Have an error on keypad 106 pn Hayward pool pump. Cannot get pump to turn on.
SOURCE: pool pump is very loud
loud pumps are most times caused by bad bearings and need to be replaced or better yet replace the whole pump new bearing cost about $100 to replace but not always easy to find someone to do hope this helps
SOURCE: Hayward Max-Flo pump: Need to separate pump from motor
Remove the back cover from the motor, lock the shaft in place, thread off the impeller.
SOURCE: My pool pump is 2 months old. It is a Hayward 1hp
The capacitor is probably bad. It's under the cover on the side of the motor, Take a look and smell it. A motor shop has them, or Grainger
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: The pump only hums when plugged in. Any suggestions?
It sounds like the impellor is locked. Take this part off and then see if the pump is turning but before you do, some of them have a big screw driver slot in the shaft. If it does, turn it to see if you can free the impellor. I have done this many times and they will continue to work for years after. They just get stuck from rust, etc. and also being frozen a little. Hope this helps.
SOURCE: Hayward pool heater - p5 code
The code is "PS" for Pressure Switch and means there is insufficient pressure to operate (low flow) or the switch itself is bad.
