Question about Honeywell ER150B Air Conditioner
Ac won't turn on it just clicks.
There was a power outage yesterday, so after the storm I tried turning on the ac but the thermostat just clicks. I have a Honeywell digital thermostat.
    Sergeant:
  • 470 Answers
Thermo or the start cap.. Start caps don't like voltage spikes. Thers is also a transformer from 110v to 15vdc if you shorted the thermo somehow this could be the problem
Posted on Aug 25, 2014
  • 3 Answers
Hitachi DC Inverter Scroll Compressor have a startup problem. when i start the unit the compressor start a voice of " Tak, Tak , Tak rasie and after 30 Second the compressor trip, after few minutes the compressor again try to start and again Tak, Tak, raise and compressor trip. please somebody help me about this issue.
Posted on Jul 29, 2013
2 Suggested Answers
buffalonyman
  • 1865 Answers
SOURCE: ac will not turn on, ac clicks but does not turn on
At this point, you have to check to make sure that none of the wire became dislodged in the t-stat. If all the wires are securely connected, check to be sure that you are reassembnling the t-stat correctly.
If all is well at the t-stat, then the next step is to start testing the HVAC components; you will need a voltmeter for this step
Posted on May 05, 2009
Just purchased 1993 coachman RV heater works but ac doesn't ac did come on yesterday morning when wife turned up thermostat because she was cold
check for a problem climatic control unit
if the ac gave out cold air when the thermostat was adjusted , it indicates a control problem rather than an ac problem
take it to an accredited ac specialist shop for a proper diagnosis and quote
Jul 29, 2016 | RVs
Reset after power outage
pull out the plug or just turn it too off for 20 minutes and plug it back in/turn it on. when power goes off the compressor will click and keep trying to restart. this also happens with AC s turn off and let sit usually fixes most of these
Apr 23, 2014 | Whirlpool Refrigerators
Our Ruud ac won't come on after a storm and power outage? I have flipped the breaker with no luck. Any suggestions?
there is a fuse on the circuit board on the inside unit. Typically a power surge will pop it. checking that fuse is the best place to start
Sep 29, 2012 | Ruud Heating & Cooling
WE HAD A POWER OUTAGE.NOW MY KEURIG WONT TURN ON. CAN YOU TELL ME WHAT THE PROBLEM IS. THANK YOU.
Hi,first you need to check if fuse has not been blown out.Because when POWER comes back after an outage there is a surge voltage flowing through electrical lines.It is advisable that when their is a POWER outage you have to turn off your FUSE box or SAFETY box to make sure that it won'tdamage appliances when POWER comes back>Technically when POWER SOURCE or SUPPLY has been shut off for a period of time.When POWER is back, expectantly there is an abnormal flow of current/line; current will not be as stable until a period of time..AC current behaves like a wave,values changes from time to time especially when POWER SOURCE has just been TURNED ON..So better turn off FUSE BOX when experiencing POWER OUTAGE so that when power comes back SURGE VOLTAGE wont flow within the circuit>Hope this helps..
Jun 22, 2011 | Keurig Elite B40 Coffee Maker
After a power outage, my wii will not turn on
You can try a new AC adapter.If that does not work,it will need to be repaired by a Nintendo authorized center.(I used to work at one).If you do by a new one PLEASE buy Nintendo brand.The "off" brands usually end up in some kind of problem down the road.
Good luck and agme on!
Jul 12, 2010 | Nintendo Wii Console
Radio, dome lights and EVIC power problem
I found a paritally blown fuse. When the fuse blew metal pieces ended up partially making contact. After replacing the fuse everything worked great.
Jan 07, 2009 | 1994 Jeep Grand Cherokee
Thermostat message battery low. Put in two new batteries and it will not reset or start. Lost Power during storm and cannot get it going again.
Let me see if I understand your question.. your thermostat indicated the batteries needed to be replaced so you changed them with new ones.. With new batteries, you cannot get your thermostat to initialize or program correctly and as a result of that, you cannot get your AC system to start up.. If that is true, please provide the Honeywell Model # and verify the batteries you installed were Ok,...
Will attempt to assist once you've provided this info..
( on an off chance, have you checked the fuse or cuircuit breaker for your AC system to make sure it has power available?) This is especially important after a power outage..
Sep 16, 2008 | Honeywell Heating & Cooling
I have a Carrier 38tra048340 ac 4 ton unit outside, heater in attic. Thermostat is Totaline P374-1100. Power went out than back on after a few hours due to vehicle crashing into power pole. AC was running...
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Jun 23, 2008 | Carrier Heating & Cooling
I changed the filter on my ruud 1x2000 the other day did not try to turn on until yesterday.tried ac nothing then tried heat nothing. changed termastat still nothing.
is this a whole house air conditioner ,
if so check the fuse panel,
check to see if the outside unit runs at all , compressor or fan.
check the ac transformer power to the thermostat
check the switch in the ac closet
doe the internal fan run if you switch to fan only.
Apr 13, 2008 | Heating & Cooling
Honeywell ER150B Air Conditioner Logo
131 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
