031 528 Was able to scan, but now I can't. Anyone have a fix for Windows 7 that actually works? I have a Dell 2135cn mfp.
SOURCE: dell laser mfp 1815 dn "scanner locked" message
When you lift the scanner lid look to the left bottom. you should see a green slider button. If you stick your hand in the output tray and get it rigth under the green slider you will find a lever. Move that thing backwards or forwards, that is your unlocker.
Posted on Jul 20, 2009
vanherringto
  • 1738 Answers
SOURCE: WILL NOT WORK IN WINDOWS 7
There is a new download for windows 7 users.
Click this link to run programs in Windows XP compatibility mode in Windows 7.
http://www.microsoft.com/windows/virtual-pc/download.aspx
Posted on Feb 08, 2010
SOURCE: Xerox 6180 MFP N error 016-782 Windows 7 x64
did you get a solution to this problem. i have the exact same situation.
Posted on Feb 28, 2010
alpug
  • 1961 Answers
SOURCE: When I used the document
Clean the scanner bed glass, as well as the ADF platen glass using a lint-free cloth and a glass cleaner.
That will fix it.
Posted on Dec 19, 2010
  • 628 Answers
SOURCE: I am having print quality issues on a Dell 2135cn
Try removing the toner cartridge and gently rotating it back and forth. Often the toner will bunch up like a snow drift and where there is little toner you'll have light or no print. If that doesn't do the trick try another toner cartridge.
Posted on Feb 18, 2011
Can I print wirelessly from my Sony windows 10 laptop to my Dell 2135cn printer?
Yes. Dell has made available both 32 bit and 64 bit Windows 10 drivers for this device so it should work on you Sony. This printer is network enable but it is wired, not wireless so you will have to connect it to your network with a ethernet cable.
Here are the drivers:
Support for Dell 2135cn Color Laser Printer Change product
Here is the manual:
http://downloads.dell.com/manuals/all-products/esuprt_printers_main/esuprt_printers/dell-2135cn_user%27s%20guide_en-us.pdf
Jan 03, 2017 | Dell 2135cn All-In-One Laser Printer
Memory full how do i clear
This was actually a common problem that was occurring on this model. Dell released a new driver to correct the issue (the link is below). Hopefully that will work for you, if not let me know - I believe there was another work around, but I'll have to dig it up.
May 04, 2011 | Dell 2135cn All-In-One Laser Printer
How does one lower the scan resolution on the Dell 2135cn? Currently, a document of twenty - or so - pages, saves to a pdf file of ten-plus megabytes. Far too large to attach to email.
You need to adjust the resolution in the software. Are you using the Dell software and PaperPort or another application?
This will be easiest to do when you launch the scan from the computer. If you have the TWAIN driver loaded, load the document to scan in the ADF and open Paperport. Click FileScan and the available scanners list should open. Choose your scanner (otherwise click the Select button on the left side of the window). Then click OK. Click on the Scanner Display dialog box on the left of the window. Click on Preview. Then adjust the resolution by clicking on the Image Quality tab.
If the document contains is only a series of picture or you have the WIA driver loaded, then use Paint or PhotoGallery (Vista includes the program, but it is available for XP or Windows 7). Then choose File > Import from Camera or Scanner > From Scanner. Open the Advanced Properties dialog box by clicking on Adjust the Quality of the Scanned picture.
I hope this helps.
(The default resolution is used when you launch a scan from the unit itself. It is possible to adjust it once the software loads but you must use the scan to file option, instead of scan to e-mail. Then attach the resultant file to your e-mail.)
Feb 26, 2011 | Dell 2135cn All-In-One Laser Printer
I am having print quality issues on a Dell 2135cn MFP - print on the left side of the page is light.
Feb 18, 2011 | Dell 2135cn All-In-One Laser Printer
I have a dell all in one 2135cn . and its giving me the erro smb logn error 031-522. how do i fix that?
Make Sure you have the correct IP of the computer you want to scan to and that it is on the same network. Also Make sure on the Login Name field you ONLY have the Login Name of the computer you want to scan to. if login name to computer is "Peter" use only "Peter" and do not add the Domain\Peter. Aldo make sure the are no extra spaces (Like I had) and the Password and Login names are correct. Remember this fields are case sensitive.
Hope this Helps
Sep 15, 2010 | Dell 2135cn All-In-One Laser Printer
Feb 16, 2010 | Xerox Phaser 6180N Laser Printer
Feb 07, 2010 | Xerox Phaser 3100MFP/S Laser Printer
210 people viewed this question
k24674
jasbo
jasbo
