Question about Vehicle Parts & Accessories
98 ford exploer gas coming from tail pipe wth white smoke pcm code cly #4,5 misfire i have replaced the fuel dumpler "fuel pressure regulator" but no luck. Checked sparked plug and it's fine. Wires ar
    Top Expert:
  • Vehicle Part... Master
  • 45,365 Answers
Next to check is the injectors for correct operation and the connections for moisture in them
Posted on Jul 29, 2013
em1cl
  • 463 Answers
SOURCE: My 1996 Grand Voyager runs
You didn't mention any trouble codes. In 1996 all vehicles manufactured in the U.S were required to install the second generation OBD, also refered to as OBD II, to insure that a standard scanner could be used on all vehicles.
It shouldn't be a fuel problem with everything you've had done.
I don't believe it's an emissions problem, because, although emissions can cause a vehicle to stall it usually gives a bad idle and poor acceleration among other things.
Because you don't mention bad idle, loss of power, or no restart we can safely say it's not an emissions problem.
The only thing left that I can think of is an electrical short. I would start with having both ends of the auto shutdown relay checked for a good connection and have the contnuity checked.
Secondly, I would ant to have the wiring in the steering column checked for the same thing, in particular around the ignition. I am very sure your problem is electric.
I'm very sorry your having these issues and I hope this will help you solve them.
If you have other questions please feel free to leave me a comment, and I will get back to you ASAP.
Thanks, Donnie
Posted on Feb 22, 2011
jesusismy138
  • 8 Answers
SOURCE: 1990 dodge d150 360 cuts out when i accelerate checked codes, pulled 24,37,22,14. i replaced map sensor, throttle sensor, coolant sensor, and still having same problem erased codes and now still pulli
Code 37 (Part Throttle Unlock (PTU) solenoid circuit is open or shorted)
This is detected when the ECU doesn't sense near 0vdc or 12vdc at the relay when the solenoid is turned on or off. When code 37 is thrown the power limited light will not be lit and the system will not enter limp mode. With manual ****** it can throw this code for no apparent reason.
Possible Reasons for Fault Code 37
Check the wiring and connections from the logic module to the solenoid. Clean and re-grease the connectors with Dielectric Grease.
The solenoid is located in the right, front fender next to one to three other solenoids.If I remember right it is nothing more than a simple plunger activated by an electromagnet type device. It redirects air from one port through another or to another port. I don't know about finding a new one if you need it but they are built well and you could find one at pull a apart. You can also spray carb/throttle body cleaner through it and clear any clogs that might be in it.
Posted on May 11, 2012
sxygaman
  • 95 Answers
SOURCE: 2001 tj jeep no fuel pressure at tank
leaking fuel tank or bad vent tube creating air pocket
Posted on Aug 12, 2012
george_karas
  • 211 Answers
SOURCE: 2002 Nissan Frontier P0301 Misfire Detected(Cylinder)
spark plugs high tension leads rong clock wise 1-3-2-4 or 1-3-4-2 .
Posted on Sep 08, 2012
gregs_rockin
  • 274 Answers
SOURCE: 1995 chevy sports van trouble starting only in early morning and is now blowing white smoke from tail pipe
It is normal for it to blow out Exuast smoke when it is cold out. With the starting is your battery good? When was the last time it was tuneup? How many miles are on it? Was it mantain reguraly? That problem can lead to a lot of different things.
Posted on Oct 21, 2012
94 lexus es 300 leaking gas and white smoke from exhaust tail pipe and when I turn off the car it starts to pour out of the same spot
Charles, after searching the net., stuck injectors,faulty fuel pressure regulator or faulty ECU. Have a good Tech, check engine codes, diagnose and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
White smoke out of exhaust not what you think Club Lexus Forums
Es300 Smoking Bad And Gas Smell Help
http://www.automotiveforums.com/t967184-_93_lexus_es300_fuel_in_exhaust_runs_rough.html
Jul 09, 2016 | Lexus Cars & Trucks
What does it mean when gas is coming out of the tail pipe and the car has no power?
Most likely your problem is being caused by a sticky fuel injector. When a fuel injector sticks open it constantly sprays fuel into the combustion chamber even when there is no spark being supplied to that cylinder. Therefor all that fuel gets expelled from the combustion chamber through the exhaust. The white colored smoke is the raw fuel burning in the exhaust pipe. The white smoke may also be caused by a blown head gasket(which can be caused by a stuck injector).
Mar 14, 2016 | Beck Arnley Fuel Pressure Regulator...
Dumping gas into oil and blowing white smoke changed the fuel pressure regulator no difference
White smoke is coolant getting into the cylinders , blown head gasket cracked head or crack in the block etc... . If the engine were running rich ,then black smoke would be coming out the tail pipe -exhaust !
Aug 25, 2015 | Cars & Trucks
I have a 2004 Chevy Impala. 3.4l v6. About two months ago, the fuel pressure regulator went out, and I forced it home. My mechanic replaced the fuel pressure regulator and said I had an EGR code, so I...
White smoke and foam in the gas tank indicates antifreeze leaking into the engine somewhere. Do you smell antifreeze? You may have an engine seal leaking, most likely head gasket. It may be affecting the various engine sensors.
Aug 23, 2013 | Cars & Trucks
Burning gazoline and white smoke is coming out to tail pipe
This means its running rich, burnning to much gas. this could be due to a bad mass air flow sensor or bad o2 sensors or even a bad fuel pressure regulator, i would start with the fuel pressure regulator, remove the vacuum hose that goes to it and start the engine and see if gas is leaking from the port that vac hose goes to and if it is then replace that regulator and see how it runs from there. the rest you will need a scan tool to check the readings of the o2 sensors and mass air flow sensor. another thing is that if the engine is running rough it may be misfiring , skipping due to bad wires or sparkplugs. white smoke means alot of gas is being burnt and a regulator would be the first thing i would look at. good day.
Aug 17, 2011 | 2001 Chrysler Town & Country
Hi i have a 1988 ford f150 it idles up and down and always smells like gas also when you floor it or tap the gas after idling for a while black smoke comes out the tail pipes. i'm so sick of it running...
Check fuel pressure regulator by removing the vacuum hose. If idle does not change or fuel comes out of regulator replace it. Otherwise check your injectors one at a time while car is running. If idle does not change replace it.
Oct 13, 2010 | 1988 Ford F 150
My 92 ford is using excessive gas and has a bad gas smell with alot of smoke coming from tailpipe after i add gas
If the smoke comming from the tail pipe is black your running rich. If thats the case the entire fuel system has to be ckecked out. Injectors could be leaking, a bad pressure regulator,stuck return line ,a coolant temp sensor could be telling the ECU that the engines cold give her more gas. I don't recommend doing fuel service unless your qualified to do so for the obvious reasons.
If the smoke coming out of the tail is grayish you have a bad head gasket. If the smoke coming out of the tail is blue you have engine oil getting into the combustion chamber. keep me posted
Mar 08, 2010 | 1992 Ford Explorer
Chevy 3500 Express truck. fuel problem?
IF YOU GOT CYLINDER MISFIRE.OR OPEN FUEL INJECTOR.THAT WILL CAUSE THE PCM TO ENRICHEN FUEL MIXTURE.TO ADJUST TO DEAD CYLINDER.WHICH ACT AS A LARGE VACUUM LEAK.THATS WHY YOUR EXHAUST TAIL PIPES HAS A RAW FUEL SMELL AND WHITE SMOKES.
Sep 03, 2009 | Chevrolet 3500 Cars & Trucks
White smoke coming from exhaust, smells like gas
Check the fuel pressure regulator. It should have a vacuum line attached to it - disconnect the vacuum line and turn the ignition on - if fuel come out then that's your problem. DON"T do this while the engine is hot or you could start a fire!
Jan 01, 2009 | 1996 Cadillac Seville CA Value
Vehicle Parts & Accessories Logo
78 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
