Question about Sony Audio Players & Recorders
How much will an audio amplifier ic cost
Shows push power protector message on the display. None of the speakers are connected but still displays the message. From several solutions on net, got to know that amp ic could be the reason. SO I need to know the cost of 1 audio amp IC. Please help
    Genius:
  • Sony Master
  • 1,054 Answers
What model #?
Posted on Jul 29, 2013
  • Zenali Jul 30, 2013
    Thanks for asking. DAV-DZ570
SOURCE: "Protect" and "Push Power"
i have a sony component push power protect, i have already replace IC but still protect push power
Posted on Jun 21, 2009
  • 788 Answers
SOURCE: f61 error code
Sorry to hear about your error code F61
This code refers to a High Limit Temp. condition.
This is most likely caused by the cooling fan.
If the Fan has stopped running or not running at full speed, you will recv. this error message and the temp. reaches high-end limit.
Please check the cooling fan, any possible air flow restrictions and correct running RPM.
Hope this information has helped you.
Readers, please rate your technicians information.
Thanks,
John Ray
john@johnrraycomputer.com
Posted on Jul 12, 2009
dmftrucker
  • 1922 Answers
SOURCE: IT DISPLAYS PROTECTOR PUSH POWER
its in standby, try it again, if it does it repeatedly theres a problem in the switching power supply not letting it power-up to save components
Posted on Oct 18, 2009
SOURCE: Push Power Protector
As had already been stated by several people, the "Push Power Protector" scrolling marquee means that you have a short in one or more of your speaker wires. This is an easy problem to fix. First, trouble shoot which wire(s) has the short by unplugging all 6 speaker wires from the back of the unit. Then turn on the unit and switch the function to "Tuner FM." That way when you start plugging the wires back in, you will have sound (music) playing out of the speakers you plug back in, thus ensuring that that speaker wire doesn't have the "short." Now, with the unit on, start plugging in the wires one at a time in the following order...Green, Purple, Red, White, Grey and then Blue. Somewhere in that sequence, you will find that the unit shuts down and the scrolling marquee of "Push Power Protector" comes back on. Viola! You have your short. For me, it was the Grey wire because I had spliced it with additional wire to reach the back of my room and the splice was touching, thus creating the short. I placed a little more electrical tape on the splice to keep it separate and I am back in business! Good luck! :)
Posted on Jan 30, 2010
SOURCE: "Push Power'' and ''Protector"
my sony bravia is KLV-32S400A. i tried to stop the dvd playing and turn off the home theatre, but the tv is still on. suddenly there was a loud blast sound and the home theatre shows PUSH POWER PROTECTOR.
please help what should i do with it?
Posted on May 21, 2010
NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Jan 23, 2012 | NAD M3 Master Series Integrated...
Push Power Protector?
This indicates that you have a blown output amplifier or shorted speaker wire. Disconnect all the speaker wires and try to turn it on once more. If it shows the same display give it to a service center for repair.
Mar 10, 2011 | Sony DAV-HDX500 System
Have recently had an "overload" displayed. Have
HI:
Usually receivers go into overload due to a bad speaker make sure you disconnect the speakers also to make sure its overloading from a bad speaker. If the unit still shows overload even with all speakers disconnected, then your main amplifier output has a short usually a shorted output transistor is the cause. Unplug the speakers one at a time to and turn the unit on after disconnecting one of the speakers , to determine which speaker is at fault.
Jan 23, 2011 | Panasonic SA-HE200 Receiver
I have Home Theater Sony DAV- DZ151Kb. Display Push Power and then PROTECTOR. I need Help
Push power protect message appears when home theater got problem in amplifier output section and any output amplifier chip becomes bad, receiver set protection mode and refuse to power up to avoid further damage in circuit board.
It is very hard for novice to troubleshoot what output chip is defective out of six amplifier output ICs in unit, check by professional is needed to solve this issue.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Jan 14, 2011 | Sony Audio Players & Recorders
Its displaying push power n protector on my av system
Unhook all speakers to the unit and then turn it on...see if the problem goes away. If it does, then one of the speakers may be damaged...If not, then the amplifier circuitry has some sort of problem, possibly the output transistors/IC's are defective...If it is the latter you will need a technician to troubleshoot the amplifier to find out what the extent of damage is
Jan 08, 2011 | Sony DAV-HDX500 System
My pioneer AV reciever last shows in the display a "amplifier error" then suddenly the power shut-off. aftr that i power on again but the reciever do not power on again. I remove all the...
The real problem is already informed you by the unit itself.
For us technician it was obvious that you have a faulty output I.C.
Your unit automatically shuts off to avoid further damaged most especially to the speakers.
I've advice you to look for a qualified technician/service center to replaced the output I.C.
After that your unit will back to normal again........
Jan 03, 2011 | Pioneer Audio Players & Recorders
I have a sony DAV DZ230 home theatre system
on my home theater display it shows protector push power
Nov 24, 2008 | Audio Players & Recorders
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
