Question about Cub Cadet Garden
How to remove clutch on a cub cadet lawn tractor
Need to remove clutch
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cub Cadet Master
  • 1,917 Answers
If eletrical clutch you need a air wrench remove the nut clucth slides off but you got to have air wrench
Posted on Jun 07, 2014
joboo1
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
highspeedsan
  • 61 Answers
SOURCE: cub cadet dead as a door nail
I have the same mower. The wires do need to be connected. It is a safety feature on the cubs. The engine will not start if the electric PTO is engaged. I just went into the garage, pulled the pto lever out to engage, pushed down brake, tried to start and it would not start. I suggest reattatching the wires and trying it. Hope this helps.
Posted on Apr 25, 2009
  • 376 Answers
SOURCE: How do I change the drive belt on a 1500 Series
Go to www.partstree.com click on Cub Cadet, enter the model number that's under the seat and that will give you a diagram.
Posted on Jun 13, 2009
  • 3600 Answers
SOURCE: cub cadet from a 1330 lawn tractor drive belt
Most common problem is the deck bearings being bad for one of the blades. The next thing to look at is the mounting arms, hsake the deck back and forth if it wiggles side to side it will need reparirs. Also check that yo have not bent any pullys and that they are all running straight.
Posted on Aug 27, 2009
  • 4 Answers
SOURCE: I have a Cub Cadet lawn tractor that just stop
CHECK THE FUSE
Posted on Jul 02, 2010
How do i get the pto clutch off of a cub cadet lt2180
you need a impack gun to get the nut off the cluctch it will come right off
Sep 17, 2014 | Cub Cadet Riding Lawn Garden Tractor 25hp...
How to change out an electric clutch on a cub cadet zero turn RZT50?
Removal is simple if you have access to an impact wrench so you can the center retaining bolt.
When re-installing anti-seize compound needs to used on the crankshaft so the new clutch assembly doesn't seize on the shaft. To tighten the center bolt you must hold the flywheel in place by blocking it. This center bolt must be torqued to 45-55 ft fts. Also the new pto clutch needs burnishing in. Most new clutches come with instruction on this procedure.
Jul 23, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
My cub cadet lt1050 lawn tractor mower starts when cold fine, but wont even turn over when hot.
you have bad valves it needs a valve job this is because the hatter it get it looses power and will shut down when to hot
May 25, 2014 | Cub Cadet Lawn Mower PTO Clutch Replaces...
Hello, I have a Cub cadet tractor model 2164, and
BEARINGS ARE BAD IN CLUTCH REPLACE THE PTO
Oct 30, 2013 | Cub Cadet Garden
My cub cadet tractor starts but the pto clutch stays engeged and i cant shut it off(pto)
The clutch has it's own brearings in it. You have to replace the hole PTO.Sometimes you can find a Aftermarket PTO clutch. There usually A little cheaper.
Jul 10, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Cub cadet zero turn clutch will not engage
If the clutch will not engage it can be that the cable is not regulated to pull the clutch enough
this is an idea on a real car.
thanks
Jul 12, 2011 | Cub Cadet Street Sign- tractor lawn riding...
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
My Cub cadet pto cluch bearing is froze up on my 2518 lawn tracto
A medium length extension (stuck through the grill), a swivel and an impact is all you need to remove the pulley with the frozen bearing. It's just a bolt, a washer, and a lock washer holding it on. You just need to remove the pulley to see if the bearing is stuck. Take the pulley to your local shop that can press bearings and you can be up and running for $20 dollars instead of $300. Here's a diagram I found on partstree:
http://www.partstree.com/parts/?lc=cub_cadet&mn=2518-48+Tractor&dn=0043700012
Apr 08, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I need to replace the pto clutch on my cub cadet 2160, how do I remove the outside bolt? it turns with the engine
best way is to use an impact gun. second way would be to use a pipe wrench on the shaft if theres room. use some liquid wrench to loosen it up too
Jun 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
