Goodmans GD11FVRSD32/GD11FVRSD50 not recording everything it's programmed to.
Goodmans GD11FVRSD32/GD11FVRSD50 has stopped recording two episodes of the same series out of five every week. It has been set up to record this programme since I bought the box in Sept 2012 but the last month or so it's missing two every week.
SOURCE: Problem connecting Samsung DVD-HR737 DVD recorder to Set Top Box
I had the same problem, if you go through the channels from your DVD-R remote it should give you the option AV-1 and then AV-2 ? on mine it's AV1 (test it out first and you have to watch what your recording) then it should record from the cable box
worth a try?
Posted on Aug 24, 2008
SOURCE: LG DR 165 DVD Recorder problem
hi , how are u friend
i have problem pls can y help me
lg dr4810 afiche in lcd (please wiat )
Posted on Sep 30, 2008
SOURCE: I have purchased a Teac HDR2500T video recorder. I
The part re the other channels having no signal....I had the same problem with mine and that was because the small loop cable in the back wasnt right. I could watch all channels, press record and still watch that channel but try to watch a diff channel while its recording and they were gone. As soon as I had the loop cable in properly it solved the problem. Hope this helps....
Posted on Sep 06, 2009
SOURCE: Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Posted on Apr 18, 2010
SOURCE: Stop Substitles on a LG RHT497H 160G dvd recorder?
I have the LG DVD recorder DRT389H which has the same problem. You can't switch off the subtitles during timer recording from the Electronic Programme Guide. The only way I could stop this was to go to the main set-up menu then select the A icon. Select DTV Subtitle and choose a language that the TV programme isn't broadcast in. I chose Gaelic. The only disadvantage is that this stops any subtitles being recorded so you can't access them later.
Posted on Jun 13, 2010
Planned recordings dissapear library ok also series does not work
How about some more info.
All recordings, or just some? Planned?
Most DVRs default to look for the program on the channel you found it when you initiated recording, so if you initiated a recording for Law And Order SVU from USA but asked for only new episodes, since new episodes show on NBC, you won't get any. So make sure you are setting up a recording from the channel you want to record it from, in the format you want to record it (New, reruns, all, HD, SD, etc.)
Depending on your service and receiver, signal quality may also be stopping your recordings. For instance, you have DirecTv and you never have service when it rains, it also just happens to rain in your town whenever Modern Family airs. Just your luck.
And, it could be that you are trying to record a show that is an OnDemand or streaming only show, like Orange is the New Black (on Netflix). Waiting around for an episode to air will never happen because they are an On Demand service.
Dec 16, 2016 | Televison & Video
My Father has a Goodmans GD11FVRSD32 freeview recorder and media initialising stays on the screen permanently. meaning he cannot access library or record any programmes
hi ya
this is almost certainly a hard drive failure - and probably lost all the stuff recorded on it,
its very common issue and if its out of warranty may as well go for a new one, manhatten are fairly good for the money and use AV class harddrive which a designed for continual use,
however you can swap the harddrive out for a new one cheaply it should be s 2.5 sata drive of 320 or 500gb, these willbe about £25 quid
and its easy to swap out but always do it with the power off
May 20, 2015 | Televison & Video
GD11FVRSD32
2906,2901,2907. Try these codes. If you wish to get more codes and other details,
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 26, 2013 | Televison & Video
How do you delete a program that is mistakenly added to the record every episode mode
The easiest way I know is to press menu, then daily schedule. Find the program in question in your list. Click on that program and you will se a window "timers", click on that and you will see "delete", click on that. then you can reset your program to record the way you want. You can also follow the same proceedure, click menu, then daily schedule, then click on "timers". Scroll to the timer you want to delete, click on it, then click on delete.
May 02, 2011 | DISH Network ViP622 DVR DTV Receiver /...
Grundig GUFSDTR500HD FreeSat PVR Problem
Hi There, I've never had this problem with my Sky box, it knows which programs are repeats. I suspect its a problem with the GUFSDTR500HD. I have had two of these boxes from Costco, and both have both been as buggy as hell. They have recorded random programmes, they have missed recording programs, they often crash (black screen), series link seems to get it's knickers in a twist, and the up and down directional buttons fail to work after coming out of the guide or menu screen. To top it off, I found that the remote control also interferres with my B&Q fireplace... cycling through the colours when I change channel. Both of these boxes have gone back to Costco and I will never touch another Harvard Group (previously Alba, including Bush/Goodmans/Grundig) box again. Back to sky HD for me!
Feb 24, 2010 | Televison & Video
Dvr is programmed but at times "chooses" not to record show and other times it does record
Be sure that a DVR timer is set to fire, instead of an auto tune. Also if it is a series then make sure you select new episodes, your dvr will not recor a program if it has already recorded the same program once, ( re run) you can also check your scehdule in your dvr to check if timer has been deleted or modified.
Nov 13, 2009 | DISH Network DVR 510 DTV Receiver /...
We have our timers set to record only new episodes but it trys to record old ones all the time. They say clearly "original air date ___". (there are no actual blanks fill in whatever date there). Also we...
when you select "new episodes" it will record ALL episoded that have not been recorded already. ALL episoded will record every time the show comes on. as far as then 134 hr recording, it sounds like a manual timer error i would erase it and monitor progress to see if it does it again.
Sep 23, 2009 | DISH Network ViP 612
Panasonic DMR E55 Won't record AT&T U-Verse programs!
Make sure you only use the correct type of discs: DVD-RAM or DVD-R for recording and DVD-RAM, DVD-R, DVD-Video, DVD-Audio, Video CD, CD-Audio (CD-DA) and CD-R/RW (MP3, CD-DA, Video CD formatted discs) for playback.
DVD-RAM disks are in plentiful supply on eBay, both new and used. Keep an eye open and you should pick them up, new, for less than £1 Sterling each!
I am unclear, though, what you mean about recording to and from the VCR. The DMR-E55 doesn't have a VCR facility, just DVD.
Jan 26, 2009 | Panasonic DMR-E55 DVD Recorder
After recording a one hour episode, won't recognize the dvd.
Try inserting your DVD media into the PC and doing a 'quick format'. The LG is not seeing what it considers to be media that it can use. It is not seeing that you have inserted recordable media. Sometimes you can reformat the DVD or do a quick media erase, and the LG can then put on its blank "squares" that is uses for its menu selection. I think that it what it does when it 'initializes' a new media.
tom
Apr 23, 2008 | LG DR787T DVD Recorder
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
