Hotpoint aquarius aq 90 691 aqualtis f6 flashes
SOURCE: Hotpoint Aquarius WD440 Error
Remove the white plastic cover on the back near the bottom. To the right as you look at it their will be a black concertina pipe with a hose clip on its top edge. Undo this and pull the pipe downwards to reveal the filter. There will be a plastic ball inside (which is supposed to be there) remove this and clear out the cr*p.
Re-assemble as removal.
That should fix it
Posted on Apr 27, 2009
SOURCE: my hotpoint aquarius wd440 has flashing lights
First of all try cleaning the filter inside the back as described by others if this does not work there is a filter in the top. how you clean this is quite easy. all you do is remove the top of the machine by undoing the 2 screws at the back then pull top top backwards when you have removed the top you well see a large metal casing on the left if you are looking from the the back of the machine the filter is in there to remove the casing you pull the small pipe off then undo 5 star headed screws then gently pull the casing off noteing that there is a large pipe at the front when you have remover the casing you will see the filter (the small pipe you removed at the start fits on this filter) clean the filter then put it all back together.
Posted on May 17, 2009
MsMithra
  • 79 Answers
SOURCE: Hotpoint Aqualtis AQGF 149 Error F-05 what does this mean?
F-05 means service switch jammed.
Hope this helps. =)
Posted on Oct 10, 2009
SOURCE: control panel lights ALL flashing on hotpoint aquarius washing ma
my lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
Posted on Feb 16, 2010
  • 662 Answers
SOURCE: Hotpoint Aquarius not completing finally spin and pumping out
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The filter is inside the machine. Turn off the power and pull out the machine to get to the rear. Pull out the hose you see going into the wall pipe, lay at floor level or plastic bag to drain out remaining water in machine. Remove the panel at the bottom (2 screws) where the discharge hose comes out. You should see a black concertina type tube coming from below the drum attached by a jubilee clip. The filter is inside. Loosen the clip and pull away the tube, take out the filter and clean it. When you replace it don't forget to put the ball float back in (exactly as you found it) and check it’s well fixed by running a spin cycle before sealing up. Caution, the exit drain hose shd be fitted at the exact location where you found it, abt three feet up from ground level.
Pl rate me nice for the free help, thnks.
Posted on Jun 04, 2010
My hotpoint Aqualtis has an f6 code displaying.. Any ideas on what the problem is and how to fix please?
Hi!
F6 means:
- Broken buttons;
- A faulty electrician between the control board and the controller;
- Faulty electronic module
Mar 05, 2017 | Hotpoint Washing Machines
My hotpoint aqualtis model number aq9f 492 u is showing f6 what does this mean
F06 Door lock fault
Issue: Washing machine door cannot be opened or closed / when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
Dec 29, 2015 | Hotpoint Washing Machines
Hotpoint aqualtis not draining
Hi.
Check the drain hose at the back and access the drain filter located at the bottom side of the appliance.
Please click here to read an article showing how to fix common drain problems.
Regards.
Ginko
Apr 28, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aqualtis giving H20 error, looks like fill problem, but cannot see anything stopping the water flowing into the machine.
i have hotpoint aqualtis, it washes & empties but then starts flashing when ready to rinse. any suggestions?
Dec 04, 2009 | Washing Machines
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
Hi fixya aqualtis washer 4 yr old display light flashing machine jams i have empty filter in the past and this has solved the problem but not this time thanks ben
Is the pump running and or do you see rotor on pump.Seems to me that either pump is blocked or outlet hose.Machine wont spin if water is left inside.Pump could also be destroied.Jan
Jan 18, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
On a hotpoint aqualtis aqxx149pm i get error code f8 flashing
Hi.
F8 means that heater relay cannot be activated, you need to call an engineer.
Could be expensive, possibly a new control board needed
Nov 19, 2008 | Hotpoint WMA35 Front Load Washer
Aqualtis AQGD 169 S F12 problem Please help :-(
ok, I have just had the 'blocked pump message and after much playing around I have solved it.
Pull the machine out and take the drain out and place in a bucket. Then tilt the machine on its side about 30 to 45 degrees so you can get a hand underneath. At the front there is a black rubber pipe-squeeze this a few times and then run the machine on a pump cycle. Put water in machine (i used a bucket) and repeat. You should get the foul smelling gunk out of the pump. I did this about 4 times and finally the water comes out clean and you should be ok.
Regards and good luck,
Matt
Jul 01, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
Top Washing Machines Experts
