I have a jvc Rx-515vtn digital surround system receiver s . no 178c4092 i cant get it to function without the remote
  • Audio Player... Master
  • 5,190 Answers
Has some kind of "child lock" come on? Look for that in the manual.
Posted on Jul 29, 2013
The Marv
  • 72 Answers
SOURCE: JVC RX-618V SOUND IS MUFFLED
check to see if the radio is clear. If it is it may be the signal going into the amplifier. if it is muffled as well, depending if you have an Equalizer hooked to the unit. This also could cause the problem. Finally check the bass, treble balance and volume knob but turn them back and forth while unit is on and see if signal clears up momentarily. if this is the case the control knobs need to be cleaned. Also spin the connection jacks {RCAs} in the rear and see if this clears it up. If not you may have to have the unit serviced by a professional.
Posted on Aug 05, 2006
tech48
  • 624 Answers
SOURCE: I have a JVC rx-6032v
yes, you must use the setup menu and assign the optical input to the input you are using. Some receivers have a "input mode" switch. If this one does, you only ned to press it until it says "optical". If you have a owners manual, it will decribe all the settings that need to be made to accomplish what you need.
If you do not have one, I have uploaded one to my website for you do have. It will only be there for a limited time before I remove it, so get it quickly. You need Adobe Reader to read this, so if you don't already have iton your computer you can download it free here:
http://www.adobe.com
Here is the link to the owners manual:
http://www.get1here.net/rx-6032v-ownersmanual.pdf
I would appreciate a "FixYa!" rating for this free information and manual. Let me know if I can be of any further help.
Dave
Posted on Jul 12, 2008
SOURCE: jvc rx-5032v audio/vido control receiver
HI MATE YOU NEED THE REMOTE
Posted on Aug 19, 2008
SOURCE: Digital surround mode not putting out bass-RX-6022V
On the unit, just left of the volume control there a "adjust setting", cycle through the modes until you SUBWOOFFER and then press CONTROL UP or DOWN to make it say YES. I have no idea how it switched to NO. Probably with my remote, but some time did pass and I'm happy I got my Bass back. Quantum of Solace sounds great.
Posted on Nov 30, 2008
SOURCE: I have a Yamaha Rx-v363
this sounds strange, but is true. you need to run your digital audio optical cable from your tv to your receiver (after, of course, connecting tv/receiver via hdmi). so, hdmi from blue ray to rec - hdmi from rec to tv - then optical from tv back to rec. it's round about, but that is how yamaha says (and the only way it works) to do it.
Posted on Jan 04, 2009
Can't get my center spkr.to work on my jvc rx 807v receiver
Make sure the speaker is good by connecting it to a known good working site. If speaker is good, make sure it is properly connected to center speaker terminals. Then if it is a surround receiver make sure that the sound mode is one where the middle channel works such as 5.1 DTS, etc. If the center channel still does not work then the problem lies with the decoder chip that is not working properly and sending the center channel info to that specific amplifier.
Mar 10, 2015 | JVC RX-807VTN Digital Surround System...
My receiver only plays front speakers. when i put it in surround mode none of the speakers will play and the sub even in stereo mode is barely a whisper of sound. i dont have a remote for it but it goes...
you don't need a remote. to me sounds like you might have a connection problem. try and do a test tone which will send a test signal to all the speakers. starts from left to right etc. if you cant hear all the speakers you need to check all connection wires etc. hope this helps
Apr 08, 2014 | JVC RX-8000V Receiver
Connecting to samsung smart tv
For digital connections on your TV ( unknown model) read on page 7
[PDF] RX-6000VBK / RX-6008VBK INSTRUCTIONS AUDIO/VIDEO - JVC
Sep 30, 2012 | JVC RX-6008V Receiver
JVC RX-515VTN: When I turn it on, th ereciever comes to life and then "Protect" flashes on the screen and then it automatically shuts off after about 10-15 seconds.
Check the rear panel for any loose connections, paying special attention to the speaker terminals. If you are using speaker wire without connectors, make sure that you have no stray strands of wire protruding outside the terminals or any broken strands.
Strand wire over time oxidizes and becomes brittle and easy to break so at any time the unit was moved while connected or anything else that would create tension on your connections it could easily break some wiring.
Also check the opposite ends of all of your connections at the speakers and input devices, i.e; DVD player, television etc.
Feb 10, 2011 | JVC RX-554V Receiver
I am using a JVC RX6000 video audio receiver, and i hooked 5.1 BMB brand home surround speakers to it, and connected my ASUS media player that has optical output and used optical cable to connect to the...
This is a common problem. Each input will default to analog. Even though you have plugged an optical cable into the inputs of the Receiver, you have to change that input to digital.
For example, if you connect a CD player RCA cables to the Receiver. The receiver will recognize the Analog signal at the CD input. If you unplug the Analog RCA Cables and plug in the Digital optical, the receiver will still be at it's normal default input for the CD player which is Analog. You then have to switch the input, using either the remote or it may be able to be done with the buttons on the front.
As soon as it is changed to Digital, you will get nice sound.
Hope this helps,
Happy New Year,
Mark
Dec 31, 2010 | JVC RX-7000V Receiver
PS3 with this receiver.
I dont know your reciver but if it has a hdmi input plug ps3 into it and set audio on ps3 to pcm,this will give you digital surround eg multichannel,if not you must use a optical cable from ps3 to reciver and set ps3 audio to digital.
hope this helps.
CABLE GUY.
Jun 30, 2008 | JVC RX-6030V Receiver
Rear Surround speakers
Best thing to do is to put the unit in 5 channel or 7 channel mode. That will send left ch information to the front left and rear left speakers ( both will get the same information). Ditto with the right channel. The center channel will get centre channel information.
If all the speakers work, go out and rent TOP GUN. ( yes its old), BUT there are a few extreme scenes , one of which is the elevator scene, where the camera changes perspective and suddenly you hear the elevator doors close BEHIND you through only the surround speakers ( have the unit in surround mode....NOT 5 or 7 ch mode ). If this works ok, then you have no problems.
Remember, surround sound only produces information in the rear channels when the information is there. To check out the digital and DTS decoders, get an action flick. If you can, get a remote too, because that will unlock many features about the receiver that you cant get to with the front panel controls. Also go to yamaha and download the owners manual ( its free !!).....that should get you going.....
best of luck...
Rob
Jun 08, 2008 | JVC RX-880V
Feb 22, 2007 | JVC RX-5022R 5.1 Channels Receiver
46 people viewed this question
 Grubhead
Grubhead
