Question about Garden
How do you tighten bolt cutters - Garden
How do i fix my bolt cutters
you can try tightening all the pivot bolts but generally when this happens there is not much that can be done but to junk them
the secret with bolt cutters is to get the size that is 3 times the size of any bolt you intend to cut as cutting a maximum size bolt on smaller cutters is what puts them out of line
Jun 15, 2016 | Air Tools & Compressors
How to service gear case on Honda435u brush cutter
Under normal cercumstances you don't require to service this, except greasing the gears and that is done as... There is a L key bolt on the right side of the pipe (you should own a L key set) above the blade you are useing,,open the bolt in the normal direction means anti clock wise than insert grease in to the opening till it doesn't start coming out by it self that means its full. Replace the bolt but don't tighten it too hard because it can create problem to open next time.when you now run the brush cutter it will run smooth. On ther hand if there is any other problem than this like gears are broken or something than replace the entire assembly
Sep 24, 2014 | Garden
Why won't it turn over?
Have you checked the battery?
Aug 27, 2014 | Cars & Trucks
Stihl hs86 set blade gap
You shouldn't have to set a gap.. the gap between the blades is 'pre-determined' by a spacer between the blades that each 'blade bolt' passes through. You should be able to tighten up the blade bolts and the blades should still move. If they dont, then the spacers are worn and need to be replaced.
Apr 02, 2014 | Stihl Hedge Trimmer Pruner Cutter Blade...
My blades are a little dull will the blades still cut through a bolt?
You shouldn't really be using dull bolt cutters because it requires more force to cut through the metal which increases the likelyhood that you will get an injury. Yes you can use dull bolt cutters but you should always make sure that your blades are sharp before you use them.
Nov 14, 2013 | Cutter Tools
Are bolt cutter blades really sharp?
A pair of new or freshly sharpened bolt cutters will be sharp enough to cut through skin if you run your finger along the blade. Never run your finger along the blade to check for sharpness.
How to remove and replace Tata Indica gearbox
not a bad little car i think,done one last year for a new clutch and i it was that easy that i honestly do not remember having any problems with it ,only one tip i will offer though and i do this on all motors and thats to drill a hole in the bellhousing with a hole cutter big enough to get a 10mm socket 1/4 drive through the hole to tighten the clutch bolts ,getting to old to struggle now so i make a hle that aligns up with the clutch bolts then fit bolts holding the clutch finger tight then once the box goes in nice and easy as the clutch plate can move a bit then two big bell housing bolts in and then rotate the flywheel twic tightening the bolts one by one .easy better than hurting ones back with a struggle
Apr 13, 2012 | Tata Indica Cars & Trucks
The whole streering wheel locked how can we unlock it
Faulty steering lock only method here is to cut the whole lock off with a radial cutter you may even have to remove the whole steering column to get to the lock as the fititng bolts have shear headed bolts which break off on tightening
Mar 17, 2012 | 1998 Dodge Caravan
The pull cord for starting the cutter has detatched
normaly there is 4 bolts holding the cover on take them out and the pull clutch in under there,,, put the string back in the cover and tighten the clutch up first so it pulls the strin in when you let it go,,,tiy a good knot in the pull start string or you will just pull it out again!
Jul 01, 2010 | Ryobi Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
