Question about Sewing Machines
How to thread morse sewing machine model 3900
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: How to thread sewing machine Janome model 372
how to thread a janome model 372
Posted on Dec 27, 2009
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_477_threading_diagram.htm
Posted on Jan 23, 2010
  • 1116 Answers
SOURCE: I have a Singer Touch N Sew Model 636. The
I had a Golden Touch 'N Sew many years ago and as the machine aged and parts became worn, step 4 of this bobbin winding diagram started to become a problem and I had to sometimes try several times before the "tabs" would release. If they did not release, the machine "thought" it was still winding the bobbin and would not sew.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_2001_touch_tronic_threading_diagram.htm
Posted on Mar 06, 2010
What light bulb fits 4300 Morse sewing machine
The Morse 4300 and 4400 use the same small 15W screw in light bulb as many other sewing machines. This is one vendor: https://a1sewingmachine.com/LB716sm~Bulb%2C+15+Watt+Small+screw+in+base.htm . Another source is https://www.sewingpartsonline.com/light-bulb-white-7scw.aspx .
I hope this helps. However, if you have a bulb in the sewing machine, take it out and confirm that it is the screw in type. (If there is no bulb, look at the socket for some turns for threading in a bulb.) If the bulb or socket doesn't have threads, then look for a 15W push and twist bulb at sewing machine parts suppliers.
Nov 08, 2017 | Sewing Machines
I have a Morse Sewing machine Model 9400 I can"t find any information on this machine or that it was even made.can any one help with this
The manual is here in the main link. There is history below. The machine is imported from Japan.
Morse - NBWiki - Needlebar.org
www.needlebar.org/nbwiki/index.php/Morse
  1. Cached
  2. Similar
Jump to Morse Sewing Machine & Supply Corp - Morse was set up in 1948 as a US distributing ... Machines were imported from Japan via Mercury Machine Importing Company, ... of the public preferred machines of domestic origin. โ€ŽMorse Sewing Machine & Supply Corp ยท โ€ŽMorse Foto-Matic Zig Zag (MOD ...
What is the history of the Morse sewing machine company? - Quora
https://www.quora.com/What-is-the-history-of-the-Morse-sewing-machine-company Here's a website that gives a little history and information on some of the Morse sewing machine models: Morse - NBWiki.
Sewing Machines >> Morse Sewing Machine - PatternReview.com
sewing.patternreview.com > Forum > Sewing Machines
  1. Cached
  2. Similar
Jul 30, 2009 - 10 posts - โ€Ž6 authors I tried to get hold of Morse International Sewing Machine since they sell ... the Super Fotomatic from my little collection of machine history.
History of the Morse Sewing Machine ' eHow
www.ehow.com > Crafts
  1. Cached
  2. Similar
History of the Morse Sewing Machine. Morse sewing machines were introduced by Philip S. Morse in 1948. They are recognized for their versatility and ...
What company manufactures Morse sewing machines? ' Reference.com
https://www.reference.com > Hobbies & Games > Crafting > Sewing
  1. Cached
Pine is one of the companies known to have manufactured Morse sewing machines. Morse was established in 1948 as a U.S. distributor of these Japanese-manufactured machines. The Pine Sewing Machine Company was purchased by Singer in 1959.
What is a Morse sewing machine? ' Reference.com
  1. Cached
What company manufactures Morse sewing machines? ... The country of origin was either covered by a motor or the label was removed prior to the machines ...
Sew Chic Pattern Company: The Morse Sewing Machine, a question ...
sewchicpatterns.blogspot.com/2012/06/morse-sewing-machine-question-of.html
  1. Cached
  2. Similar
Jun 15, 2012 - I wonder about the history. How did this happen? Did they advertise to the right crowd? Was the machine too expensive? Made in Japan- were ...
Morse Sewing Machine ' eBay
www.ebay.com/bhp/morse-sewing-machine
  1. Cached
  2. Similar
Find great deals on eBay for Morse Sewing Machine in Sewing Machines. Shop with confidence.
Morse Sewing Machine Pictures
www.sewusa.com/Sewing_Machine_Pictures/morse_sewing_machine_pictures.htm
  1. Cached
  2. Similar
Pictures of Morse Industrial and Domestic sewing machines.
DOWNLOAD PDF 9400 sewing machine manual smm411pdf Machines name begins...
Oct 30, 2016 | Sewing Machines
Hi! I'm looking for a manual for a vintage Morse 550 zig-zag sewing machine. Need help with tension assembly.
manual for a vintage Morse 550 zig-zag Kathleen, Check the attached links,manuals and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Morse 550 zig zag manual Google Search
Morse 4300 Zig Zag Sewing Machine Instruction Manual Fotomatic III
Morse Pushbutton ZigZag Sewing Machine Threading Diagram
http://www.sewusa.com/Sewing_Machine_Manuals/Morse_Sewing_Machines.htm
Mar 31, 2016 | Sewing Machines
Morse zig zag mzz sewing machine needle cutting thread
change the needle--one that is correct for the fabric being sewed
check the needle plate and see if there are any burrs--if there
are gently use a small file to take off the burr
check with sewvacdoctor.com,,,or ,,a1sewingmachines.com
or sewusa.com about a manual,,, you'll have to call them or
email them about the manual..
the tenison dial may need to be replaced.
Dec 17, 2012 | Sewing Machines
Sewing Machines Logo
96 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
