Question about Goodmans W280NS Television
Goodmans plasma gtv42p4
Screen powers up,but the images appear very "distant" like as though the contrast and brightness have been tuned to minimum
Re: goodmans plasma gtv42p4
If you have had this tv for a while, then it is likely screen burn, this happens from leaving the tv on for prolonged periods of time displaying the same image, some pubs / bars buy plasma tv's then after a couple of days of being left on a sports channel they're broken due to constantly displaying the same image (the information boxes on the screen). It's a problem all plasma tv's have. If you have some kind of TV guide and you left it on that and went out for the day, that could easily have done it.
Posted on Jun 18, 2009
Re: goodmans plasma gtv42p4 - Goodmans W280NS Television Flat Panel Televisions
Buy new telly
Posted on Dec 17, 2007
0 characters
3 Points
Voire 46" plasma tv- best color settings, to much white
The proper way to set flat screen tv's is opposite of old school CRT tv. First, find a movie with dark scenes and pause on a really dark part. Now set brightness only high enough to see some detail - no more. then go to a really bright scene and set contrast just high enough for good brightness. You may need to go back and forth a few times to get good setting.
Dec 21, 2013 | Toymax Viore 42 in. Plasma TV
Scan lines missing
wow..that's most definitely a video drive error. 1. Check to see your settings are good still. It's not out of the realm of possibility that something glitched in the settings. 2. Missing information is a video drive issue, period. I'd suggest that you have a video board that's truly unhappy. Is this still under warranty? Hope so, since these service calls can run some serious dough.
Feb 11, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Gateway 42in plasma p420142v5
try check its settings, maybe its not configured properly..if you have remote control on it, locate the menu button then go to picture settings or video settings then adjust the contrast, brightness, and the color of course to your desired level..
Jan 24, 2008 | Gateway GTW-P42M303 42 in. Plasma...
We got hit by lightening. The tv still works but the picture is color is affected- very light.Anything that can be done? Is there a degausser button?
Unless this is a tube set there is no Degaussing. Even the tube set have built in degausing when powered up.
LCD, LED, Plasma and projection sets are not affected by magnetic fields near the display like old tube sets.
You may be able to fine tune your colors through your OSD
Most sets allow consumer adjustments on brightness, color saturation, hue , contrast etc and are accessable through the On Screen Display or Setup option
Aug 03, 2011 | Flat Panel Televisions
42inch sonya flat sreen tv turn on I get sound I could see the sreen alittle bit but its dark
check the contrast and brightness settings. check if its set to minimum... if so just set to the correct contrast and brightness settings... if problem did not solve. and if its under warranty just bring the unit back to the store or in the authorized service center. or call a local repairman because there is no serviceable parts inside. ty
Jun 23, 2011 | Sanyo DP42746 42 in. Plasma Television
A Green Blotchy Area about 9 in oval in the upper part of teh screen
Plasma with Burn in within 3 years, I bet. I've seen Week old plasma's with burn in. Plasma technology is not as good as some would make it out to be. Due to the nature of the physics of the device, it is susceptible to something called "Burn-in" When an image of any form is displayed for long periods of time on a Plasma display, they start to literally burn in or wear out that part of the screen faster than a moving picture elsewhere on the screen. ie. If you have a television that is always on one channel and that channel always displays the little logo in the bottom right of the screen (abc, cbs, speed...) that kind of thing, you will eventually actually be able to read that logo even when the plasma tv is turned off. Check your manual or the manufacturer's website for your tv, and somewhere in there, it will refer to a "half-life" of the tv. ie. if your model has a 2000 hr half life, after 2000 hours of viewing, the display can at maximum, put out 1/2 of it's total brightness output. after another 2000 hrs 1/2 again as bright. and eventually it will be so dim that it's unusable. This is a fault with Plasma technology, LCD does not have this issue. CRT used to have this issue, but advances in technology have lowered this risk. So. What you are seeing is remnants of a bright image that was more often shown on that part of the screen than anywhere else on the screen. There is nothing that can be done other than replace the unit (or the screen, but it's easier to change the whole unit). if you've had this unit for 3+ years, you did pretty well. doing the math, if you only use your tv for 2 hours a day, for the 3 years you own it, assuming a 2000 hr half life, you've broken that limit. meaning that you will have parts of your screen that are very likely half as bright as others. Nature of the beast (plasma). This is why they are not as popular as they are advertised. Try an LCD next time.
Aug 06, 2007 | Pioneer PureVision Pro-1000HD 50 in....
Whats the difference between a LCD and plasma
Answer: Outward appearances are definitely deceiving when it comes to LCD and Plasma televisions. Although both types of televisions are flat and thin, they employ different technology in an attempt to deliver similar results. Plasma TV Overview Plasma television technology is based loosely on the fluorescent light bulb. The display itself consists of cells. Within each cell two glass panels are separated by a narrow gap in which neon-xenon gas is injected and sealed in plasma form during the manufacturing process. The gas is electrically charged at specific intervals when the Plasma set is in use. The charged gas then strikes red, green, and blue phosphors, thus creating a television image. Each group of red, green, and blue phosphors is called a pixel (picture element). Although Plasma television technology eliminate the need for the bulky picture tube and electron beam scanning of traditional televisions, because it still employs the burning of phosphors to generate an image, Plasma televisions still suffer from some of the drawbacks of traditional televisions, such as heat generation and screen-burn of static images. LCD TV Overview LCD televisions, on the other hand, use a different technology (see also question #1 for this same explanation). Basically, LCD panels are made of two layers of transparent material, which are polarized, and are "glued" together. One of the layers is coated with a special polymer that holds the individual liquid crystals. Current is then passed through individual crystals, which allow the crystals to pass or block light to create images. LCD crystals do not produce their own light, so an external light source, such as florescent bulb is needed for the image created by the LCD to become visible to the viewer. Unlike standard CRT and Plasma televisions, since there are no phosphors that light up, less power is needed for operation and the light source in an LCD television generates less heat than a Plasma or traditional television. Also, because of the nature of LCD technology, there is no radiation emitted from the screen itself. Plasma vs LCD The ADVANTAGES of Plasma over LCD are: 1. Larger screen size availability. 2. Better contrast ratio and ability to render deeper blacks. 3. Better color accuracy and saturation. 4. Better motion tracking (little or no motion lag in fast moving images). The DISADVANTAGES of Plasma vs LCD include: 1. Plasma TVs are more susceptible to burn-in of static images. 2. Plasma TVs generate more heat than LCDs, due to the need to light of phosphors to create the images. 3. Does not perform as well at higher altitudes. 4. Potentially shorter display life span - this used to be the case. Early Plasmas had 30,000 hours or 8 hrs of viewing a day for 9 years, which was less than LCD. However, screen life span has now improved and 60,000 hour life span rating are now common, with some sets rated as high as 100,000 hours, due to technology improvements. LCD television ADVANTAGES over Plasma include: 1. No burn-in of static images. 2. Cooler running temperature. 3. No high altitude use issues. 4. Increased image brightness over Plasma. 5. Lighter weight (when comparing same screen sizes) than Plasma counterparts. 6. Longer display life used to be a factor, but now LCD and Plasma sets both have at least 60,000 hour or higher lifespans. DISADVANTAGES of LCD vs Plasma televisions include: 1. Lower contrast ratio, not as good rendering deep blacks. 2. Not as good at tracking motion (fast moving objects may exhibit lag artifacts) - However, this is improving with the recent implementation of 120Hz screen refresh rates and 240Hz processing in higher-end LCD sets. 3. Not as common in large screen sizes above 42-inches as Plasma. However, the number is growing fast, with 46 and 47-inch screen sizes becoming more common, and some LCD sets having a screen size as large as 65-inches also available to the general public. 4. Although LCD televisions do not suffer from burn-in susceptibility, it is possible that individual pixels on an LCD televisions can burn out, causing small, visible, black or white dots to appear on the screen. Individual pixels cannot be repaired, the whole screen would need to be replaced at that point, if the individual pixel burnout becomes annoying to you. 5. LCD televisions are typically more expensive than equivalent-sized Plasma televisions (although this is changing), especially when comparing EDTV Plasmas to HDTV-LCD Televisions. For a more detailed look at the LCD and Plasma comparison, check out: Should I Buy an LCD or Plasma Television?
Jan 18, 2010 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Burn in images
When "creen burn" occurs it is impossible to remove and the image will be there permanant. I have seen the same happen to CRT TVs and CRT computer monitors. You have probably had the image on the screen too high in brightness/contrast. Coupled with the fact the image did not change much.
Sorry but there is NO fix for this - apart from a replacement TV.
Oct 07, 2009 | RCA P42WHD33 42 in. Plasma HDTV
Goodmans gtv42 p4
change your backlight or tft light
Mar 20, 2008 | Goodmans W280NS Television
Squares visible in bright colors
Turn down the contrast to about 55-65% of maximum. Also turn down sharpness to about 10-20% of maximum.
If ther is a Contrast Plus option, or digital contrast, turn to minimum or off. (Dependant on TV)
This is a common side effect with digital television.
Jan 23, 2008 | Philips Magnavox 42MF521D/37 Television
Flat Panel Televisions Logo
308 people viewed this question
Top Goodmans Flat Panel Televisions Experts
olayoju victor
Jonathon summesfield
Are you a Goodmans Flat Panel Television Expert? Answer questions, earn points and help others
