Question about Sport & Outdoor - Others
Bonair tent trailer
How to replace lift cabels
4 Suggested Answers
SOURCE: rockwood tent trailer (model 2318G) has no power
I have the same trailer and had the same problem. The trailer has a button that shuts off all power when the swing down stove and sink are folded down (this prevents anything from turning on when the trailer is folded down). The button is red and one of the wires came off the terminal.Once I hooked the wire back up everything worked fine.The button and is visible as soon as you fold down the sink and stove. The funny thing is that there is no mention of it in any of the literature that comes with the trailer
Posted on Aug 29, 2009
SOURCE: i have a Centurion power
the converter might not be working and is letting in too many volts and over powering it to the point of not working var fctb_tool=null; function FCTB_Init_18d1597bc4e042ef83fc9da550d91841(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_18d1597bc4e042ef83fc9da550d91841(document['FCTB_Init_2f479b557e0942269c917ba4c26f8cca']); delete document['FCTB_Init_2f479b557e0942269c917ba4c26f8cca'] var fctb_tool=null; function FCTB_Init_6055a1a4f8f0424782d2160b7b182f51(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_6055a1a4f8f0424782d2160b7b182f51(document['FCTB_Init_ad434a04dea2406ca738d57fb96fd227']); delete document['FCTB_Init_ad434a04dea2406ca738d57fb96fd227']
Posted on May 05, 2011
SOURCE: broken lift cable 1994 Coleman Tent Trailer. The
Hi well what you need to do is cut a piece of the cable off, and go to a place that stocks and sells nylon cordage, then simply obtain a length that will do the job, then once that's in hand, simply remove all the old cord, and replace with the new one, just reverse whatever you do when you remove the old stuff. It's basically just a bit of rope?
Posted on Oct 20, 2011
1978 bonair tent trailer has a 110 plus 12 volt system but wires were cut from coverter. I would like a drawing of how to reconnect wiring system
Building their first recreational trailers in 1983, Bonair offered a wide range of small to medium-sized products. Bonair concluded production of recreational vehicles after the 1999 model year.
It will be difficult to find manuals for legacy RVs. Try an online enthusiast forum.
Jun 24, 2016 | RVs
I have a Bonair 600 tent trailer furnace will not start with new battery but will work if pluged in
Check fuse, check 12 volt wiring, may have to replace board. Look close connections may be corroded.
Aug 25, 2014 | Heating & Cooling
Tent trailer
First of all clean the jacks very thoroughly. If they are really dirty, tap gently with a hammer to release sand and dirt, hose thoroughly, repeat. Lubricate every part of the jack with lots of wd40. Check that the part of the jack that extends down has been fully released and pushed up into the upper portion of the jack. Then grasp the jack with both hands and tug it down. While the jack is pulled down, swing it up under the trailer until it clicks into place.
Aug 19, 2014 | Hoisting
Interior lights inop jayco pop up tent trailer
I have a 99 Jayco Eagle Tent Trailer and had this issue of no interior lights. I discovered that the kill switch was stuck in the off position. On my trailer, it was located on the inside of the roof about 1 ft. from the end of the roof where the electrical wires come down the black protective tubing. This is on the road side of the trailer.
Mar 06, 2013 | Sport & Outdoor - Others
Bent tent trailer rails for pop out beds, how do we fix
Try bending rails back into shape or make new (stronger) ones. I have shared your experience. Set up trailer in rain, jumped into bed, and supports fell out! Also set up tent in the dark in the rain after one quick lesson and no instructions.
Nov 18, 2011 | Sport & Outdoor - Others
Broken lift cable 1994 Coleman Tent Trailer. The cable that lifts it up when you crank it up
Oct 08, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
I have a Centurion power converter 30 amp for a bonair tent trailer.I have power to my plug outlets when i am plugged into household power but no dome lights which i assume are 12 volt.Would this mean the...
May 05, 2011 | Sport & Outdoor - Others
Manual for 1982 Coleman Niagara Tent trailer
One is available for download from http://www.popupportal.com/manuals/Coleman/Coleman_1982.pdf
Jul 02, 2009 | Coleman Sport & Outdoor - Others
We have a 1978 Coleman tent Trailer and we need to find instructions how to replace the cable that lifts up the roof to have the beds come out, Can you PLEASE help
if the cable is broken on the bottom of the trailer jest cable splice cable if it is broke in side the suport i have 3 of them
May 02, 2008 | Coleman Propane Forced Air Heater...
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
