Question about Garden
Bolens bl110 cannot get fuel to fill bubble pump to prime engine
  • 51 Answers
SOURCE: my pull string came out and will not retract on my
the coiled rewind spring ends are bent back in a hook. the hook usually breaks so springdoes not wind up. some times you can re bend but steel is very brittle and keeks breaking and must be replaced
Posted on Jul 18, 2010
rycgl
  • 1545 Answers
SOURCE: I changed my fuel line
I would remove the fuel tank and clogged line . Then drain the gas out of the tank. You probably need to clean out the fuel tank. Use clean gas that you KNOW is clean to flush it. When you pour the old gas out of the tank, install a coffee filter inside a funnel on the can you pour it in. It will show ALL the debris inside the tank. If you are sure gas line is good , you may have an airlock (I have seen it) in the line prohibiting fuel from flowing all the way to the carb, but this usually only happens with the installation of an online fuel filterl There is a small screen INSIDE the mower's fuel tank above the outlet that may be clogged. That is why I recommend flushing it. Any gas filtered by the coffee maker should be clean enough to reuse.
Posted on Sep 07, 2011
  • 2239 Answers
SOURCE: I have a Bolens BL110 Trimmer - it starts just fine, but won't rev up completely. Suggesstions?
Could be blocked spark arrestor or carboned up in the exhaust port.
Posted on May 07, 2012
1vagabondlad
  • 56 Answers
SOURCE: What could be causing this?
to much dirt got up in clutch housing and shoes are not making full contact unit needs to be dissembled and cleaned.
Posted on Sep 06, 2012
hunter19_46m
  • 7482 Answers
SOURCE: When I use the primer bubble on my Ryobi ss26 it usually fills with fuel. After sitting in my garage for a month or so, I noticed that when priming, it does not fill with fuel and it wont start.
Hi tony_012000
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Then follow the procedure below:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indetion in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Sep 29, 2012
The head on my Bolens BL110 weed eater is slipping
Check the drive shaft. Within the drive tube there is a tightly sprung drive shaft, check where this connects to the head of the cutting attachment, it could have a worn drive.
http://www.ereplacementparts.com/mtd-bl110-41ad110g965-trimmer-parts-c-20039_20040_143532.html
Apr 10, 2016 | Garden
I have a Bolens BL110 starts fine but dose'nt rev at all
Bolens trimmer sputters and stalls and only runs on half choke? Here's how to fix it.
Look on the top of the carburetor and you will see 2 black screws that are mostly round with a flat side recessed in the aluminum housing. They are flat on top and have no notches to insert a screwdriver. The trick is to turn these two screws 1/4 turn counterclockwise. I have a set of precision pliers and used the fine tipped needle nose to turn them.
The other option is to try and notch the top of them enough so you can use a flat blade screwdriver. You can grind down the surrounding aluminum with a Dremel tool so you can access them better.
You can see in the picture that I scratched across the top of the screws as a reference to see how far I was turning them.
Mar 17, 2013 | Garden
Unable to prime engine for starting
Diesel changed filter? you may have to pressurise the tank with compressed air to force the fuel through as primeing pumps often don't work. either that or use a boat fuel bubble to draw the fuel through
Jun 25, 2012 | Cars & Trucks
May 06, 2012 | Garden
I think i ran my 1999 ford e450 out of fuel, how do i prime it and or test the pump
remove fuel filter fill it with fuel there is a bleeder there have som eone crank engine press bleeder until air bubbles are gone and just fuel comes out
Mar 19, 2011 | 1999 Ford Super Duty F 450
Bolens 4.5 Briggs and Stratton: I prime the carb
Be sure the fuel is fresh....meaning, fresh from the gas station. IF that doesn't fix it, replace the carb.
Oct 07, 2009 | Garden
Priming fuel system on a 8.1L diesel engine 2001chev 1 ton dual
Well, one problem is, if its an 8.1, its not a diesel. The 8.1, or Vortec 8100, is a gas engine. The DuraMax is a 6.6 engine. There is usually not a priming system on a gas engine, because the fuel pumps will usually get it through the smaller filters used quick enough you dont need them. However, if it is a DuraMax engine, then right on top of the fitting where you mount your diesel filter, there is a primer pump and an air bleed valve. What you do is, open up that air bleed valve ( its a little black plastic octagon shaped thing on the top of the filter mount) then you pump the primer (the silver button looking thing) until you get diesel squiting out the air vent without too many air bubbles or gurgles.
Jan 17, 2009 | 2001 Chevrolet Silverado 2500HD
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
