Kf 51gw airconditioner
My iglu KF-51GW/GX1a drips continuously after several hours of operation in cooling mode ( this model has no heating mode). how do I correct tyhis problem????
2 Suggested Answers
  • 587 Answers
SOURCE: I have an artic airconditioner
The value is on the capacitor, but if you can't read it, you need the model number of the compressor and you can call a appliance parts store and they should be able to help you.
Posted on Oct 17, 2010
I need LAMP DOOR Cover Mine got warpped from heat
Contact someone from sony, call or send them an email asking where you could purchase this replacement panel.
Jan 27, 2015 | Sony Replacement lamp for Grand WEGA or...
Celiera 51GW 18000BTU mini split a/c heat, water collects on top rear coil and drips into fan housing and comes out bottom
While cooling, water is supposed to drip off the evaporator coil and flow out the unit. That's a feature of air conditioning. You get a little bit of control of where the water drips to by installing tubing to conduct the water wherever you like, unless the outlet port is plugged up. Poke a toothpick up it and see if that unclogs it.
May 13, 2014 | Haier HEATER CPN10XH9 Air Conditioner
My kfr-51gw/gx1a unit is 3 yearrs and is blowing a black like suit out off it
The soot is temporary.Will go away.Check the flue damper is moving freely.
Nov 22, 2011 | Heating & Cooling
I have an artic airconditioner model KF-51GW, I want to know the value of the compressor capacitor ( I lost the orinal value).
Oct 17, 2010 | Heating & Cooling
It overheats and pops the Xl-2100u lamp?
by pops? do you mean it explode? how many lamps? it could be the fan that supposed to be ventilating the lamp or it could be the the ballast, why the ballast because the ballast regulates the voltage in order the keep the lamp on, for ignition it sends around 15,000 volts after that it regulates the votage to a small amount of voltage around 5,000 so it could be sending the big amount of voltage all the time never regulates that or it could be regulating and then sending another big amount of voltage over and over until the lamp doesnt handle those changes.
Apr 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
We are trying to find out what an E4 on a Celiera
Does anyone know what does that means
Mar 30, 2010 | Heating & Cooling
AFTER A FEW MINUTES OF OPERATION ON MY SONY KF-42WE610TH LCD PROJECTION TV THE SCREEN GOES BLACK.THE SOUND COTINUES AS NORMAL.AFTER A COUPLE MINUTES IT COMES BACK ON THEN REPEATS UNTIL THE SET HAS RUN FOR...
First blush - the protective device called a "thermister" is heating up and "fusing". When the system cools down, the thermister releases the protection and allows the highvoltage transformer to provide power again.
Often times a device is drawing too much current - and the thermister shuts off the device to protect it - much like a fuse.
I have been able to maintain service on my TV by adding more cooling air to the existing fan. If your cooling fan is not turning fast enough - it can also cause the problem.
Nov 14, 2009 | Sony XL-2100U Projector Lamp for...
Xl-2100u
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your Projector from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your unit Caution: Do NOT touch the bulb directly with your fingers.
  • Oct 19, 2008 | Sony XL-2100U Projector Lamp for...
    Heating & Cooling Logo
    Top Heating & Cooling Experts
    paulcarew
    Dan Webster
    Dan Webster
    Donni Steen
