator
Complex matrix
Please consult your calculator's manual. You will find out that it does not perform complex number calculations nor matrix calculations. Thus there is no way to do complex matrix calculations.
Aug 24, 2013 | Casio fx-300ES Calculator
How do you convert decimal complex numbers in TI-84 (OS 2.53) to fractions?
I answered a similar question not long ago and here is what I wrote:
Not quite true for OS 2.56 MP for the TINspire with Ti84 keyboard. To convert a complex decimal value, that you just calculated, into a fraction use the command Math [1:>Frac] and it will convert the value to complex fractions
See below.
I suggest you upgrade the OS to version 2.55 MP.
Mar 06, 2012 | Texas Instruments TI-84 Plus Silver...
How can i enter a polar form number with angle to convert into a complex numbe(a+bi)
Set the calculator to polar form, then simply enter the radius, press the comma key, then enter the angle (in whatever angular mode you've specified).
Full details are in Chapter 2 of the manual you can download from here.
Oct 25, 2011 | Office Equipment & Supplies
When trying to divide two complex numbers in a+bi format, some of my students get the Data Type error message. I don't know why or how to help them. Can you help? Each complex number was enclosed in...
Here is screen capture of a similar calculation, performed on TI Nspire with TI 84 plus keyboard.To type in the imaginary unit use key sequence [2nd][dot], do not use [ALPHA][X^2] for the letter i.
Jun 08, 2011 | Texas Instruments TI-84 Plus Calculator
Find the complex conjugate of(3 5i)/(1 2i)
When you divide (3 5i)/(1 2i) you get (2.6, -.2i) so the complex conjugate would be (2.6, 0.2i). In polar form that is 2.608 at 4.399 degrees. [Calculation done using TI-86] Best Wishes!
Mar 31, 2011 | ABA English Facebook Apps
MS-80TV AUTOMATICALLY ROUNDS UP TO 1 DECIMAL DIGIT
The [MODE] key can be used to select the modes described below.
Important! The following is a general explanation of Scientific Calculator modes. Note that your calculator may not include all of the modes described here.
1) Calculation Modes
Before performing a calculation, you first need to select the appropriate calculation mode.
COMP: Basic arithmetric calculations
(arithmetic operations, trigonometric functions, etc.)
COMPLEX: Complex number calculations
SD: Single-variable statistical calculations
(sample standard deviation, etc.)
LR or REG: Paired-variable statistical calculations
(linear regression statistical calculations, etc.)
BASE or BASE-n: Binary, octal, decimal, hexadecimal number system calculations
MAT: Matrix calculations (determinants, etc.)
VCT: Vector calculations
EQU: nth degree equations, simultaneous equations
2) Display Settings
Use these settings to control how calculation results are displayed.
Note that changing the Fix and Sci settings does not affect internal calculation results.
Norm: Exponential display format and cancels the currently configured Fix and Sci settings.
Fix: Specifies a fixed number of digits to the right of the decimal place.
Sci: Specifies a fixed number of significant digits.
3) Angle Unit Setting
(90°=?/2 radians=100 grads)
Deg: Degrees
Rad: Radians
Gra: Grads
4) Engineering Mode
Use this mode when you want to input and perform calculations using engineering symbols.
Please rate this response . .
Sep 08, 2009 | Casio MS-80TV Scientific Calculator
Calculation with angle
You perform all calculations in complex mode. When you need to convert to angle amplitude, in the [RUN] screen press [OPTN][F3:CMPLX]
To obtain the angle press [Arg] ( complex number) [EXE]
To obtain the magnitude, amplitude press [Abs] (complex number) [EXE].
Since the [ANS] memory keeps only the last value calculated, you may have to store your result (the complex number) in a variable.
1+ 1 i [white right arrow under tan key to store] [ALPHA] H
Display shows 1+1i. Then
[Abs] [ALPHA] H [EXE] gives 1.414213562
[Arg] [ALPHA] H [EXE] gives 45
Hope it helps.
May 22, 2009 | Casio CFX 9850GB Plus Calculator
Casio Classpad 330 Graphic Calculator Classpad330 Logo
50 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
