when i switch power on, all display lights illuminate for a second then go off. Then there seems to be no power to the appliance at all. i then have to switch off at the plug socket, leave for eight seconds and switch on again with the same results. i have checked the fuses.
The drum bangs back and forth during spins causing the machine to cut power to the motor. I have...
(More)
The drum bangs back and forth during spins causing the machine to cut power to the motor. I have checked that the belt is still sound so does anyone have any idea why this is happening? It is almost like it has broken free from something but could it be imbalanced in some way? The problem only occurs under load, not with an empty cycle, and I have tried several weights to see if this made any difference. It did not!
i am trying to determine the cu. ft of my topload whirlpool washer. i can find no model or serial...
(More)
i am trying to determine the cu. ft of my topload whirlpool washer. i can find no model or serial numbers. on the back towards the top is a part number 3359232 (i believe for the control panel). there is also an insignia that says FSP inside a circle.it is approx 10 years old.
