Question about Garden
John deere 4500 fuel gauge
Fuel gauge not working
wireguy212
  • 1627 Answers
SOURCE: I have a John Deere 2020 diesel. I can't get the fuel pump off
You need to remove the nut under the cover in front of the pump and then borrow a tool from a j.d dealership to pull the coupler off the pump,you may need the dealer to do this because they have a no lend pollicy for their special tools.Hope this helps.
Posted on Nov 10, 2009
nova2nv
  • 197 Answers
SOURCE: where is the neutral safety switch on a john deere
Its located on left side of trans,just under the shifter lever
Posted on Nov 14, 2009
nova2nv
  • 197 Answers
SOURCE: john deere tractor x585 not getting 12 volts at fuel pump
To check pump u remove fender deck,unhook connector, put 12 volt power to it.I have seen pumps react to a swift kick to the fuel tank,NO JOKE.You first have to check fuses,2 on control board and early x585 machines had a single red wire near control board that was only for fuel pump.Remove right side air screen and check for voltage on the relay closest to the radiator.Red wires #231/232 feed your fuel pump relay.Current flows from that relay #655 pink wire and goes to your fuel pump .Also check#215 grey wire {fuseable link}coming from starter post,they WILL burn out,it goes to #221 red wire with inline fuse and feeds rear of the 2 relays,that is your EFI relay.You have 3 fuseable links coming off starter post,check all of them.
Posted on Jan 01, 2010
wireguy212
  • 1627 Answers
SOURCE: i need a wiring diagram for a john deere 4500
What are you trying to repair?What on the tractor is not working?Copy right laws prevent me from posting the diagrams but i can help you with your problem,i have access to the diagrams you need so let me know what you need.
Posted on Jan 21, 2010
SOURCE: John Deere 115 lawn tractor - won't start.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Posted on Aug 18, 2010
I have a 1996 John Deere 455 diesel It started running only 20 minutes before it dies for no apparent reason. After about 10 minutes it will pop right off again. The engine runs strong, no hesitation
The fuel injection pump has a fuel supply from the fuel filter and a fuel return line from the fuel injections to the fuel tank. This fuel return line is kinked or restricted in some way . Repair fuel return line and it will run. Check return line and fitting on injection pump also. If it is an electrical problem it is most likely the operator presense switch in the seat overheating and loosing connection then cooling off after a few minutes.. Check it out.
Jan 03, 2017 | John Deere Garden
Need to know where the fuse is for the fuel pump for my 625i to fix my fuel pump
Troubleshooting - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMM136969.../OMM136969_L013.htm...
Fuel shut-off valve turned off (if equipped). · No fuel or ... Open-circuit in wiring. Engine is hard to ... Fuel pump output not adjusted to specification. · Improper fuel ...images for john deere 625i wiringimages for john deere 625i wiring
Dec 05, 2015 | Peg Perego John Deere Gator HPX Ride on...
Err 68 what it means and how too fix no fule too motor
Err 68 means
Err 68 Hold-in Relay ON. Output from the Display is short circuit. No fuel to the engine. Contact your John Deere dealer
Aug 24, 2014 | Cover My Tractor Tractor Cab-Enclosure for...
Sounds like the fuel sender is stuck or fuel sender selector has bad continuity or the contact on it is worn.
Oct 14, 2013 | John Deere Garden
I have a 2000 John Deere 990. The fuel gauge and temp gauge only work part time but always together.Any ideas?
I have owned a 990 since new. 2001. The fuel gauge started to act similar to what you described for a few years. Recently the temp gauge was also doing the same thing. I finally decided to chase the problem. Bought a PDF file of John Deere manual. The fuel and temp gauges share a common ground. I tool the hood and panels off that allow getting behind the instrument panel. ps, you don't need to pull the steering wheel. NOTE, disconnect the battery before you dive into it. I disconnected and cleaned ALL of the plug connectors with spray contact cleaner. Put it back together. The fuel gauge comes to life instantly. The temp is slow, but that looked normal, and worked. Then today the temp stopped working mid way thru an hour of using the tractor. After a palm slap to the side of the instrument panel the temp gauge instantly came to life. So there is also a issue with the gauge itself. I am going to assume that the gauge needle is stuck. so maybe some cleaner and lube in the gauge itself will solve the second half of the problem.
Sep 12, 2012 | Garden
Where is the john deere 4500 fuel cutoff switch located?
the tank might not have one but if is not starting due to fuel check the anti back fire valve on the bottom of the carb they stick all the time causing a no start problem
Apr 26, 2012 | John Deere Garden
Fuel gauge problem
LOOK FOR A BROKEN GROUND WIRE. TOUCH WIRE FROM SENDING UNIT TO GROUND AND SEE IF GAUGE GOES TO EMPTY. IF IT DOSE THEN YOU'LL NEED TO REPAIR THE BROKEN GROUND WIRE TO SENDING UNIT.
Jan 20, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Fuel gauge inop on a 2000 john deere 5310 tractor
Either the fuel gauge has given up the ghost or the sending unit is not properly grounded, in which case the fuel gauge would not work. Hope this Helps, Don
Oct 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Lawn tractor shuts off after 20 minutes of running
How old is your ? Sounds like ignition problem,If your engine is older you would have points when the points are bad they can stick together and will result in shutdown after unit cools a little it will restart !
May 09, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
