Question about Diamond Multimedia S3 Trio 64 86c764x 9550 fa2354 Stealth 64 DRAM T PCI 2MB VGA Graphics Accelerator Video Card - v 2.09 - Expandable to 4MB
Sound not working
Volume all the way and no sound coming out of device
I have an HP Laptop with Windows 7 and I have correctly set up my Logitech LS21 speakers, but the volume control does not enhance the sound coming from my laptop. The speakers work fine, but the sound is...
There are 2 volume controls on the audio output in windows 7. one is the system volume the other is the device volume. make sure that they are both at full and then control the sound volume on your speakers.
Jan 20, 2013 | Logitech LS-21 2.1 Speakers
Speakers were working,then i pressed something to see if was gonna sound different and now i cant find my way back to what it was...sound is coming from the computer to the tv,,but external speakers have...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope it helps
Sep 22, 2011 | Logitech X-230 Computer Speakers
My Speakers are not working, no sound is coming out and the volume control dosent ever work
If you are having problems with you sound
also
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Aug 21, 2011 | Computers & Internet
Cant see the sound icon, no mixer balancer, no voice..
Your Notebook might be missing Sound driver.
Here is the download link : http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/1ga241ww.exe
Download the driver and install it.Your sound should work fine.
For sound icon.
Go to "Control Panel"
Click "Sound and Audio devices"
Under "Device Volume"  tick " Place the Volume icon in the Taskbar."
Your Sound Mixer will automatically comes when you double click the Sound icon.
That's it.
Jan 06, 2010 | IBM ThinkPad R50e Notebook
My volume has stopped working its sayn no device
try unistalling the device from device manager, then reinstalling the drivers from hp. if your sound card is not built into the motherboard, then try to remove it and then put it back in firmly (with the computer turn off of course). if this does not help, a new sound card can be had for cheap from tigerdirect.com
Sep 13, 2009 | Computers & Internet
Have external gateway speakers
First make sure your sound cards are working properly. 1) Check the master volume of your PC. Go to start menu, control panel, sounds speech and audio devices, sounds and audio devices - i) In volume tab click the speaker volume and check whether all the left, right, etc.. volumes are in medium or high. ii) In audio tab click the volume tab of sound playback and make sure that the master volume is not in mute and all the volumes are either in medium level or at 100%. After making these changes try playing any music. Even if the problem persists go and get your sound card checked in an authorised service centre.
Thanks & Regards,
Shiva
Sep 11, 2009 | HP (ZD929AA) Computer Speakers
Installed USB microphone, but NO sound.
select the device from control panel /sound and audio device / audio .../sound recording ...
if it doesnt work ...look for the device ( microphone ) on volume panel ( double click the speaker from the system tray ) if you do not see a volume for mic...click options..and check the microphone from there ...after that look out and be sure it s not muted...it has to work if it is proper installed..
May 28, 2009 | Micro Electronics PowerSpec 8250 PC...
Sound from only 2 of 4 speakers
Use the software that came with the card and make sure that it knows what you are using. Which would be "4CH Speaker". If this doesnt work, open Control panel > Sounds and Audio Devices > Volume> Device Volume advanced and from the options menu make sure that none of the 4 speakers are muted.
May 05, 2009 | Creative Labs Sound Blaster Live! 24-bit...
System has power and cd's spin but no sound coming from the speakers. checked all connections and tried speakers with a different system they work fine. Please advise, Frank
First, check volume levels in mixer, both output volume and cd input volumes...Go to control panel>sound and audio devices>hardware and check to see that your sound card and drivers are working properly. Use troubleshooter if devices are disabled or not working properly. Make sure advanced settings for sound are correct for your speaker type....
Also see this article: http://support.microsoft.com/kb/307918
or search sound problems vista for alternate article.
Apr 20, 2009 | Audio Players & Recorders
No Sound
1) First check the mute.
2) Make sure there aren’t headphones plugged in, that will disable the speakers.
3) Check the audio setup
4) Check your Volume lock
Changing Volume Lock
The remote comes preset to allow independent volume control of each selected device (Global Volume Unlock).
However, you may change the Volume Lock setting to Global Volume Lock so that one device’s volume will
control volume in all other modes. After that, you can perform Individual Volume Unlock on a selected device to
set its volume control for independent operation or Global Volume Unlock to remove all volume locking.
Locking Volume Control to One Mode (Global Volume Lock)
1. Press and hold SET until the red LED blinks twice; then release.
2. Enter 9-9-3 and then press the mode key for the device you want to control volume (for example, TV).
The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected device (for example,
TV) will control the volume regardless of the current mode.
Unlocking All Volume Control (Restoring Global Unlock)
2. Enter 9-9-3 and then press VOL+. The LED blinks four times. Volume is now
independently controlled for all programmed devices.
Unlocking a Single Device’s Volume Control
1. Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
2. Press and hold SET until the red LED blinks twice; then release.
3. Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
independently controlled for the selected
Mar 15, 2008 | Polaroid FLM-2632 Television
Diamond Multimedia S3 Trio 64 86c764x 9550 fa2354 Stealth 64 DRAM T PCI 2MB VGA Graphics Accelerator Video Card - v 2.09 - Expandable to 4MB Logo
74 people viewed this question
Top Diamond Multimedia Computers & Internet Experts
David
David
Lawrence Oravetz
Jason Harris
Jason Harris
Are you a Diamond Multimedia Computer and Internet Expert? Answer questions, earn points and help others
