Frigidaire gltf1240aso manual - Washing Machines
FPBM189KFC MANUAL
Most Frigidaire manuals are available through their support site: http://www.frigidaire.com/Owner-Center/Product-Support-FAQs/ . Enter the model number in the search box and press enter.
The direct link to the owner's manual in English for the FPCM189KFC is http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316902454en.pdf . An installation manual and wiring diagram are also available from Frigidaire.
I hope this helps.
Aug 09, 2017 | Frigidaire Microwave Ovens
I am trying to locate an owners manual for a Frigidaire Dishwasher model # FGHD2433KW1
Below is the link, you can download it
http://www.manualslib.com/products/Frigidaire-Fghd2433kw1-2885301.html
Dec 05, 2015 | Frigidaire Dishwashers
Frigidaire front load washer model GLTF1240ASO makes a loud noise durring spin cycle
Most likely the drum bearings are gone, especially if you have some play. You need a bearing and seal kit which is fairly inexpensive but it is a pretty big job. The entire inner drum must come out so it requires the disassembly of quite a bit of the machine.
Jul 09, 2013 | Washing Machines
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
Lost manual for Frigidaire gallery gas oven. need to know how to use convection baking
What model Frigidaire oven do you have? Most Frigidaire manuals are available from the manufacturer's site: http://b2b.frigidaire.com/support/manuals.asp or http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/ . Note: these manuals are in the PDF format; you will need Adobe Reader or a similar program to read them.
For example the User's manual for the FGGF3054MW range (with convection oven) is available at http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316901218en.pdf .
I hope this helps.
Apr 13, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Extra long rinse cycle for gltf1240aso
Sounds like a bad water valve or the timer is not communicating correctly for each cycle. Contact a professional.
Aug 28, 2012 | Frigidaire ATF6000ES Front Load Washer
FRIGDAIRE WASHER FRONT LOAD MODEL#GLTF1240ASO DOES NOT GO TO HIGH SPIN . A CHECKED DRAIN PUMP REPLACED DOOR SWITCH AND REPLACED SPEED CONTROL CHECKED BELT
Hi, are you sure your pump is operating properly any little thing caught in the impeller will stop these pumps. You also say there water still in the tub it will definitely not spin fast with water in the tub. Remove the pump and inspect the impeller sometimes there are things caught in it and other times the vanes are broken right off.
Apr 21, 2011 | Washing Machines
My GLTF1240ASO has an amplified noise level when spinning? The Drum does have some more than normal back & forth movement as well.
That could either mean that you need new bearings or the spider arms the part that holds the washer tub are broken. It can be very expensive to repair. Get a few estimates before deciding whether to fix or replace.
Jan 07, 2011 | Frigidaire GLTF2940ES Front Load Washer
Our Frididaire GLTF1240ASO washer will not spin or empty the water. We had this happen once before and a technician came in to fix it. It seemed like something simple that he said this model is known...
Hi, He probaly found it in the pump. THere should be two screws holding the front panel on. Then you neeed a screwdrive to pop the top up by releasing the clips located in the crease between the top and the front panel. Once the top is raised, the front panel drops down and then you can move it out of the way. There is an electric style pump on your model sobe sure and UNPLUG the machine before you start working on it.
Remove the hoses from the pump and you might find something plugging it. If there is nothing in it, You can test to see if there is 120V going to the pump. Also check the drain hoses since you are this far.
Hope this helps you. Please let me know if you need more help.
Thanks
Vic
May 11, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
