Question about Ovens
Hotpoint ew84 cooker or grill not working but hobs are what wrong?
Basically the display is blank, there is no light in the oven and the oven and grill do not heat up, and wanted to know what's wrong, turned it on and off but nothing changed.
barkencoa
  • 3463 Answers
SOURCE: fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Posted on Dec 27, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Plz rate my solution.
Thanks.
Posted on Jan 12, 2009
SOURCE: Beko D533 cooker only half working
where the power goes in there should be fuse links on both sides if they all in then its the thermal fuse inside
Posted on Jun 22, 2009
barkencoa
  • 3463 Answers
SOURCE: PRIMA FAN ASSISTED COOKER - FAN WORKING BUT NO HEAT?
Hi.
You will need to check the oven element, it probably needs replacing.
Please rate my solution.
Thanks.
Posted on Jul 14, 2009
SOURCE: Samsung PKG001 Stainless steel Single Oven and ceramic hob
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
Posted on Sep 04, 2009
The grill and ovens on my Jackson Topline cooker have just stopped working, the rings work but none of the lights above the switches are on when they are working, any Ideas please? thanks.
I am not familiar with your model of cooker but I assume it is a gas cooker.
Gas cookers have safety devices in the oven and grill the hob rings do not need. I speculate even the domestic oven hasn't escaped the interference from the electronics industry and I expect the aforementioned safety devices depend on (low voltage) electronics and electronics depend on electricity - that the lights aren't working would suggest there is no (low voltage) electricity.
Even in the case of an electric oven the thermostat could be electronic and need (low voltage) electricity to work.
I suspect the internal power supply has failed.
Jun 17, 2016 | Ovens Ovens
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
Hotpoint oven suddenly stopped working
Sounds like a control board problem. When the display goes out that is usually a dead board.
Mar 10, 2014 | Hotpoint Ovens
Gas hob will not light on my leisure gas hob
At the rear of the oven is a gas cut off valve. Try twiddling it
Nov 24, 2013 | Ovens
Our beko dv 555 w double oven bottom oven is not working as the clock display is not on
Beko DV 555w Electric cooker.Oven and clock is not working.
The hob and grill work.
Nov 19, 2010 | Ovens
MY STOVES COOKER'S OVEN AND GRILL HAS STOPPED WORKING?THE HOB IS WORKING FINE.
The hob is normally totally independent of the oven. What is actually working or not working on the oven? i.e. does the grill still work, is the clock OK and can you set it, or is everything totally dead?
Oct 16, 2010 | Stoves 720EF Electric Double Oven
The light on my aeg competence oven and grill is not working. I can not use the timer.
It's either the thermostat / switch or the timer unit. Make sure the timer was not set to have turned off the grill first
http://www.espares.co.uk/part/cookers-and-hobs/thermostats/aeg/p/1604/143/0/0/1061574/top-oven-thermostat.html
May 20, 2010 | Ovens
Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Aug 26, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Hotpoint Double Oven ceramic hob
suspect more than one problem. half grill not working may be due to half the element gone open circuit. the other problems could be due to an installation fault. many ovens have links in the connection box which have to be tightened down. this is often overlooked. look at the connection box or terminal strip to check. there is often a diagram of hoiw it should be done adjacent.
Jun 02, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
