Question about Samsung ML 1210 Laser Printer
Unable to print
My computer recognizes my ML-1210 but, when I try to print, the system tray icon says that the document is being sent to the printer but nothing prints. Usually, the ML-1210 will warm up as though trying to print but the paper does not feed and nothing is printed. I have uninstalled and reinstalled the software, updated the driver, and cleared and restarted the print spooler in Control Panel, Admin. No help. I am able to printo to my HP printer (manual switch from the parallel port), so I do not think it is a computer problem.
  • 161 Answers
If both printers are connected through a parallel switch, be advised that changes on the switch do not take effect until the computer is restarted. Those boxes worked fine under DOS, but Windows does not support them. Connect the Samsung printer to the USB port and make sure you use a good quality cable and not those thin and cheap cables.
Posted on Sep 21, 2007
Why does my Samsung ML-3712ND printer say "paper empty in MP tray" when it is not empty?
The MP tray is the fold down 50 sheet tray that is built in to the front door of the Samsung ML-3712. It is usually used for thick papers, letterheads and unusual sized paper.
Sometimes people mistake the 250 sheet cassette tray that slides underneath the printer for the MP tray.
If you want to print on plain paper in your cassette tray and you keep getting this message.
1. cancel all print jobs
2. try printing a new document ( you can make a new word document with just one line)
if that works
Usually one of the settings in the print job you are printing will be out of specification ( could be too small margins) and the printer will be trying to feed from the MP tray
If the new print job doesn't work, the problem is likely in your default printer settings/properties
Dec 01, 2014 | Samsung Office Equipment & Supplies
My printer HP psc 1210 sys it is
When the system is unable to recognize the printer "offline" appears on printer icon. 1. Ensure that printer should be on condition.
2. Check printer USB cable both ends are properly connected or not, remove & re-fix .3. Insert in another USB port. 4. Replace with another USB cable.5. Replace Formatter assembly.(only professionals can do this activity)
Nov 29, 2011 | HP PSC 1210 All-In-One InkJet Printer
I have a Netgear PS121v2 USB printer server connected to my rounter and a Samsung Laser Printer ML-1250. For some reason I cannot print anything because the printer status indicates the printer is paused....
Try purging the pending print jobs then try to print again. Go to Printer and Faxes on XP, then right click on your printer icon then select purge print jobs. Or double-click on the printer icon on your system tray (lower right hand of the screen) then click on the pending print jobs then purge it. Then try to print again.
Oct 22, 2017 | NetGear PS121 Print Server
Samsung ml-1250 Printing stopped
Try purging the 3 pending print jobs then try to print again. Go to Printer and Faxes on XP, then right click on your printer icon then select purge print jobs. Or double-click on the printer icon on your system tray (lower right hand of the screen) then click on the pending print jobs then purge it. Then try to print again.
Oct 21, 2008 | Samsung ML 1250 Laser Printer
Document will not print
1. try right clicking the printer icon & use printer online
2. make sure print queue is zero otherwise delete them then try printing again
Jul 24, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP DeskJet 840c
pls. change your data cable of printer connected to computer
if it is work pls. remarks
Jan 30, 2008 | HP DeskJet 840c InkJet Printer
HP PSC will not print
Click Start (windows) icon - Control Panel - Printers. Right click on the HP PSC icon. Set the printer as default printer. Right click on the printer icon and select Set as default. Right click on the printer icon - Select properties - Click on Ports tab - Change the port to USB virtual printer port. Click Apply and Ok. Try to print. If the issue did not resolve. Get back to me.
Dec 11, 2007 | HP PSC 1210 All-In-One InkJet Printer
Can't print using USB connection
Unplug printer and un install software. Delete printer in printers folder. Restart pc. Install software first and then connect printer. Also make sure your usb drivers is correct.
Sep 29, 2007 | Samsung ML 1210 Laser Printer
My hp psc 1210 won't work with vista
I had a similar problem! Here is what eventually worked for me, after searching through postings for hours on end...
First, I made sure I had the new driver. Second, (and this might be different for you), my computer recognized my printer, but any time I sent something to print, it never made its way there. The little printer icon at the bottom said 1 document pending, then quickly said 0 documents pending, but nothing ever printed. When I ran HP diagnostics, it said everything was okay with the printer, and even printed a test page! But still nothing from any other program. So, eventually I went to control panel, then printers, then I clicked on the HP printer, then right clicked and went to properties. I changed two things in here, and I'm not sure which one was the solution. First, I changed the security settings (in the security tab) so that every user had access to all options for the printer. Second, on the advanced tab, I selected print directly to printer instead of the spool print documents option. And tada it worked!
May not solve anyone elses problem, but I didn't see this solution in any of the posting sites, so I thought I'd share it. Give it a try!
Aug 27, 2007 | HP PSC 1210 All-In-One InkJet Printer
Samsung ML 1210 Laser Printer Logo
154 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
