LG intellowasher 7.2kg WD-1021WF, settings for washing
2 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Manual for LG Intellowasher 7kg
While not exact to your model,this manual may answer your questions.
http://136.166.4.200/contents/Laundry/WD-1070FH/WD-1070FD_Service_Manual.pdf
Posted on Sep 08, 2010
Need basic operating instructions for LG Intellowasher WD-1255FB
Hi
U can download manual here
http://www.lg.com/za/support-product/lg-WD-1255FB
Oct 04, 2015 | LG Washing Machines
LG intellowasher 7kg wd-8015c
SURE VINEGER IS VERY GOOD ON CLEANING WASHER
May 02, 2014 | Washing Machines
Lg intellowasher wd 10160f
Check the Lid Switch Assembly with an Ohm meter for continuity, these switches are a common problem. Replace the switch assembly if faulty.
Mar 18, 2014 | LG Washing Machines
Need the operating manual for a lg intellowasher 7.5 wd-1018c
go to www.lg.com/au then click on product support left hand side of screen then type in wd-1018c in search box under box high lighted in red wd-1018c washing machine comes up. click on it. half way down page down load pdf for manual
Oct 10, 2010 | Washing Machines
I have an intellowasher made by LG WD1023C I have
This means -Child Lock trying to solve the problem myself- I think by pushing 2 buttons together... but which ones?
Aug 16, 2010 | LG WD-1080FD Front Load Washer
LG Intellowasher (Model WD-1023C)
The water pump can be blocked and thus stop the machine from finishing the wash cycle. In front on the bottom there is as hatch that can be opened with a flat screwdriver, the small black rubber pipe can be used to first drain all the water before the opening the filter. Small objects such as coins coluld be found in here, blocking the pump. Clean the pump by removing these, optionally blowing into the outlet (yuck!), to dislodge anything. If that does not help to fix the problem, you can clean that actual water pump, but this requires you to use a screwdriver to remove the pump.
Tilt the machine on its side, the pump is attached with 3 self-tapping screws. (if you can't figure out what the pump is you should probably let a technician do this). The pump has 2 parts to it, take it apart carefully and clean out all the dirt that has accumulated in there. Plastic friendly, waterproof grease can be applied to the pump spindle and bearing if available.
If the problem still persists a new pump is available from LG at a reasonable cost.
Jul 30, 2010 | LG Washing Machines
Hi i need an instruction manual for an LG
If you google the brand and model you will get a lot of info and/or a locality where you can request a manual....Good luck.........Nomess
Apr 16, 2010 | LG WD-1041WFH Front Load Washer
Lg intellowasher wd-8013f is very noisy
You suspect right.
It is a complete strip down job. I have just finished mine.
taking apart and reassembling is not too dificult.but you need to make up a tool to remove and replace the bearings which are two different sizes. It consists of a lenghth of studding, bolts and washers.
Download the manual from LG.
Good Luck
Mar 17, 2010 | Washing Machines
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
