Question about Garden
What causes front steering problems on a 4230 John Deere tractor
Runs smoothly, then start going different direction in the field while working
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
mattofilms
  • 110 Answers
SOURCE: 2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Posted on Jul 02, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
  • 17 Answers
SOURCE: 1974 John Deere 2030 diesel tractor and the engine dies
I will assume you have bled the fuel system per the owners manual to ensure no air lock in your system. This is especially critical after replacing the injector pump.
The next step is to ensure you fuel filters are good and flowing and last but probably the problem is the screen on the petcock (fuel shut off) in the fuel tank. Remove this shutoff valve and clean the screen with a fine wire brush and carburetor cleaner.
Posted on Nov 17, 2009
  • 5 Answers
SOURCE: My John Deere lawn tractor
If you have a fuel solenoid switch on the float bowl you can remove it and replace it with a plug. You can leave the plug disconnected. Did it to mine and it runs better than ever. I think the solenoid get s hot and shuts off the fuel
Posted on Aug 01, 2010
Does anybody know why steering column doesn't lock on a 5325 john deere tractor?
Its likely worn out.The key switch could be working fine but their is a pin that locks the column spring loaded that maybe worn or damaged or the column tube that receives the pin .
As long as it runs OK and the steering wheel turns its not going to effect anything else but the steering lock .
Oct 28, 2016 | John Deere Garden
Year model of john Deere 4230 serial number 4230h031250r
John Deere 4230
From the data on this web page, it was built late 1976.
Best of luck.
Jan 02, 2016 | John Deere Garden
What would cause my John Deere Sabre 25hp 54"cut to be hard to steer ?
Your tractor has a simple worm gear turning another worm gear system.Either the one of the spindles in the front wheels is sticking or the worm gear is not meshing or you need to replace the worm gear on the steering shaft it's self.Also,if the tie rods are not set right then the wheels may turn hard,set the tie rods so that they have 1 to 1 and 3/4 inches of tow in in the front wheels.
Sep 12, 2010 | John Deere 420,1020,2010,2020,2510,2520...
JD 4020 Row Crop Tractor; No power Steering, No
In regard to the problem - JD 4020 Row Crop Tractor; No power Steering
What was the problem and how did you fix it I'm having a simlar problem
Apr 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
JOHN DEERE LA 175... TWO FRONT TIRE ARE NOT TRACKING
John Deere allows up to two and a half inches of tow in on the front wheels,to them this is normal.An adjustable steering rod is available but is not covered under warranty,it's up to you whether or not you need to install it,i suggest that you do.
Apr 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
JOHN DEERE LAWN TRACTOR 145 SERIES, RUNS OK
When you start to have this problem loosen the fuel cap and see if that makes any differance,there is a small vent hole in the cap that can get plugged.When it gets plugged your fuel tank will develop a vaccum and cause you engine to starve for fuel.Im not sure on this model but the older 100 series had a problem with the fuel line being pinched between the frame and the tank.
Feb 22, 2010 | Sport & Outdoor - Others
John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
May 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
