Question about LG W2753V PF Flat Panel 27" LCD monitor
Blank display W2753V. Not power board, need service manual
My LG W2753V blanks out after 1 second. The power LED is still on, so is the LCD backlight. I have replaced the capacitors on the power board, but get the same result. DVI and VGA do the same result. I have not bee able to find the service manual for this unit. I think it may be the input board, but need a part number to try and locate a replacement board. Any assistance greatly appreciated!
  • Steve Aug 27, 2013
    Hello everyone, many thanks for the ideas.
    The LED on the monitor is not flashing, ti is on solid. A new monitor is working fine. Nothing changed on my system when this monitor stopped. I've even got a new video card (opportunistic upgrade, not done for this specific issue), and that also didn't work. Monitor fails on two different computers.
    The monitor is a couple of years old, and had medium use, not turned on 24/7.
    I'm going to have a look at the inverter board, but I'm not sure about that, as I'm pretty sure the backlight is operating fine (I can see the glow).
SOURCE: When I press the power button LG displaying chars for 1 second
Had the same problem, turned out it was due to a faulty capacitor on the inverter board, 680uF 25V (105 celsius rated). Simple to fix once you have the unit dismantled and the correct replacement part. Two screws hold the shroud on, but you need to be careful with an (old) credit card levering it off.
Unit is now working fine.
Posted on Oct 23, 2008
ginko
  • 19396 Answers
SOURCE: LG 700E monitor's power LED blinking continueously, no display
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 22, 2009
sys_admin
  • 829 Answers
SOURCE: lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
Posted on May 10, 2009
  • 732 Answers
SOURCE: My LG 2353 monitor screen goes blank
shaylane_195, Good description of problem! But you left out one or two key things to tell me. Age of monitor? Approximate total "ON" hours of use? Is unit covered by LG (Lucky Goldstar) warranty? You and only you can tell me if the screen is really BLANK, or is it only BLACK? Do flashlight test to determine true state of screen! Can you see very, very faint image of WIN-desktop holding bright flashlight near your black screen? This monitor works!!! You just need to fix the possible (1) "cold, frosty looking, thermally intermittant solder connection on the "internal switch-mode-power-supply/CCFL inverter board. Yes, your monitor along with many other CCFL back-lit LCD units of all brands also could have some BAD, swollen, leaky electrolytic filter capacitors installed on the SMPS/CCFL inverter board which will need to be replaced with new ones of higher quality. Get back to me, lmistyrel on aim. or do additional comment on fixya, after you do some reading in my and other fixya tech's profiles to discover all options you as consumer/user have open to you. Bye for now. 12fixlouie
Posted on Mar 05, 2010
  • 555 Answers
SOURCE: How to open (remove back) Omnitech Vw19B LCD Monitor
You are right about the problem on the flourescent, but the issue is caused by the mosfet transistors. You need to use a flat screwdriver to pry the back of the display until you get this open. Start from the bottom side because some damage will be left on the plastic.
Posted on Apr 15, 2010
Would replacing the T-Con board in an LG TV55LN5600-UIfix the issue of 'no picture and base red led blinking 3 times'?
The service manual in the troubleshooting section says that is a power board error, I would try that board.
Nov 25, 2017 | LG Televison & Video
I have an LG 47LN522-UB LED TV that stopped working after three years and need help diagnosing a problem with it.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 26, 2017 | LG Televison & Video
LED Backlights on LG TV?
If audio is OK, the backlight inverter is the part should suspected. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Oct 25, 2015 | LG Televison & Video
What parts to fix a blank screen besides power supply and main boards (have tried both)?
STOP Get a SERVICE MANUAL and follow instructions before you make it any worse by "Mucking around with it" it needs to be serviced in a set careful methodical way u cant just replace boards and hope as those boards may damage or be damaged, to have any chance u need to get the book plain and simple less expensive too.
Aug 21, 2015 | Toshiba 39L1350U 39" LED TV 1920x1080, 120...
Lg 50ln5600 backlight issue
Check whether the back-light start voltage [control voltage] comes to the backlight inverter section of the power board; from the main board. It sounds that that voltage does not come from the main board, after the firmware has been loaded up. If so the main board will have the fault. Contact any service technician.
Aug 03, 2015 | LG Televison & Video
V7 S20PD monitor goes blank after 1 second!
This is usually caused by one of the inverter transformers that drive the backlights, or the backlight itself. The capacitors should not be ruled out, to fix it will be expensive venture.
May 16, 2012 | V7 Computers & Internet
My LG 26LH20 turns itseld off after about 2-3 seconds. TV is a little over 1 yr old. I t happened about 2 months ago and I thought it was the cable. had cable serviced, not the problem. now it's...
Tv turn itself off after 2-3 seconds the tv still audio voices?Yes,than the tv long board that call the LCD inverter board it is dead.Require change the tv long LCD inverter board,this board help the LCD screen panel to have a backlight to produced a picture or 2-3 seconds tv power died completely no power to tv all?Yes,than this problems the tv power supply board it is dying.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board or the tv power supply board for the replacement.
May 09, 2011 | LG 26LH20 LCD TV
I HAVE A LG Full HD 1080p HDMI W2753V-PF 27-inch LCD Monitor (Refurbished)...I WAS USING MY COMPUTER WHEN IT TURNED OFF..THE COMPUTER WAS STILL ON ...BUT THE MONITOR JUST TURNED OFF...AND IT WOULD TURN ON...
This is a common problem with LCD monitors after a few years of use. The filter capacitors on the power supply/Inverter board have failed and the power supply board can not start up right. You can repair the board by replacing the defective capacitors. Here is a picture of the power supply board model LGP26-09P from the LG W2753V monitor and below the picture is a link to a repair guide for that model.
http://www.ccl-la.com/blog/index.php/lg-w2753v-repair-no-picture-no-power/
Jun 23, 2010 | LG W2753V PF Flat Panel 27" LCD monitor
Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
Dec 17, 2008 | Acer AL1716Bbd 17" LCD Monitor
LG W2753V PF Flat Panel 27" LCD monitor Logo
150 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
