Question about Electrical Supplies
Gt 1200c generator
Won't start. Looks like there's no spark even if I change the spark plug. Any suggestions? Typical causes?
  • 83 Answers
SOURCE: My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
Posted on Mar 30, 2009
  • 3 Answers
SOURCE: want schematic for gt 1200c petrol generator
Here is a link for the manual....printed on glossy paper, so difficult to scan.
http://rapidshare.com/files/285883408/GT-1200C_Manual.pdf.html
Good luck,
f.
Posted on Sep 28, 2009
  • 342 Answers
SOURCE: Generator won't start. Seems to
have you had the generator stored with fuel in the carburettor since its last use if so the fuel goes bad and blocks up the main jet, remove the float bowl and clean out all the residue you can clean out the main jet with a suitable piece of wire
Posted on May 30, 2011
  • 1388 Answers
SOURCE: I have a 3250 watt Kingcraft generator that won't
Always troubleshoot with new sparkplug. Remove the oil sending unit connection from the coil. The coil should work without any wires connected. Usually the only connections are oil sending unit that will short to ground when low oil condition and other wire must be kill wire to on/off switch. Use carb cleaner spray directly into the carb with air filter removed and choke off as fuel supply. Just a short spray and another short spray after a couple of pulls. If engine wants to start you will need to keep spraying cleaner for engine to continue to run. If engine wants to run, replace fuel with couple gallons of premium fuel to get it going. Hotter fuel will help if the compression is low. Good luck
Posted on Aug 24, 2011
Mr BrokRench
  • 1623 Answers
SOURCE: Our Honda EB 3500 generator
It's either not getting enough fuel, or the govenor is not working. When the engine is running, watch the throttle linkage between the carburetor and engine, looks like a bent wire. When you throw a load on it, it should move to give the engine more power, if it dont, try moving it by hand.
If that appears to be working ok, check the fuel line from the tank to the carb for good gas flow.
You can also remove the float bowl on the bottom of the carb, it's a round bowl on the bottom of the carb with a bolt in the middle of it...clean it out and check the float. The float looks like a little catamaran, make sure it is moving freely up and down. That is about all you can do without removing and cleaning the jets in the carb.
Good luck, & i hope this helps.
Posted on Aug 27, 2011
Pontiac grand prix 99 won't start no spark at the spark plugs no link on the scan tool when plug to the dlc what can be the problem
I hope my suggestions can help you ,first ,you can check the storage of battery and the engine ,if there is no power to use , second , check if the power is connected well .
Apr 20, 2013 | 1999 Pontiac Grand Prix GT
Husky generator won't start
did you try cleaning the conductor that goes to the spark plug if not try to clean it with a real fine sand paper it should do the job.
Oct 27, 2012 | Husky Portable generator
Onan 5500 marque gold turns over but, won't start. fault code is 32 but, batteries ok, air cleaner ok, fuel pumping, oil changed, won't start
Code 32 is a low cranking speed sense. You didn't mention a Spec # which would help. You say batteries are ok, but the generator is not getting enough cranking amps or voltage to maintain the control properly. Check, battery voltage, wiring, any in line isolation solenoids, check generator solenoid, also make sure there is no mechanical binding on the generator, a good way to do that is remove the spark plugs DISCONNECT THE BATTERY to prevent starting, underneath where the air intake is under the alternator is a plastic plug, remove that and you can put a socket I believe 3/4" up onto the alternator shaft and rotate the engine, if it tuns freely there is no binding, if you feel it is hard to move, check the drive train, belts, pulleys underneath (A lot of work, best to take to a dealer if it is mechanically bound)
Sep 13, 2012 | Onan Marquis Gold Quiet Gas Generator 5500...
1993 grand voyager won't start
anti theft malfunction. seriously put your ear near the filler neck uncapped and have someone turn the key. is there s whining. then that rules out a bad fuel pump> try carefully priming the injectors with fuel and then crank. standby with a garden hose in the even it backfires and pukes out the fuel. remove a plug wire and put any plug in the boot rest it against the valve cover have someone cranlk and looks for spark. 2 main causes for no start lack of fuel, lack of spark
Sep 04, 2012 | 1993 Plymouth Grand Voyager
Why won't my Homelite 720 watt Generator start?
hi am elie hawzi i have generator 720wat homeliet had to run wer can i put 2 storc oil in my generator pleas do you have any adia haw can i leave the generator run stridaway thanks for fixya
Jun 28, 2012 | Electrical Supplies
97 gmc jimmy cranks but won't start, have replaced everything possible but still won't start, most of the time the brake lights won't work, or the gauges goes crazy. I have changed relays,...
There are two basic reasons for not starting - no spark or no fuel, both of which are controlled by the ECM. You need to check error codes and these items - for the spark, test it at the cylinder 1 sparkplug; for the fuel check the pressure (if too high or low, problem!).
Aug 28, 2017 | 1997 GMC Jimmy
How do you change the spark plug on a Coleman Powermate 5000 10P Generator? It has been sitting for about eight years since last use and won't start. Would like to change the spark plug, but it seems...
The plug is under the gas tank. They can be difficult to get to and you may have to remove/loosen the tank. If you can remove the spark plug wire you could test for spark. If you have a spark and it still doesn't crank the spark plug is probably the least of your worries unless you drained the tank and the carb (most people don't.)
If you have a spark give a spritz of starter fluid into the carb after removing the air filter and see if it runs for even a bit. If it does fire and doesn't run, clean the carb.
Good luck.
Jan 07, 2018 | Coleman Powermate Powermate 5000W...
Missing Manual
Here is a link for the manual....Sorry for the quality, it's printed on glossy paper, and difficult to scan properly.
Click on Free User, wait the few seconds, and then click on the download button.
Good luck,
fields
Aug 23, 2009 | Eastern Tools And Equipment 1200 Watt...
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
