Question about Dell PowerEdge R900 Server
Server not boot
There are offline or missing virtual drives with preserved cache. Please check the cables and ensure that all drives are present. Press any key to enter the configuration utility. Foreign configuration(s) found on adapter. Press any key to continue, or 'C' to load the configuration utility or 'F' to import foreign configuration(s) and continue.
VooDooNOFX
  • 95 Answers
SOURCE: The server doesn't boot
You can download the drivers here:
http://support.dell.com/support/downloads/driverslist.aspx?os=WNT5&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=PWE_FOS_XEON_4600&hidos=WNET&hidlang=en&TabIndex=
However, due to the many configurations available in the PowerEdge server 4600, there is no way for me to tell you exactly which controller driver to use. You will probably have to make a boot disk to feed the driver to windows 2000.
Comment back with specific controller model numbers, and maybe I can direct you to the correct download.
Steven
Posted on Sep 17, 2008
graysand
  • 558 Answers
SOURCE: Dell PowerEdge 2450 Server issues
Power down thy system,pull the hard drive half way out remove all cards from the slots power up see if you go pass the processor etc,if not go into the system setup f2,integrated devices turn them all.see if you go further if you do go back in turn the devices on one by one,do not put the hard drives in yet.wait until you turn the scsi controler assuming you are using the integrated card.If you still cant the on board raid controler uses a raid dim if you can change thi note it must be the same type.
Good luck
Posted on Sep 04, 2009
Geekman
  • 32281 Answers
SOURCE: I have dell 4600 pe serveri want to install
The hard drive needs to be set as the first SCSI ID device boot device..
The hard drive needs to have the jumper set to SCSI ID 0, the CD and FDD can be set to SCSI ID 1 and SCSI ID 2. No SCSI devices can have the same SCSI ID number unless it is on a different SCS controller.
Posted on Jul 16, 2010
LASITHA-VEGA
  • 428 Answers
SOURCE: I have a Dell Poweredge
hi!
This is a quite serious matter to be solved. The information you have provided is not enough at all.
What you have to include in here:
  1. First, Be precise. Don't assume.
  2. How did you recognized the failure. Which indicators or POST/BIOS/RAID BIOS reported you the errors? Was it from the OpenManageSA?
  3. Please specify the Hardware Controller model and manufacturer with the version (RAID controller).
  4. Which Operating System do you run (or ran)?
  5. Are these disks Hot Swappable?
  6. Have you used hardware RAID controller or software RAID? Provided by OS.
  7. Do you have Dell OpenManage Server Administrator?
  8. How do you describe the RAID configuration? Are you sure that Disk 1 and 4 are mirrored to 2 and 3? You must be precise. Because raids can be used in many ways. You can combine any two disks and mirror them to any two disks. Even though it prevents hard drive failures, if your OS had an issue Mirrors may not be an option to recover it.
  9. That message is a Warning Message. However Drive Roaming has completed. You don't need to worry about that.
  10. If your BIOS has associated firmware controllers you could rebuild the array. But you may have to add new disks to replace others. You may need to update the firmware if necessary.
  11. Then if you plan to use disk 2 and 3, you have to position them to 1 and 4. Then try to rebuild the array. But you may have to have Controller Drive installed on the disk. That varies from type to type. So I cannot say exactly. However if the mirroring of the OS is done to one disk, that disk would be enough. But you have to be certain. Reconfiguring should be done using both the disks replaced if you do not know anything about the configuration.
  12. Check BOOT ORDER. Change it if necessary. If disks fail again check one by one and repair them using a separate machine.
  13. Use Dell Software (OpenManage Server Administrator, if its the one available). Rebuild and or Resync the array.
  14. If boot record errors occur, you have to boot from CD/DVD and repair the Boot Record and/or MBR.
  15. If you need any other issue like BSOD, please write them down. Make sure the OS is not corrupted. If you backed up the System Status, restore it in such a case. Do an In-place Upgrade otherwise (will replace the OS files only, not data).
  16. Use the manuals for Dell Server and RAID Controller if you do not know how to use properly.
  17. If all the options are not working, you have to contact an engineer at Dell.
Feel free to contact again.
Thanks for using Fixya!
-Lasitha
Posted on Sep 04, 2010
  • 83 Answers
SOURCE: I have dell power edge system all hard drive is
your hard is not on mother board properly back track what you did make sure all wires are mother board .
Posted on Feb 26, 2011
My ncomputing device gives a message that"Can't establish connection to server.Connection ended unexpectedly"
reset the ip , clear dns cache and check it.
if u use dhcp server, the reset ip using
netsh interface reset "c:resetlog.txt"
in cmd prompt..
Apr 28, 2015 | NComputing Ethernet Virtual Desktop (L300)
Checking virtual IP servers... [VIP Raw] Connecting to Virtual IP server 127.0.0.1... [VIP Raw] Resolving host name 127.0.0.1... [PASSED] [VIP Raw] Connecting to Virtual IP server 127.0.0.1... [VIP...
clear your Cache and History from/through IE. Try re-opening http://www.yahoo.com on IE then try logging into Yahoo Messenger again.
either manually or try this free tool
http://www.piriform.com/ccleaner
download, install, run cleaner, and then registry options
hope it works for you
Nov 19, 2010 | Yahoo Messenger
Web page will not load
are you loading website trough internet or hosted locally with local web server. give me more detail i will able to fix it for you.
Dec 11, 2007 | Computers & Internet
PXE boot slow, creation of RAM disk failed
RAM disk requires actual memory in order to create a 'virtual' drive. My first instinct would be to check to ensure that RAM is actually available. Perhaps memory is faulty or configured improperly.
Sep 06, 2006 | Microsoft Virtual Server 2005 (w15-00001)
Dell PowerEdge R900 Server   Logo
594 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
