Question about Malber WD1000 Front Load Washer/Dryer
Water leaks (spewing) from sides of bottom of machine when it's filling up
HI there- OUt of nowhere, I wanted to wash some cloths and when it starts to fill up the machine, a lot water spews out from both sides of the machine on the bottome. It is not coming from where you empty out every once ina while the plug but fromthe sides. I have no idea why this is happening and why it just started? What could this be?
  • 78 Answers
The normal cause of leaking while it is filling is a leaking Inlet hose. Try pulling the washing machine away from the wall and watch the hoses as the machine fills. If it is leaking you can see which hose is leaking. You may either need new tighner clips or to replace the hoses depending on how bad they are leaking. Another possibility is the water pump inside the washing machine could be broken and spewing out water.
Posted on Aug 31, 2007
Water leak at bottom of Whirlpool Estate washer. Removed the cabinet. No leaks from the water pump, hoses or inlet valve. The tub leans a little toward the front of the machine. When filling/rinsin
It is common on Whirlpool models for the water to splash out the top when filling especially when sheets or nylon cloth is loaded in the washer. Air fills the cloth and balloons the garment up this caused water to bounce off the garment and splash out the back. This is the most common reason for those mysterious leaks. Lowering the water pressure coming into the washer can help prevent this.
Jan 25, 2015 | Whirlpool Washing Machines
My whirlpool just started leaking from the bottom of machine onto the floor. This happens when the machine is OFF and no clothes in machine. Is it a switch
The drain hose has to be higher than the water level at its highest point. IF there is water coming into the machine when it is not running then you may have a bad water inlet valve. They develop leaks like any faucet or valve. It could be some other things too, like the voltage to the valves is not completely cutting off. There is also some water that stays in those machines because it cannot all be pumped out. What is the model number?
Oct 29, 2017 | Washing Machines
Water leaking at time the washer is being filled, not during wash cycle. Leak appears to be starting a bottom left side of the machine toward the front from the middle of the side. Observation does not...
you say water only leaks when it fills correct? am wondering if its the hose that feeds in to the washer
this would be from the inlet solenoids check the clamps in the machine.
Dec 02, 2009 | Kenmore HE2 Plus Front Load Washer
Kemore Elite Dishwasher Spews Water When Wash Cycle Begins
After further inspection of my dishwasher I found a bad gasket under the lower wash arm. Over the years it finally gave up and was shooting a torrent of water through the water in the bottom of the wash tub. When all that water hit the door liner it went up into the lower door vents, into to wire harness, and onto the floor.
Sep 06, 2009 | Kenmore 24 in. 16352 / 16354 / 16359...
LEAKING FROM BOTTOM
Is it leaking only when it is filling or all the time? If it is only leaking during fill, it could be an air gap device
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
  • If it is leaking all the time it could be the main tub seal. Hope this helped.
    Jul 16, 2009 | Roper RAS6233KQ Top Load Washer
    My washing machine is leaking water everywhere when rinsing
    you are over filling it!!!!!!!!!!!!!!!!!!!! when you use the rinse cycle it just fills the washer up to get all the soap out of the clothes. try just rinsing less clothes then usual. if that is not the problem then on the bottom of your washer is either rusted out or there is a rubber seal that could be over used!
    let me know if that helped at all
    zac
    Apr 20, 2008 | Ariston Technologies AWD121WH
    SMEG Dishwasher - Water fill level is too low
    Hi, I found your problem stuck here from one year ago.
    I will post my solution the same, as reference for you and more users with same problem, apologies.
    Re: smeg dishwasher fails to fill with enough water to sucessfully wash. It does put some water in.. but nowhere near enough.
    Before checking parts inside the machine, ensure that water is coming from the faucet at the back with regular pressure.
    To start check the water level sensor.
    This is usually a floater sensor located on a side inside the dishwasher.
    Check if water level is working properly, if the floater is getting stuck then that is the problem.
    If the water level is OK, then the responsible is usually the inlet valve, or clogged inlet lines.
    From description it looks more like a faulty water level.
    Mar 14, 2008 | Smeg CSU2001 Built-in Dishwasher
    Frigidare front load washing macine leaks water
    Sounds like the dispenser is leaking somehow, there is no filter that would cause it to leak. Remove lid of washer by screws on back lip and inspect during fill to see where leak is.
    Jan 20, 2008 | Washing Machines
    New to this Machine. Unit washes and stops every 25 seconds?
    Have you contacted Malber USA? 516-294-6660. They were helpful with my problem.
    Aug 17, 2007 | Malber WD1000 Front Load Washer/Dryer
    Open Questions:
    See all Malber WD1000 Front Load Washer/Dryer Questions
    Malber WD1000 Front Load Washer/Dryer Logo
    403 people viewed this question
    Top Malber Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Jason Harris
    Jason Harris
    Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
