Question about Garden
Landa PC3-22324S low running pressure
When pressure washer is running and trigger pulled, is just over 500psi, when trigger is released it jumps to the proper psi, 2200. Tried tweaking the unloader to no success, replaced the poppet and spring to no success, any suggestions?
  • 83 Answers
SOURCE: honda pressure washer cuts out when lance trigger released.
You most likely need to set your valve clearances. If it is hard to pull over or the recoil snaps back after starting your valves need to be set for sure. This may not be the entire problem but it is a good start. Also change the spark plug, a bad plug will cause odd problems and is too cheap not to eliminate as a source. In addition check your fuel, pour a little out into a white container (I like spray paint can caps for this) and look at the color. If it is yellow to orange it is bad. You can pour it into you car, the car electronic sensors will compinsate for it quality but a small engine can't. Use a NGK BP6ES or BPR6ES plug.
You need:
Feeler gages
10mm open end wrench
14mm open end wrench
1 long shaft screw driver or rod
1 spark plug socket and ratchet
Remove the spark plug and the valve cover. Pull the recoil over slowly until the intake valve opens (intake is closes to the carb and it will go down when it opens). Now put your long screwdrive down the spark plug hole. Slow pull the engine over until the screwdriver handle is at it highest point, this is top dead center. It may take a few attempts. Now check your valve clearance between the rockers and the top of the valve. The intake should be .006 and the exhaust .008, both can be +/- .001. To adjust: hold the large nut with the 14mm then loosen the small one with the 10mm. Lefty loosey. Now turn your large nut until you get the correct setting and then tighten the small one the lock it in. It may take a few attempts and alway reverify your setting after you lock it down. Once done, find top dead center again and reverify. Now your valves are set.
Posted on Mar 31, 2009
  • 12 Answers
SOURCE: Pressure is fine when first started ,if trigger released no Psi
Your uplift injector valve in the water pump is sticking. You need to remove this part. Lube the top o-ring only with a water proof grease. Reinstall this part. You will be up and running again.
You need to use needle nose vise grip tool to easily remove the valve. You need to grind down the vise grip tool to fit the opening where the valve is installed.
To prevent this problem from reoccuring use a pump guard additive.
Posted on Apr 06, 2009
  • 10 Answers
SOURCE: pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Posted on Apr 20, 2009
  • 174 Answers
SOURCE: How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Posted on Aug 26, 2009
  • 251 Answers
SOURCE: We have a Karcher G2500VH pressure washer. If you
Hi, Karcher calls the unloader valve a spill valve,
this is a link to a full drawing/parts listing , and your fault description might well be a sticking /seized unloader(spill ) valve hope this helps
http://www.pressureparts.com/ManualViewPage.aspx?Manual=/mmDEV/PDF/karcherparts/g2500vh.pdf
the part number is on page 9 of the drawing
spill valve 45910400
hope this helps , we usually use some good quality silicone grease to lube the valve ,
Posted on Mar 08, 2010
How do i fix a honda landa 3500 pressure washer, when the water doesn't come out when started?
Check out the trigger mechanism. Water should come out at any time, even when you do not have the unit started.
Aug 22, 2016 | Honda Landa PG 3500 PSI Pressure Washer
I switch the pressure washer on motor starts pressure builds up motor stops. OK pull the trigger on the lance the moter starts sounds different water pressure low. Release trigger motor still runs.
It isnt very clear your explanation of the problem but what type washer do you have first? It sounds like you have a bad unloader or need a new variable nozzle tip. Can you explain in more clear detail. Thanks
Feb 16, 2015 | Garden
Pump will not unload.
Hi if it stop when the trigger is pulled the issue is with the motor.
stopping is caused by , low revs on motor or low compression or poor spark, sometimes faulty carby.
change spark plug , adjust valve ( when valve has some slight side movment it is ok if up and down , it should be tighter (valves usually under side cover near top ) increase revs a little ( make sure revs dont get rough when running high) set max revs to when the engine still runs smoothly at max.
Mar 30, 2014 | Delta Model DT2400CS Pressure Washer 5.5HP
Pump will start briefly but not continue to create pressure???
The problem you are describing is a failing unloader valve. The valve is sticking in what is known as bypass. The water is being diverted back to the inlet as it does when the trigger is shut. This will cause you to get a momentary burst of pressure and then low pressure. On the McCulloch washers this is unfortunately not worth repairing as the cost of parts and labor will exceed what the machine originally cost you.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Mar 08, 2011 | McCulloch Garden
How do you get the soap to come out of the C.Haus. pw2200 gas pressure washer
In order for the soap to come out you need to use the pressure washer at low pressure. The injector works on a ventrui system that can only pull chemical at low pressure. Depending on your washer you will either have a black soap nozzle to use or a variable pressure nozzle which you will need to rotate counter clockwise to achieve the lowest pressure possible.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Mar 05, 2011 | Campbell Hausfeld Garden
Burner runs but will fire when trigger is pulled
the burner should fire (kick in) when the trigger is pulled,and switch off when you release the trigger.
Dec 28, 2010 | Northstar Gas Powered Wet Steam & Hot...
When I release the tigger the pressure washer stops running. Runs fine as long as trigger is depressed. What could cause this?
When the trigger is pushed, the engine is supposed to rev up to increase the pressure. So from the description, is sounds like the idle speed is simply set to low and it dies. So just set the idle speed higher. You could set it as high as pulling the trigger does if you want, but that would waste gas.
Sep 04, 2010 | Briggs & Stratton Power Products 1539...
II lost High Pressure while washing I laid the gun down the time cut it off aand I reseted it and had no high pressure I removed the pressure adjuster and noticed it was rusted I cleaned it and replaced it...
The pressure adjuster you are talking about is actually your unloader which is a pressure relief valve. It is normal for this to pop up and down as it moves in and out of bypass mode. Your pressure issue could be a failed unloader, valves or packings in the pump. You will need to bypass your unloader valve to find if the issue lies in the pump or if it is simply a failed unloader. If you have any questions, need parts or service, please feel free to contact me using the information below.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Aug 17, 2010 | Honda Landa PG 3500 PSI Pressure Washer
Pressure washer stalls out when wand nozzle is released
Apr 19, 2009 | Campbell Hausfeld Garden
Garden Logo
143 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
