Question about Refrigerators
Pro max rg5410a recovery machine
The recovery machine turns on but does not recover the refrigerant. Is the pump bad or the relay on the motor?
2 Suggested Answers
john224
  • 1378 Answers
SOURCE: Hayward Max-Flo pump: Need to separate pump from motor
Remove the back cover from the motor, lock the shaft in place, thread off the impeller.
Posted on Jun 14, 2009
How can i sell this used ice cream machine?
I would try Craig's List first.
May 18, 2015 | Refrigerators
I have a 2000 Hyundai Sonata 4cylinda fans not moving whats the problem
If its an electric fan, it could be the a) Bad or broken connection b) Fan motor needs to be replaced c) It has a "bad temp. sensor or d) something might be wraped around fan preventing it from turning
Sep 02, 2013 | Cars & Trucks
Robinair model 34288 will not stop recovering
what is the pressure reading on your guages? if it is below 0 if so the vacuum pump should kick on. if the vacuum pump keeps turning on and off check the software version on the machine if it is not 3.09 or 3.11 the software needs updated contact your local robinair service center. if it is not the software then the recovery solenoid may be sticking closed and will need replaced.
Jul 07, 2012 | Robinair Cool Tech 34700Z Recovery,...
Blower motor need a page from the book to fix it and it location
Component
Blower Motor Below right side oft?
Blower Motor Relay . In engine compartment fuse relay box
Blower Motor Resistors Below right side oft?
Blower Switch Below center oft?
Engine Compartment Fuse Relay Box Left side of engine compartment
ignition Switch Below left side oft?
Cl90 (68-LT gry) Left side of engine compartment (fuse relay box)
C20l (20-W HT) Below left side oft'?
C225 (13-Will) Below right side oft'?
Q216(8-WHT) Below right side ofi?
0203 Below left side oft'?
Blower Removal
1. Discharge the refrigerant from AC system. (Refer to the operating instructions of
your refrigerant recovery recycling charging station for proper procedures.)
2. Disconnect the inlet and outlet pipe from the evaporator.
NOTICE
- When connecting and disconnecting, refer to Quick Coupling below
- Immediately plug all open fittings to keep moisture out of system.
3. Remove the cover and drain hose.
4. Remove the glove box and disconnect the wiring harness connector.
5. Remove the blower unit.
6. Install in the reverse order of removal.
7. Evacuate the refrigerant system. (Refer to the operating instructions of your
refrigerant recovered cycling charging station for proper procedures.)
S. Charge the AC system. (Refer to the operating instructions of your refrigerant
Recovery recycling charging station for proper procedures.)
Dec 16, 2010 | 1998 Kia Sephia
Air con has been topped up to pressure blows hot ok but is not cooling on cold only a slight improvement after topping up
Is compressor clicking on and off?
If its not here is alist of items to check out:
-pressure switches
-compressor
-on/off switch
-a/c relay,
-cooling fan relay
-cooling fan
-control head
Remember there is no such thing as just topping off. The refrigerant doesn't evaporate. It is in an enclosed system air tight always under some pressure whether on or off.
So if someone told you that you were low on refrigerant what they should have explained this to you. Basically you may have a leak.
If you have a set of R134A manifold gauges put them on and ckeck for refrigerant being present in the system. If your below 50 psi on high side you probably have a leak. Checking for leaks on a 2003 is not so bad .First try looking for oil spots on the refrigerant line . If that doesn't work then bring the vehicle to a repair shop. they have the proper equiptment to do this. If you do find the leak via oil spots you have to recover the refrigerant thats in the system with a recovery machine first. Then replace the o-ring at the connection that was leaking or remove/ replace the item that was leaking.
Your gonna need a vacuum pump or recovery machine for the next part. Pull a vacuum on the entire system for 20 minutes then shut off the system and check for leaks. If manifold gauge on recovery machine doesn't move within five minutes you can recharge the system. Good luck
Jun 18, 2010 | 2003 Kia Sedona
Wont recover
Please Check the following:1# Press recover & fix a vacuum gauge on your machin Compressor suction port & monito the gauge is going up to13"HG suction,if not then you may need to replace the compressor.2# Check spin on-filter weight(total amount of refrigerant you have been recover since last filter changr,Max.filter Capacity is 68KG/150LBS) if it's more then max.cap. replace the spin on-filter.3# Check low side clearing sensor (Vacuum sensor) for proper operation.4# Also you can try to reset (clockwise & counter clockwise) automatic expension valve for any block of refrigerent flow.
May 25, 2010 | Robinair Cool Tech 34700Z Recovery,...
I have a robinair 342000 and it will not recover need help what do i do to fix
May 24, 2010 | Robinair Cool Tech 34700Z Recovery,...
High presure rest on robinair 34788
It's seems to be problem with your unit relay board,vacuum pump or pressure transducer.Most of Robinair 34788 machine having same problem.You can try the following 1# Open vacuum pump oil filling cap to release extra pressure from pump.2# Replace new relay board & follow the on screen message(do not skip any option).3# Check pressure transducer is working properly.I hope this will help you.
Aug 09, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair model 347002k has a problem with leaving a half pound in the vehicle after recovery. i have to recover again sometimes two or three times. what could be the problem. also the display says replace...
Please change your machine spin-on filter & vacuum pump oil immediately,becaus you already exceed maximum limit of filte.( NOTE:max.cap.of filter is 150 lbs ) if you keep using machine without changing filter then compressor will get damage at any time. Recovery is not compleating also because of that & do not skip clearing before any recovery.hope this will 100% solve problem.
Aug 07, 2009 | Measuring Tools & Sensors
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
