Question about Rangemaster Kitchen Ranges
Bathroom fan our bathroom exhaust fan, rangemaster model 562, does not suck air. it blows it into the room. could it be installed upside down?
SOURCE: dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Posted on Feb 15, 2007
bigg t
  • 640 Answers
SOURCE: Moisture on bathroom exhause vent
the fan is pulling too many cfm (cubic feet per minute).you can replace the switch of the fan with a potentiometer type switch (this works like a light dimmer)you can reduce the speed of the fan,or you can use a couple of synthetic fiber filters to trap the condensation.good luck
Posted on Jan 05, 2008
TheBigW
  • 34 Answers
SOURCE: Cooling fan Dell Dimension 3000
That is the correct way. It is a newer design that keeps the hot air from the CPU heatsink out of the case. 35C is a good temp.
Posted on Oct 07, 2008
  • 4 Answers
SOURCE: Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Posted on Jun 18, 2009
  • 250 Answers
SOURCE: Brand new Kenmore microwave fan does not **** up air
It's easier to notice air blowing out of something than it is to notice air being sucked into something. Put a pot of boiling water on the stove and see if the oven sucks up the steam from it. If it does, it's working fine.
Posted on Sep 17, 2009
Old NuTone 9093n Model replacement.?
Hi -- I just spent a couple of days taking out the old assembly, cleaning all the parts (layers of dust coats) and putting the 9093N back in order to fix the noisy fan. The cold air coming back in is from to the heating and I'd guess the heating element is busted. Yes, you can run it in both airflow modes: ceiling air exhaust and hot air blown to the floor. That said, the noise level on mine hasn't gone down. So I'll look for the replacement assembly. Good luck!
Mar 23, 2013 | Broan-NuTone Dryers
Should the bathroom fan light turn clockwise or counterclockwise
Which direction are the fan blade setup to exhaust the air out of the room? That is the direction it would spin, as this is not designed to pull air into the room.
Mar 17, 2013 | Broan-NuTone N-8663RP Combination Light...
I have a 4 year old RM5200 hood over my stove. The motor is making a whining noise. It seems to soon for this to happen. It is loud and constant to the point where we don't want to use it. Is it time...
Range hood motors, bathroom exhaust fan motors all share the same thing. They become coated with grime inside the shaft of the rmotor due to their exhaust feature of sucking dust and grime over the motor, which is open. The only solution is to get access to the motor and clean the fan blades and squirt a little WD-40 down the shaft as that is where the noise comes from. The dirt and grime build up on the motor shaft, and eventually starts rubbing the bushing where the shaft rest and makes a noise. Yo must remove this from the shaft and allow a little play, and lubrication which the WD-40 will supply.
Feb 15, 2011 | Rangemaster Kitchen Hood
My Bathroom Fan (Nutone) is sucking very little but blowing quite abit from around the fan asembly meets the cutout in the ceiling. The vent outside is blowing out quite a bit of air, (more than whats...
if there is no suction my question back you would be do you have a leak around the box in the cealing did you use calking material when you installed it? let me know so I can help. Also do you have a window open to see if the room breaths? Just some ideals Reply back for more help.
Aug 31, 2010 | Broan-NuTone N-763RLN Combination Light...
Rangemaster 256 no longer sucks air and is noisy
I have an old range master 42" vent hood and some of the electric wirer were cut & Im replacing the light switch & fan switch could you please send me the electrical digram so I can reconnect the model 256 120 v 60hz 2.5 amps
Jul 23, 2010 | Rangemaster Kitchen Hood
I just had a Broan Elite E662 hood installed and it is blowing out instead of pulling air in. I held a tissue up to the filter and it does not pull it up...rather it blows it down. Was something done...
It sounds like the fan blade may be installed upside down, or the entire motor/fan assembly is upside down. Typically, these small motors aren't reversible, so you should check the blade first.
Dec 13, 2009 | Broan-NuTone Broan Elite RM605404 Kitchen...
Sep 17, 2009 | Kenmore Kitchen Ranges
New bathroom venting in basement bathroom.
Install a window mounted exhaust fan if you can discharge to the outside of the house surrounding atmosphere.But undercut the door of the batroom to allow air coming in into the room.Alternatively firt a door grill 600 x 150 mm size which is more expensive.THe size of the fan should be 50 to 100 l/s of air flow.
Mar 24, 2008 | Fantech Fans Exhaust Fan In-Line
Blow back istead of suck out
This installation guide on the Jenn-Air web site does not provide electrical details, but there are two possible problems here.
1. - The fan could be installed backwards...or upside-down...so it moves air the wrong way
2. - The power wires might be connected incorrectly.
My best guess is that the fan uses a standard ac-powered motor, so the polarity of the wiring would not affect the direction it turns. If that is true, then the most likely problem is that the fan is installed incorrectly.
Good luck...and I hope this is helpful!!
Jan 17, 2008 | Jenn-Air JXT8030ADS Kitchen Hood
Kitchen Ranges Logo
47 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Chris Hall
Chris Hall
Ismael Rodriguez...
paulcarew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
