How do I maximize water levels in my whirlpool wfc7500vw washing machine? In other words, which cycle uses the most water, and/or how I can turn off the water sensor so that the machine uses extra water?
    Top Expert:
  • Washing Mach... Master
  • 49,197 Answers
The water levels in you machine are set by a pressure activated diaphragm that is controlled by the knob with the levels settings around it or by the computer if you have a press button type.. Heavy or long wash cycles use the most water with light washes using the least. So to explain if you are washing blankets and you have a full 7.5 kg load to wash you would set the water level at high and heavy or full wash. You can disconnect the tube to the control unit but if you do that the bowl will keep filling over the top and the machine would not know when to start washing as the control unit reads enough water and moves the power to the motor while closing of the water solenoid. If you follow the instruction in the operators manual you will find that you save the most water at any wash requirement.
Posted on Jul 29, 2013
  • 185 Answers
SOURCE: simpson esprit washing machine
put a new pressure switch in it
Posted on Mar 26, 2008
SOURCE: GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Posted on Mar 27, 2009
dragonsthatk
  • 547 Answers
SOURCE: LG Tromm WM2277HW Water level to low
this is normal the pic are all photo shop water you clothes are clean right?
Posted on Feb 12, 2009
  • 58 Answers
SOURCE: repair washing machine
lid switch could be broke
Posted on Oct 31, 2007
  • 641 Answers
SOURCE: Maytag Washer
There is a water level switch on the machine. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you should find it easily. You can either clear any obstruction in the tube or replace the water-level switch (easy to do it). Another direction to be checked is the water inlet valve (my recommendation is to start with it, and if it will not solve your problem to move to the level switch )- maybe it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before starting working on it!!!!!
Posted on May 18, 2006
F23
PRESSURE SWTICH ERROR
The wash level and level heater safety are switched on at the same time F23
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to pressure switch and Central Control Unit (CCU).
3. Check connections of the CCU board within the housing.
4. Check the pressure switch for worn or failed conditions .
cheers
Jul 18, 2017 | Whirlpool WFC7500VW Washer
Whirlpool wfc7500vw has f05 code
If you wish to get some details; check the site linked here. Pull up older posts.
http://homenol.blogspot.com/
Apr 10, 2013 | Whirlpool WFC7500VW Washer
My whirlpool steam duet washer won't pour water in the wash cycle
There is no output from the control panel to switch on the inlet valve, so check the inlet valve at this time of the cycle. Also check the water level pressure sensor switch.
Choose another program to confirm if not the controller seems to be suspect.
Jan 24, 2013 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Wfc7500vw spins but not at high speed on final spin
This is a common problem with the Whirlpool front load machine. The motor control board goes out but the new ones have been redesigned. You will need to replace the control board. Here is a link to the control board you need.
Oct 17, 2012 | Whirlpool WFC7500VW Washer
Front knob for whirlpool washer wfc7500vw broken?
Hi,most washing machines open from the top,a couple of screws at the back and slide the top back and lift,then you should be able to see the part number,I hope this is the same for your machine.
all the best.
Sep 10, 2012 | Whirlpool WFC7500VW Washer
Washing machine displays an LF error code. Started last week during whitest whites cycle in rinse. I cancelled and just did rinse to finish my load. All other cycles worked and yesterday all started...
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Problems with Whirlpool WFC7500VW Washer? Get code A10 & won't reset.
A10 is a long drain cycle. Check the drain hose to make sure it is not clogged or kinked. Could be a clogged or bad pump.
Dec 23, 2009 | Whirlpool WFC7500VW Washer
Wont work
Check this all this can cause that your washer is not working:
  • Check that the washer is plugged in securely
  • Check the circuit breaker or fuse box
  • Test the outlet for curent
  • Check that the water supply valves are turned on
  • Inspect the filter screens
  • Test for overheating
  • Test the water level switch
  • Test the timer control
  • Good luck :
    Regards:
    VOTIT
    Jul 01, 2009 | Whirlpool WFC7500VW Washer
    Washing Machines Logo
    56 people viewed this question
    Top Washing Machines Experts
