IBM ThinkPad R40 2722 Notebook Logo
Posted on Apr 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Take Took Long Entering Bios Setup
My thinkpad R40 gets too long time when boots, then when I would like to entering the bios setup, it also took too long. Pliz help me..
Anonymous
Level 2:
  • Expert 33 Answers
  • Posted on Apr 01, 2009
Anonymous
Expert
Level 2:
Answers
33
Questions
0
Helped
11744
Points
102
You should get some diagnostic tools (like Hiren's BootCD, PC DR., or Microscope) and run a system scan, paying specific attention to the RAM and the Hard Drive, but this sounds more like a Hard Drive issue than a RAM issue, but do both just to make sure.
Entering setup network selected as first boot device for current boot
That a LAN boot Rom is used does not affect the keyboard entry used to enter setup.
The BIOS controls if the onboard LAN will run on boot up.
LAN Boot ROMs are used to download operating system code from a network server. So, the BIOS has priority.
The BIOS runs first, and if you enter setup by pushing the proper key for the motherboard, you can change the boot to DVD or another device (USB Stick) to troubleshoot the PC.
Advanced boot options
Lenovo Basic Input/Output System (BIOS) settings allow you to quickly customize interactions between your operating system and your hardware, especially your hard drive or drives, memory and power supply.
You must get into the Lenovo BIOS before your operating system loads.
Though most users don't typically see options for entering or using the BIOS, multiple changes can be made to customize and optimize your system, such as changing your boot device order and changing the display brightness to conserve power.
Turn off your Lenovo computer.
Press the power button to start your system.
For best results, wait 30 seconds to one minute before starting your system.
This gives you a longer window in which to enter the BIOS.
Press "F1" as soon as the Thinkpad logo appears.
Depending on your Thinkpad model, you may be prompted to press either the blue "Access IBM" or the blue "ThinkAdvantage" button instead of "F1 or F2."
If this is the case, a message will appear stating "To interrupt normal startup, press (one of the listed buttons above)."
Select the "Start setup utility" to open the BIOS setup menu.
Follow the instructions provided in the BIOS setup menu to select BIOS menu sections, settings and to change options.
Next, navigate through the Bios setup pages using keybard arrow keys in order to find failsafe or optimized defaults press ENTER to select your option press F10 save to cmos and restart
http://www.michaelstevenstech.com/lenovoBIOS.html
Ideapad Z560 neither accessing BIOS setup or is starting normally
Your bios seems corrupted. You will probably need to reflash from a thumb drive which is bootable. The F2 should get you to booting screen to access the thumb drive to boot from to flash the bios.
3helpful
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
When i powerd my thinkpad a31 2652 it prompts me with a passwword i think is a bios code
Actually its not a bios code. Its a password that was been setup during the accessing of its bios. There are two options in setting up such a thing. 1 is for the security of cannot accessing the bios and 2 for not accessing the computer when booting up. Well in your case it was setup in not accessing the computer when booting up. If you set this options definitely you know the password of it. Just type it in the password that you have setup. Then press enter.
Error no 0176
Change the bios battery.Remove the notebook battery and then you should see the bios battery.Maybe you should have to disassembly the complete pc because it is a little dificult without disassembly.
MY IBM Thinkpad R52 laptop is not entering in BIOS setup
OK< this is main fix I start with when working with a Thinkpad...Unplug from the AC adapter...remove the battery, and the cmos battery. That is the one about the size of a quarter. Leave them out for about 20 minutes. re assemble and try again...hope this helps...
2answers
How can i reset my pass word
Would need a pass word:
How to enter the BIOS or CMOS setup.
Reasoning: IBM compatible users may need to enter the BIOS or CMOS setup to setup or change how their computer's hardware is currently configured.
Solution: Because of the wide variety of computer manufacturers and BIOS manufacturers over the evolution of computers, there have been numerous different ways to enter the BIOS or CMOS Setup. Below is a listing of the majority of these methods as well as other recommendations for entering the BIOS setup.
Notice: If you are unable to get into the BIOS or CMOS setup because of a password please see document CH000235.
New computers Thankfully, computers that have been manufactured in the last few years will allow you to enter the CMOS by pressing one of the below five keys during the boot.
A user will know when to press this key when they see a message similar to the below example as the computer is booting. Some older computers may also display a flashing block to indicate when to press the F1 or F2 keys.
Press <F2> to enter BIOS setup
Tip: If your computer is a new computer and you are unsure of what key to press when the computer is booting, try pressing and holding any key on the keyboard. This will cause a stuck key error, which may allow you to enter the BIOS setup.
Or can do this :if above steps dont help ya out
start
control panel
user account
Click on : Computer Administrator
This should get ya back on line, Good Luck
1helpful
2answers
OPEN PASSWORD BIOS
How to enter the BIOS or CMOS setup. Reasoning: IBM compatible users may need to enter the BIOS or CMOS setup to setup or change how their computer's hardware is currently configured.
Should get ya back on line , Good Luck
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
