Question about Kitchen Ranges
I have a range GE spectra. I replaced both bake elements, the bottom is working and the top is not. I opened the back panel and saw that top element has 2 wires going to a panel on top (purple and red). The bottom has 2 wires (yellow and red) going to the same panel on top, looks like switches. In order to test the wires, I switched the purple and yellow wires at the top panel. The bottom stopped working and the top started working. Wires and elements are good then. I dont know what is the part at the top panel to replace. Can anybody help?
    Top Expert:
  • Kitchen Ranges Master
  • 12,223 Answers
See the diagram attached, and make the test and fix it. God bless you
I have a range GE spectra. I replaced both bake - fd814ae9-bc0d-442f-81ed-6566bc7a299e.gif40d1cccb-67ce-4a25-ac55-5ee39b49fb0d.gif
Posted on Jul 29, 2013
SOURCE: JBP66G W1AD Oven won't get hot enough
the yellow may be the oven temp sensor?
Posted on Jul 01, 2008
jsrock516
  • 5911 Answers
SOURCE: oven bake element
If you're talking about the wires attached to the BAKE element, normally RED is on the RIGHT and YELLOW is on the LEFT, but it really doesn't matter. Theoretically, this is a resistive heating coil and it will work with the wires connected in either direction. Normally, its fairly easy to determine how these wires reconnect, because the lengths are normally only sufficient enough to connect them one way.
The RED wire connects from the BAKE element to the terminal block, to one side of the BROIL element. The YELLOW wire is connected to one end of the BAKE element and runs to the electronic oven control (EOC) board.
I hope this clarifies this for you.
Posted on Aug 23, 2008
  • 409 Answers
SOURCE: Bake element doesnt work everything else does
hi there,
the bake element can melt for various reasons, however, i think that you problem lies somewhere else.
here is the service manual. have a look through it and let me know if i can be of more help.
http://www.servicematters.com/maytag_library/docs/16010107.pdf
Posted on Sep 26, 2008
  • 62 Answers
Control unit is probably the problem, You should check your Breaker to make sure it didnt trip outside of that you can check voltage to the element with the oven set to bake, if you dont have votage to element then it would most likely be the board. I just checked the wiring diagram for this unit and there is an over limit switch which is a long shot but worth checking. My bet is on the board. There are 2 listings for the part number so if you check on parts make sure you have full model # serial # AND series #(should be a 2 digit number like 10 or something)
Posted on Nov 05, 2008
duby1990
  • 367 Answers
SOURCE: ge spectra jbp64, replacement bottom bake element
Take the 2 screws out of the back wall of the oven (inside) holding the element on. Then pull the element out and it will expose the wires and terminals (2). Unplug the 2 wires and plug them on the new element and mount the element back in the oven and your fixed. (make sure to turn the power off to the oven before you start unpluging wires.
Posted on Nov 21, 2008
Gets warm but not hot enough to cook
most likley the bake element is out! inspect it with a flash light to see if its burnt ..to replace unplug range!!! remove oven door ..open door 3 inches pull up ouickly towards ceiling to remove from brackets ..then remove racks..their are 2 screws holding element in remove them to pull out element ..then remove wires install new bake element.. let me know if it worked ..good luck/joe/
Aug 25, 2010 | GE Spectra JBP78 Electric Kitchen Range
Bake element split and oven will not heat.
thats an eazy one by a new element from one off our links at fixya and install it with the power off and no theres no reason why this happened it just wore out God bless,tom
Jan 01, 2009 | GE Spectra JBP78 Electric Kitchen Range
GE Electric Spectra Oven botton element will not heat
If only one element does not work, then test heating element continuity using a multimeter.
If oven does not bake or broil, then test temp probe.
If there is nothing wrong with elements and temp probe , then test wiring harness to control panel and timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 20, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Ge stove bottom element not working (top working)
The bottom element has probably "blown" out. See if there is a small spot that looks like it exploded. It is similar to an extension cord getting warm and melting in a spot. The only answer is to obtain a new element.
Nov 27, 2008 | GE Spectra JBP78 Electric Kitchen Range
Ge spectra jbp64, replacement bottom bake element
Nov 21, 2008 | GE Spectra JBP78 Electric Kitchen Range
Cooking element
You do not list a full model number. Typically a JBP78_____ uses a WB44X10013 bake element. Disconnect power to range. Take out two 1/4 inch hex head screws holding element in at back of oven. Pull element out a few inches into oven. Disconnect wires. Reverse to install. Not too hard if it is an exposed element. A bit more involved on ranges with "hidden" bake elements (which are under the floor of the oven).
Oct 11, 2008 | GE Spectra JBP78 Electric Kitchen Range
Oven doesn't work but broiler does
I think there is a problem with my top element, it doesn't cycle on when baking. The bottom element works fine. Also, the broiler works. What's the problem?
Apr 29, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
