IH252 inc monitor bottom half darker than top.
About 3 days ago my monitor an iH252 INC 25'' monitor, the bottom right corner look darker than the rest of the monitor. The next day the entire bottom half was darker than the top. Example, if you put brightness and contrast at 100% each the monitor will be really bright. But if you lower it to 50% it's a little dark. Well my monitor is like that, as if the top is at 100% and the bottom is at 50%.
  • JoeP Jul 29, 2013
    I've reset to factory default, and even turned up brightness and contrast to 100%. I've set the "Color Setting" to all available ones, "User, cold, warm etc." I reconnected the HDMI cable, reconnected the power cable. Still the bottom half just stays darker than the top.
  • JoeP Aug 10, 2013
    Ah, yes this monitor is about 3 and a half years old. I've gone and put max brightness and contrast, so after about 20 minutes I forget about it. Since that's the only problem with the monitor at the moment, I'll just have to wait til it gets worst and then upgrade hehe. Thank you for the help, I appreciate it.
  • 3,289 Answers
Thin screen LCD monitor brightness controls operate several fluorescent lamps called "backlights" that are positioned behind the LCD display. Typically, they're located around the edges of the screen - sometimes just at the top and bottom, and other times at the left and right edges and others still at all 4 edges.
iH252 inc monitor bottom half darker than top. - 84fdffef-ec73-450a-8fb9-5901d3322462.jpg
Fluorescent "backlight" lamp, inverter & connection wiring.
The lamps are miniature versions of those sold in stores. They require a support circuitry called an inverter that convert & boosts the level of DC to AC voltage performing the functions of a ballast in a traditional fluorescent fixture.
The reason a part of your screen remains dark is because one or more of the components in the picture above has failed and will not allow the lamp to shine. Replacement lamps and inverters aren't expensive - but requires patience and the ability to disassemble / assemble the monitor (which is usually harder to do than it appears) and solder. They are available various lengths and color temperatures (you must get a lamp that is identical or it will be noticed). If this is a new monitor - you ought to return it for replacement. If used, consider the cost of purchasing a replacement (new or used) vs. repair.
I hope this helps & good luck!
Posted on Aug 09, 2013
Testimonial: "Ah, yes this monitor is about 3 and a half years old. I've gone and put max brightness and contrast, so after about 20 minutes I forget about it. Since that's the only problem with the monitor at the moment, I'll just have to wait til it gets worst and then upgrade hehe. Thank you for the help, I appreciate it."
  • JoeP Aug 10, 2013
    Great help, thank you.
2 Suggested Answers
SOURCE: Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Posted on May 14, 2008
Tip
You may be on to something :) I bought my I-inc TW191D two years ago from...
Don't buy and products from this company they get cheap parts from companies going out of business. They are built to break down as soon as the warranty is getting ready to expire! Hannspree,i-Inc,Hanns.g
on Jul 05, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
I want to replace two regular switches with two utilitech 7 day digital in wall timers.
Go to lowes or home depot and get a book on simple wiring. they have the same ones at the library.
Nov 08, 2013 | Intermatic Inc. ST01C Digital In-Wall...
NOT COMPLETED INSTALLING
Nowadays, everything hs to be done with steam if you want to play Valve videogames.
To do so, goto: http://store.steampowered.com/ and click on the install button (top right corner).
Once you have steam installed, you will be able to activate your Counter-Strike directly with your serial key. It will then download + install itself automatically, without the need for CDs.
There you go!
Jul 20, 2011 | Sierra Online, Inc. Half-Life:...
Im useuing a lg crt 15 inc monitor, few days ago im connecting my pc with samsung lcd 22 inc monitor, but the problem is when im re connecting that crt monitor its only show out of frequency.
the resolution might be too high for the CRT monitor, try to lower the resolution if your going to connect the CRT monitor..., the 22 inc monitor obviously have much higher resolution that the 15" crt monitor. i think the max for that is 1024x800.. hope this helps :)
May 10, 2011 | Computers & Internet
I do not have the manual. What do the Icons mean in the upper left corner?
To top LEFT icon with IHB under it, means irregular heartbeat.
If you'd like to obtain an Owners Manual for future reference call:
HoMedics Inc, Customer Service 800-466-3342, 8:30a - 5p ET, Monday - Friday.
Hope this helped you. Please let me know. Thanks.
May 09, 2011 | Walgreens By Homedics Automatic Blood...
I-INC monitor to use with my Dell Laptop, no signal to monitor?
When Windows logo disappear on the I-INC, do you still see it on the Laptop monitor?
All laptops have function keys to switch the screen between the external monitor (I-INC) and laptop monitor. On your laptop, it is Fn+F8 key. Press them once and wait for 3 seconds, it will switch the image between 2 monitors (external monitor ONLY, laptop monitor ONLY, and both).
During start-up, do not close the laptop cover. Because it may put your laptop into a stand-by mode and turn off the screen. You need to modify this Power Option setting within the Control Panel.
Mar 28, 2009 | Dell Inspiron 1100 Notebook
Darker fatter letters every 2 inches apart from top to bottom
it is called phase you can attempt to let the lcd monitor auto set or you can disconnect the power over night then plug in and then do not auto set this default usually seems best some times
Nov 29, 2008 | Proview PL926WBi 19" LCD Monitor
Streaks make letters fatter every 2 inches apart across screen
this is called phase it can be set auto by the button or you can disconnect the power and next day reconnect and leave it in default which can be better than letting the monitor try to set the phase.
Computers & Internet Logo
270 people viewed this question
David Payne
David Payne
