Microsoft PowerPoint 2007 for PC Logo
Anonymous Posted on Apr 01, 2009
Adding audio to power point presentation
I am trying to add a narrative to a PPT. The file become too big, over 30mb. I tried to add a compressed audio file using real producer basic. When I tried to attach the file to the PPT it does not let you imprt an .ra file. You can imprt aiff, au, midi, mp3, wav and wma. How do I attach a compressed .ra file to the PPT. There were articles saying this is the best way to add audio to a presentation, and gave the steps to follow, but I hit a snag when I try to attach the .ra file.
Anonymous
Level 2:
  • Expert 52 Answers
  • Posted on Apr 04, 2009
Anonymous
Expert
Level 2:
Answers
52
Questions
0
Helped
28581
Points
106
Try using this software
http://www.rm-mp3.org/
to convert the .ra file to mp3. Then you should be fine.
1helpful
5answers
Powerpoint 2003 corrupt problem
1. Go to the directory where the file is located.
2. Right click on the file
3. Select properties
4. The Type of File, should be PowerPoint Presentation
5. Opens File field should be PowerPoint.
If it doesn't have this, then select the change button & select PowerPoint from the list of applications.
6. Select Ok & then Apply and OK again
7. In case this guide wasn't effective for you, then make use of professional online recovery service for corrupted .ppt and .pptx files https://onlinefilerepair.com/en/powerpoint-repair-online.html PowerPoint repair online
1helpful
3answers
How do I recover a corrupt PowerPoint 2013 presentation?
You can try:
PowerPoint Repair Toolbox is powerful .PPT repair software, resolving any problem, causing the damage of PowerPoint files. This tool guarantees the compatibility with all available software configurations therefore PPT on repair of reinforced concrete structures works anywhere in the network.
For more information: https://www.pptrepairtoolbox.com/
2answers
How do I burn dvd power point?
Just use NERO, and you will be offered to burn all kinds of projects.
I think for a Power point presentation, it could ne just a data disk. Unless you want to run it automated. I'm not sure it is possible from a DVD without toy having a powerpoint (viewer) installed on the computer.
1helpful
3answers
Message in Powerpoint: Part of the file is missing. How to fix it?
your powerpoint file seems to be severely corrupted. You may try to open this file in PowerPoint Fix Toolbox http://www.powerpoint.fixtoolbox.com/
If if it useless follow the steps 1) Open a new presentation and use Insert --> Slides --> From existing presentation to pull in the slides from the corrupted file. This works about 50% of the time.
2) Try using the Clone Me add-in from Microsoft. It may work, it may not.
Or see more http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/679-could-you-help-me-with-recovering-ppt-file
1helpful
2answers
I want to open powerpoint presentation.
then, go to format -> slide design, choose to show all documents, and choose the corrupt powerpoint file. now, go to insert -> slides from file, and select the corrupt powerpoint file. make sure you are set to insert all slides, and then import. if that works, great! i suspect, however, that you might crash at that point. if so, try repeating the process, inserting specific slides one by one until you find the problem one. after that, save the file, making sure that fast saves are off (in preferences / save).
if you are unable to open your powerpoint files then try pptx viewer tool. this utility recovers your corrupt and damaged powerpoint presentations (.ppt, .pot, .pps, pptx and ppsx formats) from ms powerpoint files. http://www.pptx.viewertool.com/
visit:- http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/1128-how-do-i-recover-a-corrupt-p-point
http://www.pptx.viewertool.com/ http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/1128-how-do-i-recover-a-corrupt-p-point
1helpful
4answers
It's me again! i hade a problem: I would like to make a slide show for a dvd with pictures,and that repeats itself.what program,and how should i use(i have windows xp)!and after i would like put the disc...
Moyea PPT to Video/DVD/Blu-ray Burner
It is an all-inclusive conversion tool that helps burn PowerPoint to DVD and Blu-ray Disc playable with DVD or Blu-ray Disc Player on TV and turn PPT to video convenient for portables, while keeping complete of PowerPoint originals like animations, sounds, slide transitions and video clips.
As PPT to DVD/Blu-ray burner, it features a powerful burning engine, a good host of DVD/Blu-ray menu templates, a cool choice of custom watermarks, and 2 flexible chapter schemes One Animation One Chapter, One Slide One Chapter.
As PPT to video converter, it enables you to convert a PowerPoint presentation to any format of video, e.g. AVI, MPEG, FLV, 3GP, MP4, VOB, WMV, MOV, etc.
3answers
Large PPT to video
Regarding converting ppt to video, these are many free powerpoint to video converters at:
http://www.masternewmedia.org/convert-powerpoint-to-video-guide-to-the-best-free-services/
If you are not care much about the conversion effect, you can use these tools.
If you want to get the best conversion effect that convert your presentation with all the animation, music, and videos retained, please try Acoolsoft PPT to Video.
1helpful
3answers
Problem running power point with embedded video file on projector
I too got the same problem once.But some how i had managed to solve it.Actually it is due to the corrupted header of the ppt file i.e the system can read ppt location of the memory but unable to reach the video file .The solution is you just need a powerpoint 2007 file recovery tool.The tool i used is provided here.Why i am recommending the tool is it makes a copy of the ppt and then repairs it .so there wont be any further damage.The demo version is here.If satisfied with demo reach the full version of it as i did ...
2answers
I have an Infocus LP10 that I use every day. I hook it up and have never had a problem until today. The camera is not showing my PPT presentation. I only get the Infocus "the Big Picture" ad...
First of all, make sure that the correct input is selected. Second, it is possible that the input card has a problem. Try reseating this board. If that fails, please update this and I'll try to provide other options.
Dan
4answers
Adding music to a powerpoint presentation
Does the music file play when you click on it? (Drag the sound icon someplace visible on your slide and preview it.)
If it does play when you click on it, you just need to animate the music. The sound file has to be a part of your slide animation--that's what tells it when to start/stop playing. When you insert a sound file, PPT may ask you whether you want it to start automatically or wait to be clicked.
Or, you can right-click an existing sound file and go CUSTOM ANIMATION. Depending on your version of PPT, what happens next will be different. But you should be able to set the sound file to play when the slide displays without being clicked.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
