Question about Cub Cadet Riding Lawn Garden Tractor 25hp Kohler 50"
Remove clutch how to remove clutch
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 94 Answers
I'm assuming you're referring to the PTO clutch on the bottom of the engine shaft. There's a 5/8" bolt that goes up through the clutch into the shaft. Remove it, but then turn it back in about 10 turns and use a wheel puller to start getting it off. You might have to c-clamp the PTO/clutch top and bottom together to get both pieces off. Once the assembly starts coming down the shaft, you can probably remove the wheel puller, remove the bolt completely, and pull the PTO/Clutch off by hand. Be sure to unplug the PTO/clutch before removing it. Also, many of these have a spacing washer on top of the PTO/Clutch that comes off in the process. BE SURE to put it back on before replacing the PTO/Clutch. DO NOT hit anything with a hammer to try to break it loose - you'll most likely NOT get the part off and most probably WILL damage necessary parts.
Posted on Jun 30, 2014
How do I remove the clutch
Remove the power unit, remove the plastic clutch/ starter cover, install a piston stop, with a t25 torx driver inserted down the center tube on the clutch drum remove the clutch drum, then using the proper clutch tool remove the clutch paying attention to the arrow stamped on the clutch- usually left handed thread. be sure not to lose small washer between clutch and drum.
Aug 31, 2014 | Yard Machines Cultivator 21A-121R900
Removing clutch drum
Use this pic for illustration purposes:
http://www.bikebandit.com/houseofmotorcycles/2003-yamaha-tt-r225-ttr225r-clutch/o/m145616sch256422
Remove (4) clutch springs and bolts (Items #11 & #12)
Remove clutch pressure plate (#10)
Remove clutch hub nut (#21)
Pull clutch assembly off.
Mar 17, 2014 | 2003 Yamaha TT-R 225
HOW TO REPLACE CLUTCH FAN
to remove clutch fan you need to remove upper fan shroud, you need large wrench to remove the fan clutch retaining nut to remove fan and clutch away from the engine drive belt should keep pulley from turning while loosen fan clutch retaining nut.if pulley belt turns while loosen fan clutch bolt remove drive belt use strap wrench hold pulley while you remove fan clutch bolt this procedure for checvrolet if you working on volkswagon you need spanner wrench hold the idler pulley while you use large wrench to loosen the large drive nut to fan clutch. you have to remove fan with clutch from engine then you can remove clutch from fan you can go to auto parts stores rent a spanner wrench try auto zone they rent out tools.
Jan 05, 2012 | Cars & Trucks
How do i pull the clutch assembly on a 84 fxrs
Disconnect the battery. Drain the primary oil and remove the outer primary cover. Remove the four bolts that hold the clutch spring in. Remove the clutch spring and pressure plate. Then, you can remove the friction and steel plates. If you want to remove the entire clutch assembly, you'll have to remove the nut from the transmission mainshaft and remove the sprocket shaft nut. The mainshaft nut that holds the clutch assembly on has LEFT-HANDED THREADS. Once you get the nut off, you'll need a clutch puller to get the clutch assembly off the tapered transmission mainshaft. Get one of the pullers that screw onto the mainshaft and you rap it with a hammer. You do not have to disassemble the clutch assembly completely to remove it from the mainshaft. You can take it off as a unit by removing the snap ring in the center and removing the adjuster plate. Remove the sprocket shaft nut, the chain adjuster nut, and the mainshaft nut and remove the engine sprocket, primary chain and clutch assembly all together.
Good Luck
steve
Jun 10, 2011 | Harley Davidson FXR Super Glide...
Replacing AC clutch....did not ask if it should be done...asked how to do it. Answer the question that was asked!
Hi:) For Ford Compressor Clutch Removel
Step 1
Locate and remove the compressor clutch retaining bolt. Looking at the compressor clutch you will see a bolt in the center and three bolts along the outer edge. The center bolt is the retaining bolt. The three bolts around the edge of the clutch can only be accessed after removing the clutch, and are only relevant in clutch repair situations. To remove the retaining bolt you need to maintain the clutch position and relieve pressure from bolt head by applying the compressor clutch holding tool with your other hand, or have an assistant hold the tool in place. Do not lose the retaining bolt in case you need to reference it later.
Step 2
Separate and remove the clutch from the shaft of the compressor. Once the retaining bolt is removed, as described in Step 1, simply pry the clutch away from the mounting surface using your hands. If the clutch is a little difficult to remove due to damage or decay then try using a screwdriver to lightly pry the rear side of the clutch away. Spray the area with an auto lubricant and allow it to sit overnight if needed. While removing the clutch do not lose clutch spacers.
Step 3
Pull the snap ring from the clutch pulley using your snap ring pliers. You will now be able to remove the clutch pulley from the compressor. While everything is apart, and before installing your new compressor clutch, clean the area to remove dust or grime.
Reverse steps to install.
Mar 05, 2011 | 1998 Mercury Grand Marquis
Zx-9r 2000 how do you remove the clutch side cover to change the clutches
The clutch cover is removed in a two step process.
  • Remove the clutch cable by loosening the adjustment at top and bottom first. Then remove the cable end from the clutch lever. This should give enough slack to remove the cable at the bottom by the clutch cover. ** Take notice of the angle of the lever that the cable goes into the cover. You will want to re-assemble the clutch cover with that lever in the same angle.
  • Remove the clutch cover bolts around the outside of the cover.the cover should now be removed by pulling the cover straight out.
Thanks and I hope that this helps.
Steve
Jan 21, 2011 | kawasaki ZX-9R Motorcycles
Removal and installation of 1988 harley sportster clutch
In order to remove the clutch from your bike, you must have a special tool. You'll need H-D #34761 in order to remove the snap ring holding the clutch together.
Disconnect the battery, drain the primary, and remove the primary cover. Once you have the primary cover off, you can remove the nut from the compensator sprocket at the engine end of the primary chain.
Install the H-D 34761 or equivalent tool and compress the clutch spring. Remove the snap ring and then back off on the tool to release the pressure on the clutch spring. Once the pressure has been removed, remove the adjusting screw assembly, the outer clutch spring seats, the clutch spring, the inner clutch spring seat, and the pressure plate.
Then you can disassemble the rest of the clutch. Remove the remove the four friction plates and three drive plates. Then you can remove the spring plate and the remaining plates after that. Remove the snap ring that holds the clutch assembly onto the transmission clutch gear and remove the inner and outer clutch shells, the primary chain, and the engine sprocket as a group.
For this job, I would recommend that you purchase a service manual. It's has pictures that show you what you're dealing with and in this case, a picture is truly worth a thousand words.
Good Luck
Steve
Nov 05, 2010 | Harley Davidson XL Sportster 883...
Info on do it tyour self clutch removal on 2001 mustang 3.8
REMOVAL:
  1. Lift clutch pedal to uppermost position to disengage clutch and brake pedal pivot shaft.
  2. Push clutch and brake pedal pivot shaft forward and unhook clutch release lever cable from clutch and brake pedal pivot shaft and allow it to slowly swing rearward.
  3. Raise and support vehicle.
  4. Remove clutch release lever dust shield.
  5. Disconnect clutch release lever cable from clutch release shaft.
  6. Remove retaining clip, then clutch release lever cable from flywheel housing.
  7. Remove starter motor from flywheel housing, then engine rear plate to front lower flywheel housing bolts.
  8. Remove transmission.
  9. Remove flywheel housing back just far enough to clear clutch pressure plate, then remove housing.
  10. Remove clutch release shaft from flywheel housing by pulling it through window in flywheel housing until retainer spring disengages from pivot.
  11. Remove clutch release hub and bearing from clutch release shaft.
  12. Loosen six clutch pressure plate bolts evenly to release spring tension gradually and avoid distorting clutch pressure plate. If same clutch pressure plate is to be installed, mark plate and flywheel so pressure plate can be installed in its original position.
  13. Remove clutch pressure plate and clutch disc from flywheel.
INSTALLATION:
  1. Position clutch disc and pressure plate assembly on flywheel, noting following:
    1. Three flywheel housing to block dowels on flywheel must be properly aligned with clutch pressure plate.
    2. Bent, damaged or missing flywheel housing to block dowels must be replaced.
    3. tart clutch pressure plate bolts but do not tighten.
    4. Avoid touching clutch disc face, dropping parts or contaminating parts with oil or grease.
    5. Align clutch disc using suitable alignment tool inserted in pilot bearing.
    6. To avoid clutch pressure plate distortion, alternately tighten bolts a few turns at a time, until they are all tight, then tighten to specifications.
  2. Install transmission to flywheel housing.
  3. Install engine rear plate to flywheel front lower housing bolts, then connect clutch release cable to flywheel housing and connect retaining clip.
  4. Connect clutch release lever cable to clutch release shaft, then install clutch release lever dust shield.
  5. Install starter motor.
  6. Lower vehicle, then install clutch release lever cable as follows:
    1. Lift clutch pedal to disengage clutch and brake pedal pivot shaft.
    2. Push clutch and brake pedal pivot shaft forward and hook end of clutch release lever cable over rear of clutch and brake pedal pivot shaft.
  7. Cycle clutch pedal several times to adjust clutch release lever cable
Aug 08, 2009 | 2001 Ford Mustang
Intermittent A/C operation
I think your a/c clutch is going. If it works for a while and cuts out, the electrci clutch is getting hot and losing the ability to stay clamped.
Sometimes, you can shim the clutch so it's less of a gap to close. Or, replace the clutch.
SECTION 412-03A: Air Conditioning 2001 F-Super Duty/Excursion/Motorhome Chassis Workshop Manual
REMOVAL AND INSTALLATION Clutch And Clutch Field Coil —5.4L, 6.8L
Removal
  1. Remove the A/C compressor. For additional information, refer to Compressor—5.4L and 6.8L in this section.
  1. Remove the A/C clutch hub retaining bolt.
    1. Hold the A/C clutch hub with the special tool.
    1. Remove the bolt.
  1. Remove the A/C clutch and the A/C clutch hub spacer.
    1. Thread an 8 x 1.25 mm bolt into the A/C clutch hub spacer to force it from the compressor shaft.
    1. Lift the A/C clutch and the A/C clutch hub spacer from the compressor shaft.
  1. Remove the pulley snap ring.
  1. Remove the A/C clutch pulley.
  1. s1o~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use air tools. The A/C clutch field coil can be easily damaged.
    Remove the A/C clutch field coil.
    1. Note the location of the A/C clutch field coil electrical connector.
    1. Install the special tool on the nose opening of the A/C compressor.
    1. Install the special tool.
    1. Remove the A/C clutch field coil.
May 22, 2009 | 2002 Ford F250 Super Duty SuperCab
Need to take off fan clutch, have taken off parts in the way
4.9L SFI
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Fan Clutch Holding Tool T84T-6312-C Fan Clutch Nut Wrench T93T-6312-B
Removal
  1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The large clutch assembly nut has a right-hand thread and must be rotated counterclockwise to remove it.
    Remove the fan clutch (8A616) from the water pump (8501) by turning the large nut, which is part of the fan clutch, using Fan Clutch Holding Tool T84T-6312-C and Fan Clutch Nut Wrench T93T-6312-B.
  1. Remove two screws retaining fan shroud.
  1. Remove the fan blade (8600), fan clutch and shroud.
  1. If the fan blade and fan clutch have to be separated, remove the remaining bolts attaching the fan blade to the fan clutch
5.0L, 5.8L and 7.5L Engines
Removal
  1. Remove screws retaining fan shroud (8146) to radiator (8005).
  1. Remove four screws retaining clutch on water pump hub.
  1. Pull fan clutch and fan blade off water pump pilot and remove fan clutch, fan blade and shroud from vehicle.
  1. Remove four screws and separate fan clutch from fan blade.
Item Part Number Description 1 8509 Water Pump Pulley 2 57632-S Screw and Washer Assembly, 5/16-18 x .62 Hex 3 8600 Fan Blade (5.0 and 5.8L) 4 8600 Fan Blade (7.5L) 5 8A616 Fan Clutch 6 380288-S2 Screw and Washer Assembly, 5/16-24 x .88 Hex A — 16-24 Nm (12-18 Lb-Ft)
Mar 10, 2009 | 1994 Ford F150 Styleside Supercab
Cub Cadet Riding Lawn Garden Tractor 25hp Kohler 50" Logo
517 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
