Question about Husky H1503tp
Air compressor runs continuously - Husky H1503tp
I have a Craftsman compressor Model # 919-15292 2. The compressor stopped building pressure because air was continually being released through the unloader valve. I have replaced the unloader valve,...
you must have wired the new pressure switch incorrectly .when the pressure switch opens it will release the head pressure so your compressor must be running with the pressure switch contacts open should be 4 connections 2 marked motor which is from your compressor and 2 marked line which is your power coming in
Jun 15, 2011 | Craftsman 33 gal Air Compressor 6 hp...
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Mar 01, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Back end of my 2001 Ford Expedition FWD, Eddie Bauer, was dragging. Had diagnostic test run and found out it needed a new air ride compressor. Had compressor installed, but compressor continues to run...
The compressor should only run until the rear suspension reaches the desired height. If it continues to run after the suspension has raised to ride height then you may have a leaking air bag/solenoid or line. If you dont have any leaks it is possible the EVO(air suspension module} or relay is at fault.
Nov 14, 2010 | 2001 Ford Expedition
The air continues to run after setting thermostat
mcdevito75 here, The FAN will continue to run this is normal but the compressor should shut off at intervals, you can usually hear the compressor going on / off. If your sure the compressor continualy runs, contact your local a A/C repair shop, they come to the house.
Jun 25, 2010 | Heating & Cooling
Compressor continues to run but doesn't refill so no pressure
hi there, several reason can be consider,check the belt tension slipway of belt can cause lost compression,but if belt is good,mainly lost compression causes of worn out compression ring,or the discharge valve is not functioning the air is flowing back.try to disconnect the belt,rotate the pulley manually you can feel at the suction side if air is sucking on suction side.if air is not entering in the suction side.replace piston ring.have a nice day dont frget to fix my rate thanks a lot.
May 12, 2010 | Air Tools & Compressors
Compressor runs loaded continuously even in low/no demand periods
Each compressor should be checked several times per year as to length of time it takes to fill an empty tank to set pressure. This will provide chart of performance / efficiency. I believe that compressor #2 is not running to full capacity. If compressor # 2 is suffering from leaking valves or headgasket the head and air discharge temp will higher than compressor #1. Good luck!
Oct 14, 2009 | Ingersoll Rand Air Tools & Compressors
Compressor not building pressure and continues to run
Unplug it and listen for air leak. What pressure does the manual tell you it should run to? The safety release could be bleeding air, listen for that, with it off. Make sure it is designed for more than 60 PSI by manufacture.
Jul 20, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Dometic RV air condtioner will not cool
Replace the compressor run capacitor.
Jul 05, 2009 | APC Heating & Cooling
DuoTherm compressor starts but will not continue to run
check condenser fan if running. it will make compressor comes on and off if broken
May 31, 2009 | Dometic Rooftop RV Air Conditioner
Husky H1503tp Logo
61 people viewed this question
Top Husky Air Tools & Compressors Experts
Lawrence Oravetz
Gil Shultz
ray gallant
Are you a Husky Air Tool and Compressor Expert? Answer questions, earn points and help others
