Question about Eclipse 180G2 MP3 Music & Video Player
My eclipse mp3 player wont connect to rhapsody
Does it work with Rhapsody?
5 Suggested Answers
  • 4 Answers
SOURCE: Eclipse MP3 Player
The official unofficial REAL Answer is here!!
I swore it off as Junk untill I took the time to figure this out.
When charging the power swith needs to be in the "ON" position.
Charge for around 3-5 hrs.
To turn device ON You hold down the Play/Pause button for quite some time, (much more time than expected from other players,cellphones or devices) the unit should power up and display "ECLIPSE".
I thought I was "taken" and strange when I saw the link for Qresolve within the files of something that did not work.
Theres even an EQ feature in the Menu and the sound is pretty decent. Good Luck!
Posted on Apr 08, 2010
Aeryskelle
  • 7 Answers
SOURCE: Eclipse MP3 Player- Wont charge. I plug it in and
People on other posts said to get a wall charger and that'll work. We looked for one, but couldn't find one. We ended up using a usb camera upload cord that had the same connector. It charged just fine after that. We have a 180 Eclipse mp3 player...I'm guessing the cord connectors are pretty universal.
Posted on Apr 09, 2010
SOURCE: eclipse mp3 player says "no file"
I had the same problem. I think most files that itunes uses are in a .m4a format. The eclipse mp3 player will need all the music files in an .mp3 format. The eclipse actually has a "software" folder that includes the "replay converter" that will convert these files for you - or you can download any number of freeware that will convert the files as well. Once I converted those files, my eclipse played everything. Prior to that - even though I had synced everything with my Windows Media player, I was getting the "No Files" message. Good Luck!
Posted on Oct 08, 2011
amandazhong2
  • 54 Answers
SOURCE: My Eclipse Mp3 Player Wont Play
1) There's a difference between "support" and play directly of video mp3 player.
2) It's not just about the format, but also screen size and resolution.
You need to run the music through the converter tool that is on the player itself (like a portable dirve, look into it's directories) or as a small CD that came in the player's kit.
Posted on May 11, 2012
Sandisk sansa 10gb mp3 player got formatted and my computer wont even read it
Depending on what kind of OS you are running you may be able to reinstall the software that came with your Sansa. The problem of not reading your mp3 may be that it is plugged in to the same USB port over and over again, try different ports. If that doesn't work try downloading Rhapsody, i use it for my mp3 players and it works great.
Here is a link for the Rhapsody player:
http://www.brothersoft.com/downloads/rhapsody.html
Oct 19, 2009 | SanDisk Audio Players & Recorders
The screen says" rebuilding the library, please wait"
Rhapsody (if that's the program you're using) uses a database file to store your library information on your computer (locally). Every time you sign into Rhapsody, this database must synchronize its contents with the Rhapsody servers. Sometimes your local Rhapsody database goes out of sync with the main Rhapsody servers, causing trouble with your library or playlists.
If Rhapsody is unable to resynchronize, you may get this error message. This error can also be caused by local database corruption or security settings blocking the connection to the server. To resolve this issue:
1. First, close Rhapsody, then re-open it and try again.
2. Try resetting your Internet Explorer privacy / security settings for Rhapsody
3. If that doesn't work, try resynchronizing Rhapsody with the server running a simple tool called dbclient
To run the dbclient:
Open My Computer.
  1. In the C: drive, browse to Program Files.
  2. Open the Rhapsody program file folder usually named 'Rhapsody'.
  3. Double-click the dbclient program in this folder (Vista users: right-click dbclient and select Run As Administrator).
  4. When the Success dialog box appears, click OK.
  5. Start Rhapsody and sign back in.
Let me know if this works
Hope this will FixYa problem
Moises
Jan 21, 2009 | Insignia NS-DV2G MP3 Player
How do i convert my rhapsody music files to play on my mp3
You have to get Rhapsody's Mp3 only service - I repeat, MP3 ONLY. No other level of Rhapsody service will work with the newer Philips' GoGear's - which is funny, b/c Philips co-branded with Rhapsody on the newer players.
-Tha Mp3 Doctor
Dec 28, 2008 | Philips GoGear Flash MP3 Player
Trying to synch my SanDisk MP3 player to Rhapsody
This player is a little goofy. The normal method to synchronize is through Windows Media Player. But if you go for the Rhapsody subscription, you have to also sync the device through Rhapsody.
-Tha Mp3 Doctor
Nov 13, 2008 | SanDisk Sansa Clip MP3 Player
Transfering music from rhapsody to player
you have to get the Rhapsody Mp3 Only subscription - any other subscription level will not work with this particular mp3 player - check out Rhapsody's website for details on this
Aug 09, 2008 | SanDisk Sansa e250 MP3 Player
NEED HELP!!! Rhapsody Software Download Problem
Okay...MacAffee is causing problems with your connection and with the download/update. You will need to right click on the MacAffee icon in the system tray (bottom right of the screen) and open the program to turn it off (or just quit the program). Also make sure your firewall is down when doing this.
Re-install BBDMS (aka Rhapsody), and allow the update to happen. Once this is complete (assuming that MacAffee is the only anti-virus software running) launch the program, connect your MP3 player, and "authorize" the player on your computer.
This should take care of the problem.
I would also recomend a different anti-virus and firewall program. AVG isn't as invasive, and PCTools firewall will allow you to configure what programs are allowed to use the internet.
Jun 10, 2008 | Insignia NS-DV2G MP3 Player
Open McAfee -go To Settings - Firewall -disable
May 10, 2008 | Samsung YP-K3 MP3 Player
Computer wont recognize the PlayForSure
Try getting windows media player 10 or 11
May 05, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e60
Try using WMP or explorer to transfer songs
Jan 05, 2008 | SanDisk Sansa e260 MP3 Player
E250 mp3
The "please sync" error means you need to connect to Rhapsody and sign-in. It will update your licenses so you can play the music.
If thats not working, your account is expired, or Rhapsody needs to check your account.
Rhapsody Support (866)597-5505
Best of Luck.
Oct 14, 2007 | SanDisk Sansa e250 MP3 Player
Open Questions:
Eclipse 180G2 MP3 Music & Video Player Logo
141 people viewed this question
Top Eclipse Audio Players & Recorders Experts
henrysmooth
Level 1 Expert
Joseph Hoffmann
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
