Lc320emx ce32os_1.0
No video or audio input through composite video or HDMI 1 on an Emerson 32 inch LCD HDTV
Check and replace its main power regulator board. It is not working. Might be faulty.
Jan 29, 2013 | Emerson LC320EMX 32 in. LCD HDTV
EMERSON LC320EMX WHEN TURN ON GREEN LIGHT FLASHES THEN GOES TO RED
Sounds like capacitor/s failing on the power board. This is a common issue and there is lots of literature and even videos on how to perform the repair on web. A shop will charge upwards of $200 for this repair yet if you find the components and only have them change those; perhaps they will work with you on cost. GL!
Sep 12, 2012 | Emerson LC320EMX 32 in. LCD HDTV
I fell asleep on my Emerson LC320EMX 32 hdtv remote; when I awoke, the tv was flashing ONLY colors (red, black,blue,white)...Now, How do I get it out of that mode....I was told its stuck in set-mode ?
I had this problem with the LC320EMX, after extensive searching on the internet, I found a solution. The TV has entered some kind of test pattern, to escape from the flashing color test pattern do the following:
While the screen is changing from red,green,Blue,White, & Black, and is Unresposive, Take your factory remote, Press the up arrow, then the down arrow, then (ON THE TV) press the power button. Turn the set back on and it should be functioning properly. (BTW: the set gets into this test pattern if you press too many buttons on the remote, or if you use a universal remote with the wrong code)
May 31, 2012 | Emerson LC320EM8 32 in. LCD TV
Emerson lc320emx remote sensor not working
Some advice--the sensor if bad requires the set to be opened and will be on a tiny board--whole board would have to be replaced as this company does not sell single parts (most now do not).
I would have the remote tested---most shops have a tester where remote is pointed at it---buttons (any or all) pressed to check it.
Some digital cameras when the remote is pointed at them will have a flash when the remote is used---
Either the remote or the sensor or something near the sensor is the problem.
If remote held very close to sensor and works----sensor is the problem most of the time.
Apr 16, 2012 | Emerson LC320EMX 32 in. LCD HDTV
Emerson LC320EMX stays in standyby mode
one of the transformers has an issue which is very common for that model. You can get a replacement inverter from www.tvrepairworld.com
Mar 31, 2012 | Emerson LC320EMX 32 in. LCD HDTV
Emerson replacement stand
Hi out there. I am in dire need of a pedestal stand for my emerson tv model # lc320emxf. Does anyone know where I can purchase one?
Dec 03, 2011 | Emerson LC320EMX 32 in. LCD HDTV
Hookup pc to emerson tv model number lc320emx
those models dont have video input for PC (video port), but if you computer has HDMI ouput you can use that one
Aug 12, 2010 | Emerson Televison & Video
Cant find code for emerson lc320emx toprogram to dish remote
Try 1465. However, you will still have to use your other remote to turn the unit on. :(
Dec 12, 2009 | DISH Network IR Remote Control
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
